I've considered Coventry as a location in the UK in the past.
Edit: As a provider this wasn't meant to look like I was jumping in on someone elses thread, just thought Coventry was an interesting choice outside of London.
Decided to stick with Coventry for now since I found a provider that was flexible there
Also, it's all good!
@skorupion said:
gimme gimme gimme e Europe gimme gimme e Europe oh yeah!
london soon?!!?!?!?!?!?!
maybe even germany?!?!?!!?!
or maybe... australia?!?!?!
London! Woot Woot!
Hope you will launch the hybrid line there
We've now confirmed UK as a new location and it should be available within 1-3 weeks. However, we'll most likely be going with Coventry, UK instead of London, UK (which is a little bit farther, but not by much).
Hybrid's will likely not launch there, but, we'll most likely keep the same pricing and specifications as our Dallas location.
LETS GOOOO BI****S WOOT WOOT!!!
Signature currently under construction
Sorry for the inconvenience
London! Woot Woot!
UK is now out, there's an option to choose it at checkout
It's most likely a problem with the software you are using, we don't specifically block anything other than port 25.
Please note that there is limited stock.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 19 Nov 2021 03:11:36 AM CET Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3692.866 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 13.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 4.41 MB/s (1.1k) | 68.72 MB/s (1.0k) Write | 4.43 MB/s (1.1k) | 69.01 MB/s (1.0k) Total | 8.85 MB/s (2.2k) | 137.73 MB/s (2.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 172.78 MB/s (337) | 109.51 MB/s (106) Write | 181.96 MB/s (355) | 116.80 MB/s (114) Total | 354.75 MB/s (692) | 226.31 MB/s (220) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 840 Mbits/sec | 591 Mbits/sec Online.net | Paris, FR (10G) | 798 Mbits/sec | 804 Mbits/sec WorldStream | The Netherlands (10G) | 772 Mbits/sec | busy WebHorizon | Singapore (1G) | 229 Mbits/sec | 326 Mbits/sec Clouvider | NYC, NY, US (10G) | 907 Mbits/sec | 727 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 27.2 Mbits/sec | 566 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 896 Mbits/sec | 688 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 831 Mbits/sec | 571 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 831 Mbits/sec | 559 Mbits/sec Online.net | Paris, FR (10G) | 832 Mbits/sec | 716 Mbits/sec WorldStream | The Netherlands (10G) | 773 Mbits/sec | 567 Mbits/sec WebHorizon | Singapore (1G) | 137 Mbits/sec | 474 Mbits/sec Clouvider | NYC, NY, US (10G) | 861 Mbits/sec | 818 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 886 Mbits/sec | 759 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 398 Multi Core | 396 Full Test | https://browser.geekbench.com/v5/cpu/11078486Could you open a ticket? Those GB5 scores are really low... they should be in the 600 mark since it's 1/2 vCore.
Wtf is that diskspeed
