[RESOLVED] UFW & Iptables not working in Debian 10 minimal
Man, my dive into Nat VM has not been kind...
one problem fixed another crop up...
Now on fresh debian 10 i cant start ufw
Is it Openvz problem?
not familiar with this module, google says openvz module/lib/modules/3.10.0-957.12.2.vz7.86.2/modules.builtin.bin'
user@mrvm:~$ sudo ufw enable Command may disrupt existing ssh connections. Proceed with operation (y|n)? y ERROR: problem running ufw-init modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/3.10.0-957.12.2.vz7.86.2/modules.builtin.bin' modprobe: FATAL: Module nf_conntrack_ftp not found in directory /lib/modules/3.10.0-957.12.2.vz7.86.2 modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/3.10.0-957.12.2.vz7.86.2/modules.builtin.bin' modprobe: FATAL: Module nf_nat_ftp not found in directory /lib/modules/3.10.0-957.12.2.vz7.86.2 modprobe: ERROR: ../libkmod/libkmod.c:514 lookup_builtin_file() could not open builtin file '/lib/modules/3.10.0-957.12.2.vz7.86.2/modules.builtin.bin' modprobe: FATAL: Module nf_conntrack_netbios_ns not found in directory /lib/modules/3.10.0-957.12.2.vz7.86.2 iptables-restore: line 6 failed iptables-restore: line 22 failed iptables-restore v1.8.2 (nf_tables): Couldn't load match `conntrack':No such file or directory Error occurred at line: 2 Try `iptables-restore -h' or 'iptables-restore --help' for more information. iptables-restore: line 4 failed iptables-restore: line 5 failed iptables-restore: line 21 failed iptables-restore v1.8.2 (nf_tables): unknown option "--dport" Error occurred at line: 19 Try `iptables-restore -h' or 'iptables-restore --help' for more information. iptables-restore: line 10 failed iptables-restore v1.8.2 (nf_tables): unknown option "--dport" Error occurred at line: 21 Try `iptables-restore -h' or 'iptables-restore --help' for more information. iptables-restore v1.8.2 (nf_tables): Chain 'ufw-before-input' does not exist Problem loading ipv6 (skipping) Problem running '/etc/ufw/before.rules' Problem running '/etc/ufw/after.rules' Problem running '/etc/ufw/user.rules'
prior to reinstalling Debian 10, ufw on debian 8 and ubuntu 16.04 works
P.S. im on MRVM SG node, running freshly installed Debian 10
UFW is garbage and you should learn to setup iptables.
@WSS I just need something fast for testing.
i'm very lazy afterall
hahaha.....
Also, iptables (iptables-nft) seems not working too. iptables issue maybe?
iptables-legacy not working too.
i figured it out,
I purge ufw and iptables, then install iptables first then change to iptables-legacy.
after that install ufw.
ufw seems to works only on iptables-legacy.
With the last Debian 10/Buster template, just
Now ufw should work fine
The actual issue here is that iptables is not installed at all as standard in those templates.
I am going to have to make a new template set with it included and distribute them, I think minimal went a bit far.
iptables-legacy? I thought iptables/netfilter was being replaced with something?
nftables is the default in buster, it seems
Ah, so,
iptables-legacy
is just the regular iptables with a tag to identify that it is now considered legacy (nftables being the new) ...Yeah,old scripts, like the openvpn installer script, dont work with nftables, just tested it. need to change to iptables-legacy
I guess it breaks not just UFW, but many of the old scripts that uses iptables.
I have found also that loading the modules on the host node which is el7 based for containers or be able to use nf* makes them incredibly unstable, I am sure it will be fixed over time.
is netfilter set to full for this container ?
vzctl set VMID --netfilter full --save
CrownCloud - Internet Services | Los Angeles, California | Frankfurt, Germany | Amsterdam, The Netherlands
it feels very un-Debian to me... these (breaking of older scripts) should've been caught in testing or unstable and not being released to stable until most of the popular scripts made accommodations to nftables..
The cutover to nftables default is such a pain. Kubernetes also requires reverting to iptables-legacy.
^this.
Quite likely.
Do it with iptables, no matter that you're on OpenVZ.
„Homo homini rattus.“
And after you learn iptables, now you can learn the "new hotness" that is nftables....
Yes, but I think a loincloth is better than no clothes
i guess you did TL;DR.
needed some quick and dirty method. i reinstall the OS on weekly basis to test software and find limitations of NAT VPS (I'm new to nat vps)
Yup
feels like debian to me. I remember sytemd breaks a few things on jessie when it was release, it just takes time to iron out
