<GONE> Transfer NOT Available - Greencloudvps SG 1TB Storage RAID10 10gbps KVM
GONE NO MORE
SG10GbpsStorage-1
- 2 vCore Intel Silver
- 3GB DDR4 ram
- 1TB (technically 1024GB) RAID10 Storage
- 2TB traffic @ 10gbps
- Renews at US$50 annually on 3rd September 2022
- Asking for proportionate remaining value = $37.50
- Paypal Transfer in USD
- Buyer handles Paypal fees if applicable.
greencloudvps allows transfer but please ensure your account is legit etc, hassle free for all.
let me know if you need mtr anywhere.
will need a few hours (actually maybe two but just in case) to transfer out my data.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Dec 4 17:09:43 +08 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Silver 4216 CPU @ 2.10GHz CPU cores : 2 @ 2099.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.9 GiB Swap : 243.0 MiB Disk : 1023.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 7.65 MB/s (1.9k) | 75.73 MB/s (1.1k) Write | 7.69 MB/s (1.9k) | 76.13 MB/s (1.1k) Total | 15.34 MB/s (3.8k) | 151.86 MB/s (2.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 282.71 MB/s (552) | 275.30 MB/s (268) Write | 297.73 MB/s (581) | 293.64 MB/s (286) Total | 580.44 MB/s (1.1k) | 568.94 MB/s (554) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.00 Gbits/sec | 518 Mbits/sec Online.net | Paris, FR (10G) | 1.29 Gbits/sec | 662 Mbits/sec WorldStream | The Netherlands (10G) | busy | 812 Mbits/sec WebHorizon | Singapore (1G) | 414 Mbits/sec | 588 Mbits/sec Clouvider | NYC, NY, US (10G) | 675 Mbits/sec | 395 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 428 Mbits/sec | 631 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.02 Gbits/sec | 668 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 348 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2844 Multi Core | 5121 Full Test | https://browser.geekbench.com/v4/cpu/16430072 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 612 Multi Core | 1186 Full Test | https://browser.geekbench.com/v5/cpu/11411496
---------------------------------------------------------------------- CPU Model : Intel(R) Xeon(R) Silver 4216 CPU @ 2.10GHz CPU Cores : 2 CPU Frequency : 2099.998 MHz CPU Cache : 16384 KB Total Disk : 1024.0 GB (442.0 GB Used) Total Mem : 2989 MB (199 MB Used) Total Swap : 242 MB (242 MB Used) System uptime : 44 days, 23 hour 22 min Load average : 0.01, 0.14, 0.18 OS : Debian GNU/Linux 10 Arch : x86_64 (64 Bit) Kernel : 5.10.0-0.bpo.8-amd64 TCP CC : bbr Virtualization : KVM Organization : AS59253 Leaseweb Asia Pacific pte. ltd. Location : Singapore / SG Region : Singapore ---------------------------------------------------------------------- I/O Speed(1st run) : 496 MB/s I/O Speed(2nd run) : 638 MB/s I/O Speed(3rd run) : 569 MB/s Average I/O speed : 567.7 MB/s ---------------------------------------------------------------------- Node Name Upload Speed Download Speed Latency Speedtest.net 6436.69 Mbps 4416.01 Mbps 0.84 ms Shanghai CT 39.41 Mbps 1313.68 Mbps 186.13 ms Shanghai CU 634.43 Mbps 1110.41 Mbps 108.23 ms Guangzhou CT 25.81 Mbps 24.31 Mbps 380.91 ms Guangzhou CU 593.46 Mbps 1289.95 Mbps 131.77 ms Hongkong CN 2155.11 Mbps 2923.52 Mbps 37.50 ms Tokyo JP 648.20 Mbps 1330.70 Mbps 70.18 ms ----------------------------------------------------------------------
Thanked by (1)bdl
BF 2021 >> Pre BF 2021
10gbps is a plus tho !
Good luck with xfer
And on that count…
$7 !!
interested. but that network speed though.
refer to bench.sh, doing well above 2G in asia as its in Singapore
https://mirror.sin11.sg.leaseweb.net/speedtest/1000mb.bin
You can test speed here @Sanjue007
It is leaseweb Singapore
Bench.monster for India and Asia
Network only. Diff vps, same DC
https://talk.lowendspirit.com/discussion/comment/69754/#Comment_69754
I'm sorry, but I can't see how much you are asking for this.
Should be around 50/12*10
Using BODMAS?
edited to include cost of remaining period
Does GC allow custom .iso?
i dont think so, but its possible to follow below guide if netboot.xyz works for you as it did for me:
https://lowendspirit.com/tip-install-os-via-netboot-xyz-without-iso-support/
still available before i post on ogf
Crap (bad for OP that it’s not gone)
Tempting
gone
