an interesting specimen from datapacket.net. All of their VPS have “16 cores”, even the 1gb one. I guess you really have to hope your neighbors are good people
after @lentro mentioned the impact of zfs caching on benchmark numbers, here is an experiment to show this again...
VM is build on a Hetzner dedi with only HDDs, so keep in mind that technically IOps are limited to somewhat around ~180 per second depending on the average access time of that model (aka 1sec/5.5ms). I put three disks in raid-z1 and have ARC limited to 4GB on the host-node, disk image is directly deployed into the zfs pool...
it always bugged me, that the 512k and 1m IOps seemed to low, and watching the load and IO wait on the node it seemed much like the filled ARC cached that needed to be written to the disk at that point kinda blocked the whole process. like what is gained in 4k/64k now is in the way...
so, how about adding a sleep 5 into the fio loop as a 'cooldown period' for ARC?
BAM! finally everything seems to be hitting the ARC cache properly. because yabs prepopulates the test-file before the actual fio runs and I added the delay/cooldown in between, even the 4k now made a bigger jump...
now, what to take away from this?
1) yabs is awesome. the way it is built allows for easily digging into specific things by modifying some test parameters and more important it is very clear from the beginning, what it is actually doing and how so one can put the result into proper context.
thx @Mason ;-)
2) single/quick glance at artificial benchmark numbers can be misleading, if you don't know what's 'under the hood' - the zfs / ARC example is comparable to a hardware raid controller with some memory-cache and there are lots of things one can adjust around that (cachesizes, writeback, writethrough) that will have an influence... however for the tests nothing of that has been changed, but just the timeline for the workload inside the benchmark!
3) it's debatable how to put the numbers into relation to real world workloads. I'd expect for common not too big hosting workloads most stuff to be sitting in FS cache or ARC most of the time and the time zfs will need to actually write to disk nicely be averaged out in most of the cases.
so will ZFS/ARC be beneficial despite the first benchmark run seem rather slow on 512k/1m ? yeah I would say so, 4GB should still be plenty and allow for a lot of frequently accessed data to be kept hot and available.
@chocolateshirt said:
HostHatch 500 GB Stockholm BF Flash Sales
that's a good one mate...should not have hesitated
Yes, it is worth the wait.. only $13.3 / yr for 500 GB.
Micronode X1S Dedicated Server - These should be provisioned sometime next week and will be priced at £5 per month with 8GB EMMC OS disk and 64GB Data disk:
Can someone post a lsblk on hosthatch and servarica? Looking for storage servers but I want to see fio results on "storage disk", not "system ssd disk".
Yes
@Mr_Tom how about a €1/year deal from the beautiful VM specialists?
Team push-ups!
err... no
epik deal
TBH, Epik would never offer such a deal
It was only @cociu, and his love for @Nekki that made this possible. As long as it lasts.
Hosthatch storage after migrated to EPYC
Hosthatch BF2021 Flash — Storage 2TB
Sultan Muda - Amazon Store
IP is from AS209, CenturyLink
Hosthatch storage BF flash sale (Stockholm) @ Ubuntu 20.04
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Jan 9 06:35:33 UTC 2022 Basic System Information: --------------------------------- Processor : AMD EPYC 7551P 32-Core Processor CPU cores : 1 @ 1999.984 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 477.9 MiB Swap : 0.0 KiB Disk : 451.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 2.79 MB/s (699) | 31.32 MB/s (489) Write | 2.81 MB/s (704) | 31.64 MB/s (494) Total | 5.61 MB/s (1.4k) | 62.96 MB/s (983) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 127.79 MB/s (249) | 70.86 MB/s (69) Write | 134.59 MB/s (262) | 75.58 MB/s (73) Total | 262.38 MB/s (511) | 146.45 MB/s (142) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 684 Mbits/sec | 2.83 Gbits/sec Online.net | Paris, FR (10G) | 2.72 Gbits/sec | 2.12 Gbits/sec WorldStream | The Netherlands (10G) | 2.82 Gbits/sec | 1.28 Gbits/sec WebHorizon | Singapore (400M) | 311 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 424 Mbits/sec | 1.01 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 1.01 Gbits/sec | 791 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 463 Mbits/sec | 679 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 170 Mbits/sec | 506 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.Contribute your idling VPS/dedi (link), Android (link) or iOS (link) devices to medical research
Adding swap will probably make GB5 run fine.
