Looking to try any Shared Hosting/Reseller with Plesk WordPress Toolkit
Hey there,
looking to try (not necessarily buy) a shared hosting/reseller that has the Plesk WordPress Toolkit to give it a spin.
Can't say I'll become a (long term) customer but if you have some spare resources for a week or two (if necessary give me a quote), that'd be great
Specs: Enough to install WordPress (obviously) and just try out some things. Basically no expectations/requirements here.
Let me know if you have smth for me
Cheers,
Ympker
I happen to have a Cpanel Account with something called WordPress toolkit. Not the same I guess?
I haven't used Plesk WP Toolkit before (hence the OP), so, unfortunately, I can't say whether the cPanel WP Toolkit has the same features as the Plesk one. There is definitely also a cPanel toolkit: https://cpanel.net/wp-toolkit/
Our high performance plans have WP Toolkit + Plesk: https://cynderhost.com/store/high-performance-hosting
I think we've got a 50% discount code lying around somewhere....
Already found something, but thanks!
Hi,
You may try cheap Shared starter plan at us, https://servzen.com/shared-hosting.html
For WordPress, We are powered by DirectAdmin with Softaculous auto installer.
for reseller plans, https://servzen.com/reseller-hosting.html
Thanks
Servzen.com | Premium Hosting Provider!
Fast, secure and affordable plans | VPS Hosting | Shared Hosting.
Sooo... does your shared hosting plans have the Plesk WordPress Toolkit like the OP is asking for? Couldn't any information about it on your site.
Humble janitor of LES
Proud papa of YABS
Ahh, I just read the "looking to try any shared/reseller" only ...
My mistake.
Thanks, I was thinking the same. Anyway, like mentioned in my post before, I've found a solution for the OP now, so this thread can (technically) be closed
