Home Proxmox "server" (aka old Dell XPS) running ZFS w/ 128GB eBay SSD
I also put in 2 x 12TB HDD but apparently one of them is gone so I'll have to RMA it
This is made on a empty node ... had a VPS from you and GB5 rarely passed 900 points, the CPU steal was huge
I was very happy with the performance at start, but that degraded fast:
@Neoon said:
You got 0.3% Steal, for a loaded node that is not bad.
Beside Contabo never seen so much before ... 420 points difference in GB5?
Well, from 4068 down to 2324 on 4 Cores, is quite a hit, my guess, CPU Priority.
You can peak all 4 cores with your Package if the Node has plenty, but since its Loaded, you getting deprioritized.
Higher Packages likely get more priority, but this is just a guess, some providers do that but not all.
Given that you got 0.3% Steal, does not look like the Node is overloaded, just loaded.
VirMach - NYC Metro - $12.48 USD Annually
Vultr Melbourne $6 check the disk speed:
OneProvider - i3-530 - RAM 4G - 2 x 1TB HDD (HW RAID1) - 1Gbps (Fair usage) - 10€/m
GreenCloudVPS after 8 months:
@ReadyDedis OGF (because the LES one are too big for me)
Github
Racknerd after 1 month:
New microLXC NL Node by bakker-it
seems like Hosthatch is fixing storage behind the scenes:
New microLXC Node in Hong Kong
provider ?
catixs.net
YABSE'd HK again, new Install
hostiko.com.ua
UA-PERF-4
DE-4
UA-4
microLXC KVM 1GB Norway
microLXC KVM 1GB Groningen
Long time no Alwyzon YABS in this thread. Let's change that with an Alwyzon Virtual Server M.
By the way, all new orders are now provisioned with 2.5 Gbps ports since start of May:
Single Core | 767
Multi Core | 2324
Full Test | https://browser.geekbench.com/v5/cpu/14644706
is it normal for AMD Ryzen 9 3900X Processor to have 702 single core score?
`1# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## #
Yet-Another-Bench-Script
v2022-05-06
Mon May 23 10:50:10 UTC 2022
Uptime : 0 days, 2 hours, 0 minutes
Processor : AMD Ryzen 9 3900X 12-Core Processor
CPU cores : 1 @ 3792.874 MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 78.7 GiB
Distro : AlmaLinux 8.5 (Arctic Sphynx)
Kernel : 4.18.0-348.20.1.el8_5.x86_64
Read 210.40 MB/s (52.6k) 1.12 GB/s (17.6k)
Write 210.96 MB/s (52.7k) 1.13 GB/s (17.7k)
Total 421.36 MB/s (105.3k) 2.25 GB/s (35.3k)
Read 1.07 GB/s (2.0k) 1.06 GB/s (1.0k)
Write 1.12 GB/s (2.2k) 1.13 GB/s (1.1k)
Total 2.20 GB/s (4.2k) 2.19 GB/s (2.1k)
Clouvider | London, UK (10G) | 849 Mbits/sec | 233 Mbits/sec
Online.net | Paris, FR (10G) | 1.12 Gbits/sec | 572 Mbits/sec
Hybula | The Netherlands (40G) | 1.11 Gbits/sec | 960 Mbits/sec
Clouvider | NYC, NY, US (10G) | 483 Mbits/sec | 59.0 Mbits/sec
Velocity Online | Tallahassee, FL, US (10G) | 1.02 Gbits/sec | 188 Mbits/sec
Clouvider | Los Angeles, CA, US (10G) | 257 Mbits/sec | 47.5 Mbits/sec
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 702
Multi Core | 723
Full Test | https://browser.geekbench.com/v5/cpu/15076790 `
"Scammed"
https://lowendspirit.com/discussion/comment/86514/#Comment_86514
no. slower than an old e5.
Which provider?
buyvm
@Francisco
mrvm 256MB bulgaria
gullo 128MB poland
HDD disk.
