n8n - Workflow Automation Tool
n8n is an extendable workflow automation tool. With a fair-code distribution model, n8n will always have visible source code, be available to self-host, and allow you to add your own custom functions, logic and apps. n8n's node-based approach makes it highly versatile, enabling you to connect anything to everything.
Just found this - looks really cool. Anyone using it?
Thanked by (1)ehab
Used Node Red (Javascript) for a while, which n8n is sorta based on
There is also Zapier (paid I think) or Huginn (Python).
I've switched to a blend of python / CI and docker though. Easier to just do python than learn a new tool tbh
