On my servers I usually rely on a combo of Cloudflare (1.1.1.1) + Google (8.8.8.8). I usually add Cloudflare IPv6 as the third option.
For personal usage I rely on AdGuard Home and then Quad9/Cloudflare (in that order) as fallback.
I should probably start using some IPv6 addresses in my resolv.conf as well, but seeing as providers randomly have issues with IPv6 connectivity, it'd probably be picked as a third option.
Just because those are the first IPs that come up in my head when I am asked to enter DNS resolvers. I am trying to get myself to remember 1.1.1.1 as well.
If IPv6 is present on server:
nameserver 2001:4860:4860::8888
nameserver 2001:4860:4860::8844
I'm using these
9.9.9.10
149.112.112.10
2620:fe::10
2620:fe::fe:10
The lowest response time from my location.
8.8.8.8 is double death
8.8.8.8
1.1.1.1
Amadex.com Domainer + IT Supporter | Brbljaona Balkan Chat Website | ICT Jobs Croatia
Using the resolvers of a Swedish VPN-provider. (They have both v4&v6)
46.227.67.134
192.165.9.158
Using these the most
1.1.1.1
8.8.8.8
1.1.1.1) + Google (8.8.8.8). I usually add Cloudflare IPv6 as the third option.For personal usage I rely on AdGuard Home and then Quad9/Cloudflare (in that order) as fallback.
Website: thomassen.sh
Discord: Decicus#0001
Home stuff is 1.1.1.1 over DoH via pihole
...VPS not too fussed...whatever is the default.
Question: what's the point of DoH besides circumventing firewall restrictions, especially if one already have a VPN?
I prefer a local unbound/powerdns, it adds a few ms fore sure but don't wanna use google/cloudflare/others
nameserver 8.8.8.8
nameserver 8.8.4.4
we using
8.8.8.8
208.67.222.222
TemasekTech - AS139859
Building Cloud Technology with Global Network
Official Website - https://www.TemasekTech.com
So… what resolvers are your local dns servers using?
https://clients.mrvm.net
Unbound can (and is generally used to) work as a recursive DNS server, not just forwarding. Probably that?
Same on my side only the other way around first google then 1.1.1.1
I use ours:
I use 1.1.1.1 and 8.8.8.8 in this exact order
"From the diamonds nothing is born, from the manure the flowers are born ..."
F. De Andrè
