Weekend deal - VPS LXC 8GB RAM Unlimited 10Gbps - $4/mo. - WebHorizon
Hey! ![]()
We are glad to announce a new lineup of LXC VMs at WebHorizon
These will replace the existing VZ7 servers overtime.
An Introductory Offer to fill-up the free capacity!
Europe LXC Introductory Offer ๐ฅ
50GB NVMe SSD Disk space
4 GB RAM
1 cores Intel(R) Xeon(R) E-2274G CPU
1 x IPv4 dedicated
Unlimited transfer @ 10Gbps port [10Gb/s down 500Mb/s up]
2 x CPU cores, RAM and Disk space on annual commitment.
Limited Stock = only 12 units are allocated for this promo.
F. A. Q.s
We're using unprivileged LXC
Docker is supported default
Fuse & Tun/Tap Supported
Available OS options - Debian 9 , 10 , 11 ; Ubuntu 18, 20, 22 , Almalinux, RockyLinux, Alpine, Devuan
Test IP - 51.195.49.128
Payment Methods - PayPal payments, Cards via Stripe Payments.
Crypto payments (BTC / BCH / XMR / USDT)
We'll be happy to help you if you have any questions. Just send us a support ticket or ask here. ![]()
edit: updated test IP.
so nice offer --- hey @AaronSS still resisting?
Do you have routed IPv6 /48?
hey @Abdullah any 1 year --- limited family offers
@ehab for you, I meant to tag you
i will go for one and test things out
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-05-06 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jun 10 18:17:06 UTC 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : Intel(R) Xeon(R) E-2274G CPU @ 4.00GHz CPU cores : 2 @ 4000.000 MHz AES-NI : โ Enabled VM-x/AMD-V : โ Enabled RAM : 7.8 GiB Swap : 512.0 MiB Disk : 97.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.15.35-1-pve fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 730.51 MB/s (182.6k) | 1.05 GB/s (16.5k) Write | 732.44 MB/s (183.1k) | 1.06 GB/s (16.6k) Total | 1.46 GB/s (365.7k) | 2.12 GB/s (33.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.64 GB/s (5.1k) | 2.74 GB/s (2.6k) Write | 2.78 GB/s (5.4k) | 2.92 GB/s (2.8k) Total | 5.42 GB/s (10.5k) | 5.66 GB/s (5.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 482 Mbits/sec | 8.72 Gbits/sec Online.net | Paris, FR (10G) | 482 Mbits/sec | 3.82 Gbits/sec Hybula | The Netherlands (40G) | 481 Mbits/sec | 8.47 Gbits/sec Clouvider | NYC, NY, US (10G) | 444 Mbits/sec | 2.18 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | busy | busy Clouvider | Los Angeles, CA, US (10G) | 433 Mbits/sec | 1.23 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1051 Multi Core | 1667 Full Test | https://browser.geekbench.com/v5/cpu/15398241I would assume this is the same as "Help me test" machine... so yabs.
No IPv6 on this
Itโs 8GB, right?
However I am pretty sure (just like OGF?) it was 8GB earlier without the asterisk and if you bought it early with monthly they will honor the mistake.
https://lowendtalk.com/discussion/comment/3437336/#Comment_3437336
Hi
This particular offer includes 4GB ram, 50gb Nvme, 1xCPU core if paid monthly.
2x the resources if prepaid annually.
Ah, missed the 2x CPU if annual part!
Yes it was honored
What???
Reboot fixed this. Still weird
suport ISO windows?
Not normal. please let me know if it occurs again or make a ticket.
Hi,
Sorry Windows is not supported on these
Oh and could you possibly enable nested kvm in these?
The virtualization is LXC, so it's not possible.
I made a ticket
sorry it is not possible to provide this passthrough.
We have nesting enabled for docker support if that can work for your use case.
Can I trial test for 48 hours? I've never worked with LXC before
Your current client.
ok. could you try fixing the yabs error? I opened a ticket like you asked
sure.
I forgot your email, can I please have in PM
DM'ed
system does not fully support snapd: cannot mount squashfs image using "squashfs": mount: /tmp/sanity-mountpoint-474755366: mount failed: Operation not permitted.Is it just me or the upload got capped around 40mbps?
it's a shared 500 megabit link between like 30 people. ovbiously it's going to be quite slow.
ddos protection triggered I guess.
@dosai did it improve then?
