@sonic said: Is Contabo uptime high? Should I use it in production?
This is LES, our production services are supposed to be down a lot .
I think you have mistaken LES and LEB
I would say that the majority of offers here has a high uptime (no statistics has been gathered, obly a gut feeling)
Very shitty disk performance, cpu looks like it's oversold and in-use, and the network is hard capped at 200mbit down, and none of the iperf tests went above 80mbit/s up.
@teamacc said:
Bought one, ran a YABS, cancelled it again.
can you please paste your Yabs if it still possible? Thanks in advance
@teamacc said: the network is hard capped at 200mbit down
Depends on which VPS you get. VPS S is 200Mbps, VPS M is 400Mbps, VPS L is 600Mbps, and VPS XL is 1Gbps. They're pretty clear about it on the order page.
200 Mbps isn't ideal but it's still better than Kimsufi's 100Mbps
Look at that YABS thing, i only got 60ish mbit/s upload compared to other people basically maxxing their 200mbit available bw.
Like with other providers, it's shared bandwidth, not dedicated, so it's not expected to be able to max it all the time.
@ehab said: @Amadex so a cancel button gives that "At end of billing period option" ? or must be some process?
Minimum cancellation notice:
None (pre-paid) or 4 weeks (post-paid)
So, just let it expire if you don't need it.
Read a lot about Contabe but I haven't give them a try.
Where can you choose between prepaid and post-paid with Contabo? When I go to their VPS page to order it says minimum term is 1 month and cancellation needs to happen 4 weeks in advance.
You get what you paid for. So the network cap is there, and when you order you an see it's capped at 200 mbit
As for disk, you can get higher speeds on 1M (via a ticket), but IOPS is limited. And as for the CPU, what do you expect from 5 eur p/m (btw you can ask to get switched to another node with a lower steal. I've used them for like 7 months, and ngl they've been rock solid in those times for the price and stuff they offer.
https://clients.mrvm.net
Ah right, Contabo was one of those LET services. But people are asking about it here. They will get about what they should expect.
There are already two yabs for this product posted here? Both were numerically similar and both were unimpressive.
It's still free today 🤔
Contabo's SSD VPSes tend to be pretty slow. I used one of their NVMe VPSes for a few months and it was pretty decent though.
Netcup gives a better product for same price on their promos.
Amadex.com Domainer + IT Supporter | Brbljaona Balkan Chat Website | ICT Jobs Croatia
I've requested a refund, CPU performance is even worse than it was.
Signature currently under construction
Sorry for the inconvenience
