[request] 1 dolar VPS with IPV6
Hello!! looking something really cheap, just to test if my vpn works.
i dont have ipv6 (damn isp) but with openvpn i make it work.
i want a cheap vps with ipv6 as a personal vpn (just to have ipv6)
i ordered a nat servers, but still not get the info from provider so, any other? preferably on USA
Just for clarity, you want to pay $1 p/month or $12 p/year?
if you only need it to test then use one of the free amazon tier ones https://aws.amazon.com/free/
A provider is essentially paying you to use it (none nat) when it is just $1
hey! dont get angry.
Not angry
Was trying to help.
If you just need one for short term test i will give you one, no need to pay.
i dont know, you made me think about it....
let me wait for the nat, if not, i send you a message
Nat is just fine if you need ipv6. I am doing the same thing on @mikho 's box
Nat vps + wireguard + pi hole is all you need.. 4 usd per year for 128 MB vps is more than enough..
i am just waiting the nat vps, i know what to do. just want to confirm it works
pi-hole for what? lol
dont get angry
Take an Amitz a day and temper/anger will never be an issue.
Pi hole inside nat or standalone?
Try Tunnelbroker.net from HE, it's free. You do need a public IPv4 though.
and dont get angry
instructions unclear
pihole stuck in popo, please advice!
ain't mad, just saying ... @Amitz
Also ... with regard to the ipv6 (and not exactly responsive to your $1 request, but maybe for future reference) - @freerangecloud is all about the ipv6 support, and they do some nice deals. Maybe they'd consider an ipv6-only offer, who knows?
HS4LIFE (+ (* 3 4) (* 5 6))
Of course pihole inside nat..
Does wireguard run on OVZ7?
Got a few inceptionhosting nat vps
https://canvay.io - A simple webhosting platform
https://v6node.com - Affordable IPv6 only KVMs
Also might do well to spin up an hourly LunaNode - I think their ipv6 setup is pretty smooth
Not sure what the minimum initial deposit is, but it might be just $5 (or $10?)
ISP blocks also ping:
IP is not ICMP pingable. Please make sure ICMP is not blocked. If you are blocking ICMP, please allow 66.220.2.74 through your firewall.
$3.5 vps from vultr worked great, using this:
ipv6 done
IPv6 connectivity
IPv6 Supported
Address 2904:z880:2:n1::13b:e001
Type Native IPv6
SLAAC No
ICMP Reachable
Hostname None
ISP Chupa
hey yo!
dont get angry
Did anybody say Angry?
Of course it will work, but not on kernel level..
Incidentally, this is why I asked about your requirement for KVM in your other thread but you ignored me.
EDIT: ( comment for iandk not chocolateshirt )
