What count as Number of Processes on cPanel account ?
yokowasisyokowasis Services Provider
edited March 2022 in General
My hosting limit number of processes to 100. My Question is what count as process.
Because I am running code-server, and ps aux only show about 5 process. Meanwhile in the cpanel it shows 70. And that's only after I disable git functionality of vscode.
Thanked by (1)risharde
  • Did you ask the hosting provider? What did they say?
    Take a look at CloudLinux's official documentation about what these LVE Resource Limits mean.
    https://docs.cloudlinux.com/limits/#number-of-processes
  • The screenshot isn't representing what you are saying... I would have naively assumed that 1 process is when for example a single person visits the site and executes php once but that is too simple an answer for all set ups so I am curious to hear what an experienced provider can explain it as.
    Thanked by (1)kkrajk
    https://onddns.com - FREE Dynamic Realtime DNS powered by 10 DDoS protected servers around the world!
  • yokowasisyokowasis Services Provider
    Actually that's entry processes. It means at 1 time, only 20 person can hit at the very same time.
    even the docs is very ambiguous.
    it says
    number of processes and threads within LVE
    Hence why I asked the question, what is count as "process" and how can I see it from terminal. Because my terminal (ps aux and top) only shows about 10 process.
    it says
    Yes sorry, wasn't criticizing what you were saying, only meant the screenshot wasn't showing the numbers you were saying. I agree, what you quoted is confusing and it's a great question that insight is needed for
    it says
    No need for sorry. It's fine. The naming is a bit confusing, you are not the only one confused one for another
  • Hence why I asked the question, what is count as "process" and how can I see it from terminal. Because my terminal (ps aux and top) only shows about 10 process.
    Based on what the docs say number of processes stands for nproc so "nproc" command should show the number of existing processes for you.
    it says
    the support replied, even they mistaken the Number of Process to Entry Process 😂
    Doesn't nproc refer to Number Of Processor ?
    https://man7.org/linux/man-pages/man1/nproc.1.html
    This is what cloudlinux docs say about it:
    Number of processes
    NPROC controls the total number of processes and threads within LVE. Once the limit is reached, no new process can be created (until another one dies). When that happens NPROC counter is incremented. Apache might return 500 or 503 errors in such case.
    Thanked by (1)Aidan
    Number of processes
    yes. but it has nothing to do with nproc command. nproc does a totally different thing.
