What in earth is Headless WordPress?
Placeholder… to be updated
Thanked by (1)Janevski
https://www.gatsbyjs.com/docs/glossary/headless-wordpress/
My loose guess would be that it works with command line interface.
Just like headless computers or servers.
Headless WordPress is de-coupling the backend/frontend. Backend runs on WordPress, via API, and frontend can be something else, ie, Gatsby.JS. That allows you to use WP Admin to publish/manage content but also gives you more flexibility to design your site/whatnot.
Frontity for example, would be an example (posted about this in the AIO wp thread some weeks ago):
https://frontity.org/
https://gridsome.org/ is pretty similar but for Vue.
Hmm look like an interesting subject. With headless wp, I think we can have more customization option
some plugins turn your WP headless. They just convert your entire site in static HTML which you can host anywhere, and when user lands on /wp/ of your site, they are redirected to static site. It's good, fast for sites which are not quite updated often. Don't ever think to use this option for wordpress news sites, or daily updating blogs.
other way is using Angular.js infrastructure installed which helps to generate javascript page client's side. It appears to load fast eliminating wordpress headers/php codes. This site is static and dynamic too. Great for news sites, etc. But requires thorough knowledge of Angular
★ 30GB cPanel Hosting $1.49/mo | VPS & Reseller Hosting $14.38/yr
(aff)
Headless cms I guess, for fast development.
Speaking of which: https://wptavern.com/wp-engine-launches-faust-js-a-new-headless-wordpress-framework
Can you explain it in one sentence?
„Homo homini rattus.“
