I've considered Coventry as a location in the UK in the past.
Edit: As a provider this wasn't meant to look like I was jumping in on someone elses thread, just thought Coventry was an interesting choice outside of London.
Decided to stick with Coventry for now since I found a provider that was flexible there
Also, it's all good!
@skorupion said:
gimme gimme gimme e Europe gimme gimme e Europe oh yeah!
london soon?!!?!?!?!?!?!
maybe even germany?!?!?!!?!
or maybe... australia?!?!?!
London! Woot Woot!
Hope you will launch the hybrid line there
We've now confirmed UK as a new location and it should be available within 1-3 weeks. However, we'll most likely be going with Coventry, UK instead of London, UK (which is a little bit farther, but not by much).
Hybrid's will likely not launch there, but, we'll most likely keep the same pricing and specifications as our Dallas location.
LETS GOOOO BI****S WOOT WOOT!!!
Signature currently under construction
Sorry for the inconvenience
London! Woot Woot!
UK is now out, there's an option to choose it at checkout
It's most likely a problem with the software you are using, we don't specifically block anything other than port 25.
Please note that there is limited stock.
Could you open a ticket? Those GB5 scores are really low... they should be in the 600 mark since it's 1/2 vCore.
Wtf is that diskspeed