standard unmodified yabs:
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.26 MB/s (1.5k) | 39.61 MB/s (618) Write | 6.26 MB/s (1.5k) | 39.84 MB/s (622) Total | 12.53 MB/s (3.1k) | 79.45 MB/s (1.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 125.95 MB/s (246) | 84.62 MB/s (82) Write | 132.64 MB/s (259) | 90.26 MB/s (88) Total | 258.60 MB/s (505) | 174.88 MB/s (170)oh, see the difference in 512k and 64k even... what about 20sec delay then?
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 140.16 MB/s (35.0k) | 867.90 MB/s (13.5k) Write | 140.53 MB/s (35.1k) | 872.47 MB/s (13.6k) Total | 280.70 MB/s (70.1k) | 1.74 GB/s (27.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 990.24 MB/s (1.9k) | 972.01 MB/s (949) Write | 1.04 GB/s (2.0k) | 1.03 GB/s (1.0k) Total | 2.03 GB/s (3.9k) | 2.00 GB/s (1.9k)BAM! finally everything seems to be hitting the ARC cache properly. because yabs prepopulates the test-file before the actual fio runs and I added the delay/cooldown in between, even the 4k now made a bigger jump...
thx @Mason ;-)
Thanks! ^^
Since I can't edit https://talk.lowendspirit.com/discussion/comment/79267/#Comment_79267 anymore:
https://browser.geekbench.com/v5/cpu/12072017 TL;DR single: 545, multi: 558
just post a new one anytime you like mate
choco@sto-01:~$ curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Jan 9 19:08:49 WIB 2022 Basic System Information: --------------------------------- Processor : AMD EPYC 7551P 32-Core Processor CPU cores : 1 @ 1999.984 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 473.1 MiB Swap : 510.0 MiB Disk : 456.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 3.31 MB/s (827) | 32.08 MB/s (501) Write | 3.34 MB/s (836) | 32.41 MB/s (506) Total | 6.65 MB/s (1.6k) | 64.49 MB/s (1.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 121.39 MB/s (237) | 170.83 MB/s (166) Write | 127.84 MB/s (249) | 182.21 MB/s (177) Total | 249.24 MB/s (486) | 353.05 MB/s (343) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 765 Mbits/sec | 3.43 Gbits/sec Online.net | Paris, FR (10G) | 2.50 Gbits/sec | 2.31 Gbits/sec WorldStream | The Netherlands (10G) | 2.62 Gbits/sec | 936 Mbits/sec WebHorizon | Singapore (400M) | 23.2 Mbits/sec | 38.7 Mbits/sec Clouvider | NYC, NY, US (10G) | 368 Mbits/sec | 1.13 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 969 Mbits/sec | 788 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 477 Mbits/sec | 666 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 182 Mbits/sec | 502 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 442 Multi Core | 429 Full Test | https://browser.geekbench.com/v5/cpu/12073404⭕ A simple uptime dashboard using UptimeRobot API https://upy.duo.ovh
15€/y 512MB NVMe Ryzen W24
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Jan 9 13:29:26 EST 2022 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 480.1 MiB Swap : 511.0 MiB Disk : 6.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 330.03 MB/s (82.5k) | 1.93 GB/s (30.2k) Write | 330.90 MB/s (82.7k) | 1.94 GB/s (30.3k) Total | 660.93 MB/s (165.2k) | 3.87 GB/s (60.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.71 GB/s (3.3k) | 1.77 GB/s (1.7k) Write | 1.80 GB/s (3.5k) | 1.89 GB/s (1.8k) Total | 3.52 GB/s (6.8k) | 3.66 GB/s (3.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 866 Mbits/sec | 269 Mbits/sec Online.net | Paris, FR (10G) | 862 Mbits/sec | 371 Mbits/sec WorldStream | The Netherlands (10G) | 853 Mbits/sec | 130 Mbits/sec WebHorizon | Singapore (400M) | 269 Mbits/sec | 277 Mbits/sec Clouvider | NYC, NY, US (10G) | 989 Mbits/sec | 956 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 971 Mbits/sec | 942 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 863 Mbits/sec | 853 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 705 Mbits/sec | 286 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1431 Multi Core | 1325 Full Test | https://browser.geekbench.com/v5/cpu/12079373Free NAT KVM | Free NAT LXC
Is this the 10x10x10? What location is this?
