Transferring GreenKVM Osaka Storage KVM VPS 1TB flash sales
No more, already transferred.
- 3072MB RAM
- 2 cores
- 1TB SATA RAID-10 (its a nice 1024GB actually)
- IPv4: 1
- IPv6: /112
- Network: 1Gbps
- 2TB Bandwidth
- Linux OS
- SolusVM Control Panel
- Locations: Osaka, JP
                # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-06-05 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Sep 7 17:45:02 +08 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz CPU cores : 2 @ 2599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.9 GiB Swap : 243.0 MiB Disk : 1023.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 20.31 MB/s (5.0k) | 130.31 MB/s (2.0k) Write | 20.32 MB/s (5.0k) | 130.99 MB/s (2.0k) Total | 40.64 MB/s (10.1k) | 261.31 MB/s (4.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 324.83 MB/s (634) | 482.88 MB/s (471) Write | 342.09 MB/s (668) | 515.04 MB/s (502) Total | 666.92 MB/s (1.3k) | 997.93 MB/s (973) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 187 Mbits/sec | 250 Mbits/sec Online.net | Paris, FR (10G) | 183 Mbits/sec | 82.2 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy Biznet | Jakarta, Indonesia (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 230 Mbits/sec | 273 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 242 Mbits/sec | 279 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 247 Mbits/sec | 265 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 113 Mbits/sec | 31.8 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3523 Multi Core | 6368 Full Test | https://browser.geekbench.com/v4/cpu/16336191 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 761 Multi Core | 1477 Full Test | https://browser.geekbench.com/v5/cpu/9712606
---------------------------------------------------------------------- CPU Model : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz CPU Cores : 2 CPU Frequency : 2599.996 MHz CPU Cache : 16384 KB Total Disk : 1024.0 GB (415.0 GB Used) Total Mem : 2989 MB (244 MB Used) Total Swap : 242 MB (215 MB Used) System uptime : 26 days, 19 hour 4 min Load average : 0.08, 0.10, 0.12 OS : Debian GNU/Linux 10 Arch : x86_64 (64 Bit) Kernel : 5.10.0-0.bpo.8-amd64 TCP CC : bbr Virtualization : KVM Organization : AS4785 xTom Location : Osaka / JP Region : Ōsaka ---------------------------------------------------------------------- I/O Speed(1st run) : 928 MB/s I/O Speed(2nd run) : 913 MB/s I/O Speed(3rd run) : 1.0 GB/s Average I/O speed : 955.0 MB/s ---------------------------------------------------------------------- Node Name Upload Speed Download Speed Latency Speedtest.net 275.14 Mbps 69.69 Mbps 2.80 ms Shanghai CT 231.88 Mbps 407.64 Mbps 46.68 ms Shanghai CU 363.01 Mbps 403.02 Mbps 41.47 ms Guangzhou CT 55.97 Mbps 96.68 Mbps 147.84 ms Guangzhou CU 246.36 Mbps 337.60 Mbps 94.56 ms Hongkong CN 338.14 Mbps 506.69 Mbps 64.51 ms Singapore SG 261.03 Mbps 421.51 Mbps 90.69 ms Tokyo JP 101.07 Mbps 154.87 Mbps 8.21 ms ----------------------------------------------------------------------
Thanked by (1)chocolateshirt
Suggest you mention the price somewhere
oops must have edited it out. amended.
Sent you a PM.
stop it,,, do you really really need it?
y-yes (scratching neck)
transferred to a fellow storage addict
