I think he's saying he enabled it. He likely just needs to Shutdown the box and Startup the box. IIRC it doesn't activate until that happens.
Edit: By which I mean literally use the Stop VPS button then the Start VPS button.
@vict0r said:
Maybe, but after struggling for a while with this, I gave up and asked here and now it's working. So problem solved.
will you now buy us drinks?
Yeah, see you at the pub.
I still had to check "Enable tun/tap" in control panel although it seemed like tun/tap was enabled on the vps when it was not (enabled in the control panel. Seems a little buggy.
Okay, I have got a vpn up and running, sort of. It's very slow and I have used one of those location websites to find out where I'm "located". Don't fall off your chair, the oval office was not exactly what I had in mind.
Well, at least I will be troubleshooting the lack of speed tomorrow.
stop & start the vps*
we have an article on this too https://my.webhorizon.in/plugin/support_manager/knowledgebase/view/7/how-to-enable-tun-tap-on-my-vps/2/
Thanks. It was/is enabled.
I have got it working. Now "Enable Tun/Tap" is unchecked in control panel, but is enabled on the vps. That's a little confusing.
It seems the feature breaks when reinstalling the vps with the option checked.
Oops, got distracted and forgot to refresh my screen. Abdullah already clarified.
Sleep well.
