123578
  • edited December 2021
    Here's my token: 1183e622f9cee9336dac8d1265e0b696eebf708d
    Justification: learning BGP by participating in the DN42 network.
    Deployed.
    Thanked by (1)terrorgen
    deleted
  • NeoonNeoon OG
    Regarding the issue that has been Reported that VM's wont start.
    This is related to an ISO cleanup, when you still have an old iso mounted, you will run into this issue.
    I unmounted all ISO's on every VM, so this issue should be fixed.
    Thanked by (1)Ganonk
  • How does haproxy work in NanoKVM?
    I have a domain that resolves to the IP my KVM is part of, configured haproxy via the web portal and now what?
    Do I just run a web server in my KVM at port 80? What if I want to use another port?
    SNI, its like magic
    Just setup a nginx and request a tls certificate from lets encrypt
    Yes and 443, its NAT seriously?
  • @Neoon said:
    SNI, its like magic
    yes, working fine for me. very nice <3
    Thanked by (1)nyamenk
  • NeoonNeoon OG
    edited January 2022
    Downside is, It won't work with Encrypted NSI with TLS 1.3, since HAProxy can't read anymore where to forward the encrypted packages.
  • hmm I started
    sudo python -m http.server 80
    on my NanoKVM
    then on my browser, enter the address I set up.
    I got a "Route not found" error.
  • NeoonNeoon OG
    edited January 2022
    @terrorgen said:
    hmm I started
    on my NanoKVM
    Its routed to your VM, plus the timeout takes a few seconds, which indicates your webserver is not replying to the request.
    Firewall?
    Keep in mind changes for HAProxy take up 1 hour.
  • @Neoon said:
    @terrorgen said:
    hmm I started
    on my NanoKVM
    Firewall?
    HAProxy works now. it's indeed firewall... thought I have already opened the right ports!
  • NeoonNeoon OG
    edited January 2022
    Pre-Announcement
    NL will get upgraded and switched to a new machine.
    This includes new shiny more powerful CPU, more Storage and we likely can offer 2GB after the upgrade.
    I also gonna take the time, to simplify the network and testing Proxmox 7 with Debiwan Eleven.
    When the initial setup is done and running, we offer migrations from machine to machine, with a window of a few weeks, so everything should have enough time to migrate his stuff.
    Thanks @RapToN / https://kts24.com
  • NeoonNeoon OG
    edited March 2022
    Some News.
    • The Website has been updated, simpler design.
    • Upgraded NL Node is up and running, enjoy the better CPU Performance and more Storage
      Which is also our first Proxmox Node running with Bullseye
    • By Default all new VM's will come with 150Mbit as Uplink/Downlink Speed, except Fremont, the Node itself just got 100Mbit, sadly.
      Existing VM's will be upgraded by Request
    If you got any feedback on the new site, lemme know, so far it works pretty neat for mobile too.
  • Token: d55088b096ae177b2804ccae5ccbbc0f6b970438
    Purpose: I want to read data from a WebSocket
    Read the Rules.
  • @Neoon said:
    Some News.
    Sir , =)
  • edited March 2022
    Thanks to nanokvm's server provider.
    I need a small machine with 1 core and 1G that is smooth enough to deploy my server monitoring project. Maybe also deploy a small private VPN.
    Here is my token: 1f12f88a580135b9ccffdda2ca8ab4c3356a8ba7
    Read the rules before applying.
  • edited March 2022
    Well, if I can't deploy monitoring related projects, please ignore my request. I don't have any other needs for the time being.
    I guess it's about the requirements for applying/being eligible, not about monitoring or not ... :innocent:
  • edited March 2022
    I see, I don't have enough posts...
    Not just posts, vpn is not allowed.
  • Not just posts, vpn is not allowed.
    Not public.
    Not public.
    @Neoon private vpns are allowed?
  • Not public.
    Thanked by (1)dosai
  • edited March 2022
    It seems to me that it does not mention whether private vpn is prohibited or not.
  • edited March 2022
    This is my 50th comment and I think it should be enough. . .
  • NanoKVM DE is down since a few hours, however I don't have any information as of right now.
    I will update once I know more.
    Thanked by (4)ehab spiritlhl Mason Ganonk
  • @Neoon
    Sorry to bother you, my request seems to have passed the 4-day review cycle, when will I get a response? My token is 1f12f88a580135b9ccffdda2ca8ab4c3356a8ba7, the purpose of my request is to build a server monitoring platform.