Team push-ups!
NY just got migrated
Alphavps giveaway
epyc 2GB
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 10 Jan 12:41:18 GMT 2022 Basic System Information: --------------------------------- Processor : Intel(R) Atom(TM) x5-Z8350 CPU @ 1.44GHz CPU cores : 4 @ 974.214 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 976.0 MiB Disk : 6.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 3.19 MB/s (798) | 5.26 MB/s (82) Write | 3.21 MB/s (803) | 5.51 MB/s (86) Total | 6.40 MB/s (1.6k) | 10.77 MB/s (168) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 5.53 MB/s (10) | 6.87 MB/s (6) Write | 6.19 MB/s (12) | 7.26 MB/s (7) Total | 11.72 MB/s (22) | 14.14 MB/s (13) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 206 Multi Core | 643wget -qO- yabs.sh | bash -s -- -i Tuesday 11 January 2022 06:54:38 AM IST Basic System Information: --------------------------------- Processor : AMD Ryzen 5 5600U with Radeon Graphics CPU cores : 12 @ 2300.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 6.7 GiB Swap : 0.0 KiB Disk : 138.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 475.78 MB/s (118.9k) | 619.38 MB/s (9.6k) Write | 477.03 MB/s (119.2k) | 622.64 MB/s (9.7k) Total | 952.81 MB/s (238.2k) | 1.24 GB/s (19.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 780.32 MB/s (1.5k) | 911.75 MB/s (890) Write | 821.78 MB/s (1.6k) | 972.47 MB/s (949) Total | 1.60 GB/s (3.1k) | 1.88 GB/s (1.8k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1161 Multi Core | 4065 Full Test | https://browser.geekbench.com/v5/cpu/12098952Hm. I expected some more fireworks given the fine specs, but maybe more RAM and disk might change the results.
Nice new laptop you have @vyas
(stockholm)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 12 10:44:04 EST 2022 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2667 0 @ 2.90GHz CPU cores : 2 @ 3260.198 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.0 GiB Swap : 1.0 GiB Disk : 39.2 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 2.11 MB/s (529) | 21.64 MB/s (338) Write | 2.13 MB/s (534) | 22.17 MB/s (346) Total | 4.25 MB/s (1.0k) | 43.81 MB/s (684) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 37.95 MB/s (74) | 74.91 MB/s (73) Write | 39.99 MB/s (78) | 79.90 MB/s (78) Total | 77.94 MB/s (152) | 154.82 MB/s (151) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 858 Mbits/sec | 845 Mbits/sec Online.net | Paris, FR (10G) | 865 Mbits/sec | 849 Mbits/sec WorldStream | The Netherlands (10G) | 848 Mbits/sec | 829 Mbits/sec WebHorizon | Singapore (400M) | 280 Mbits/sec | 307 Mbits/sec Clouvider | NYC, NY, US (10G) | 903 Mbits/sec | 898 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 889 Mbits/sec | 866 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 903 Mbits/sec | 889 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 809 Mbits/sec | 749 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 680 Multi Core | 1282 Full Test | https://browser.geekbench.com/v5/cpu/12131910sullivanshosting LEB ovz
$2
