Options are rather limited for 5 USD. Other than buying a month of VPS from the big companies e.g. digital ocean, linode , vultr, your best shot would be NAT vps.
There are a few providers offering NAT vps on this forum. The plans that fit your budget are more likely to be out of stock so you'll have to try your luck.
You need port 80, I guess you want to build a website.
If you want to build a website, then finding a suitable web hosting provider will be a better choice.
It's not realistic if you want quality service at such a low price.
I think I need to setup a frp server
Assuming you want to setup HTTP server, there are still ways to setup one with NAT vps, for example http proxy provided by the VPS provider, or cloudflare. As for FTP server, you can use non-standard port for IPv4 or standard port through IPv6.
Can u tough me how to use cloudflare proxy
You can google search and see a bunch of tutorials…
virmach JP. It's rare to see this kind of price in non US, non EU location.
let me see
it is too expensive! justhost is better then it
u hav 40 doller
then u say virmach too expensive
then what u wan
Did you checked this https://lowendspirit.com/discussion/4013/virmach-ryzen-nvme-30-2yr-768mb-40-2yr-1-5gb-50-2yr-2-5gb-70-2yr-4gb-les/ ?
no it is hkd not usd
https://hosting.gullo.me/pricing
Main , ServerStatus , slackvpn <-- openVPN auto install script for Slackware 15
good but it is natvps so.... no
Than!
Unless you are missing a comma, then it makes sense, as in Justhost is the better option.
You're getting worse by the week!
But natvps have not 80port
my English is trying
PacificRack is what you’re looking for
Better than having 40 Zimbabwe doller
@MCTGyt said:
you need to set up a server made of this? https://en.wikipedia.org/wiki/Fibre-reinforced_plastic
I assume it means reverse proxy.
Are you looking for monthly or yearly? You'll need to really dig to find a yearly at that price. Gullo maybe
XR Developer | https://redironlabs.com
You don't want to use justhost.
Plus, because of the embargo, you likely can't even pay them.
Check mzunguhosting.ml, they have very friendly CP offers.
CP == cheap prices
JustHost was always completely unusable even when you could pay them. Don't understand how that isn't common knowledge by now.
I probably still have rubles credit with them from the time I decided to learn the hard way for myself. Hope I don't get sanctions.
... and the word is "you".
你可以Google自己睇下啦
https://techsch.com/tutorials/host-website-ipv6-nat-cloudflare-dns
Why? i buy their at> @MCTGyt said:
i know
i'll try this
