Their network has some of the lowest ping I've seen to my location
From what it looks like, all of their HDD's are kept separately and they partition each HDD out individually. So no RAID or redundancy, but that's fine.
5120MB RAM
1024MB SWAP
55GB SSD RAID-10 SSD
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
Phoenix, AZ Location
SolusVM Control Panel
No refund/money back on this plan Note
5120MB RAM
1024MB SWAP
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
@Abdullah: Thank you for testing the same machine with different operating systems! m_ _m
I'm assuming you didn't tweak any of these and were just running YABS on a fresh install?
Any thoughts on why Ubuntu might be having ~30% lower IOPS than Alma or Rocky with block sizes other than 4k? In my amateur eyes, one would expect Linux 5 to perform better than Linux 4, unless it's something else than the kernel at fault here..?
greencloudvps 5555 packages
Coventry
NY
MU
RO
TX
GA
CO
Whatbox.ca 2TB HDD $15/month USA Shared
Greencloudvps 5555 deal
5120MB RAM
1024MB SWAP
5 cores CPU
1 IPv4
/112 IPv6
5TB Bandwidth
1Gbps Port
Linux OS
$55 for 2 years WOWWWWWW
you got AZ 5555 vps finally, congrats
Hetzner Auction:
BillingServ - Easy, simple, and hassle-free online invoicing solution. Contact us today.
BaseServ Certified to ISO/IEC 27001:2013
WorldStream:
how much?
I'm paying around $150 $170 for that machien.
something
€38.65 it's a quick little machine.
wholesaleinternet
was supposed to be 100mbit unmetered but i won the lottery
racknerd giveaway
that disk speed
It’s a dinosaur
Nexril 12$/year
NanoKVM Netherlands new Node
Sultan Muda - Amazon Store
🇩🇪 myLoc / Webtropia DUS vServer Linux S KVM
Re-Run YABS - Virmach Amsterdam and New Jersey
Amsterdam
Virmach - NJ
greencloudvps 5555 Coventry
rebench after fixing ddos / abusers
greencloudvps
SG DC1
rebench with IPv6
best box ever due to RAID10
Benchmark from the Last Russian VPS I likely will purchase for now.
Chelyabinsk, 210RUB, why? RETN!!!!!!!!
AX101 Almalinux 8.5 kernel 4.18
AX101 RockyLinux 8.5 kernel 4.18
AX101 Ubuntu 20.04 kernel 5.11
G-Core Labs Poland, 238RUB, RETN!!!!!!!!!!!!!!!!!
How much for this server?
238RUB for the current Rate 1.90€
