Free Linux remote control software?
bikegremlinbikegremlin ModeratorOG
edited December 2021 in Technical
I'm looking for a way to control one Linux Mint computer from another, remote Linux Mint computer.
Something like DameWare for windows, but free.
It doesn't matter whether the software creates a new login session, or "logs in" to the existing session.
I'm using Windscribe VPN with an option of a static IP address and port forwarding (not sure if that's helpful, or a problem if both computers use the same static IP :) ).
The less command prompt work/learning, the better, but it's not a problem that I'm not willing to overcome if there aren't any GUI alternatives.
Oh, the use case:
I want to be able to use a remote computer for the time-consuming video editing (rendering is the right term?), see when it's over, let it run the next one, while I'm doing some other work far away, on my other computer. :)
And no, because of some minute fiddling needed, any batch processing is not an option (for now).
BikeGremlin I/O
Mostly WordPress ™