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Jan 12 10:53:10 EST 2022 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2660 v2 @ 2.20GHz CPU cores : 2 @ 2199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 3.7 GiB Swap : 1024.0 MiB Disk : 58.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 56.13 MB/s (14.0k) | 610.70 MB/s (9.5k) Write | 56.24 MB/s (14.0k) | 613.91 MB/s (9.5k) Total | 112.37 MB/s (28.0k) | 1.22 GB/s (19.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.26 GB/s (2.4k) | 1.33 GB/s (1.3k) Write | 1.32 GB/s (2.5k) | 1.42 GB/s (1.3k) Total | 2.58 GB/s (5.0k) | 2.76 GB/s (2.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 887 Mbits/sec | 136 Mbits/sec Online.net | Paris, FR (10G) | 863 Mbits/sec | 113 Mbits/sec WorldStream | The Netherlands (10G) | busy | 158 Mbits/sec WebHorizon | Singapore (400M) | 185 Mbits/sec | 159 Mbits/sec Clouvider | NYC, NY, US (10G) | 939 Mbits/sec | 391 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 897 Mbits/sec | 169 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 909 Mbits/sec | 148 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 854 Mbits/sec | 105 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 488 Multi Core | 788 Full Test | https://browser.geekbench.com/v5/cpu/12132012cheapwindowsvps unmetered bw 4.50
Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 32 @ 3400.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 125.8 GiB Swap : 0.0 KiB Disk : 7.0 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 939.18 MB/s (234.7k) | 2.30 GB/s (35.9k) Write | 941.66 MB/s (235.4k) | 2.31 GB/s (36.1k) Total | 1.88 GB/s (470.2k) | 4.61 GB/s (72.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.41 GB/s (4.7k) | 2.50 GB/s (2.4k) Write | 2.54 GB/s (4.9k) | 2.67 GB/s (2.6k) Total | 4.95 GB/s (9.6k) | 5.18 GB/s (5.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 939 Mbits/sec | 936 Mbits/sec Online.net | Paris, FR (10G) | 944 Mbits/sec | 945 Mbits/sec Clouvider | NYC, NY, US (10G) | 812 Mbits/sec | 588 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 926 Mbits/sec | 930 Mbits/sec Online.net | Paris, FR (10G) | 930 Mbits/sec | 932 Mbits/sec Clouvider | NYC, NY, US (10G) | 886 Mbits/sec | 541 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7595 Multi Core | 67289 Full Test | https://browser.geekbench.com/v4/cpu/16462370 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1742 Multi Core | 15468 Full Test | https://browser.geekbench.com/v5/cpu/12138187Noice test result... Bravoo!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-28 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 12 Jan 2022 08:36:43 PM PST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU X5570 @ 2.93GHz CPU cores : 8 @ 1788.777 MHz AES-NI : :x: Disabled VM-x/AMD-V : :heavy_check_mark: Enabled RAM : 19.5 GiB Swap : 976.0 MiB Disk : 1.8 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 520.00 KB/s (130) | 7.17 MB/s (112) Write | 547.00 KB/s (136) | 7.54 MB/s (117) Total | 1.06 MB/s (266) | 14.72 MB/s (229) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 24.56 MB/s (47) | 33.54 MB/s (32) Write | 25.77 MB/s (50) | 36.24 MB/s (35) Total | 50.33 MB/s (97) | 69.78 MB/s (67) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 73.4 Mbits/sec | 70.3 Mbits/sec Online.net | Paris, FR (10G) | 62.9 Mbits/sec | 65.2 Mbits/sec WorldStream | The Netherlands (10G) | 60.2 Mbits/sec | 67.7 Mbits/sec WebHorizon | Singapore (400M) | 59.9 Mbits/sec | 64.6 Mbits/sec Clouvider | NYC, NY, US (10G) | 71.8 Mbits/sec | 72.3 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 74.8 Mbits/sec | 76.2 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 63.5 Mbits/sec | 66.2 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 65.0 Mbits/sec | 70.6 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 565 Multi Core | 2365 Full Test | https://browser.geekbench.com/v5/cpu/12142174
