You know, me and my wife lived in abject poverty looking back! Some of the happiest times though!
Sat laughing our heads off on a free sofa - we still do the same on overpriced ones.... but with less responsibility 😁
Serious advice, save up for the perfect item - never settle for something not quite right, we've wasted loads that way! Cable every room and still get mesh WiFi!
I can imagine Even with little money, life can be enjoyed. As students we certainly can't spend that much either :P
Sounds like you guys had a great and memorable time back then! Those kinda memories are the best :P
Noted! Better to get the better one straight away (even if saving longer for it) than buying cheap and replace.
Living with a woman often means you face a choice between being right and being happy. Choose wisely.
Everything else falls into the correct place over time.
Wondering whether I should just buy a 20meter LAN cable to connect the second pc in bedroom to the internet. Will I notice a big difference in between a 20m Cat 5e and Cat 8 cable?
@chris said:
"Always buy the best, never settle" - Me to anyone, anytime I get the opportunity 😛
Haha alright I understand the Cat 8 shields a bit better against outward interference than the Cat 5e, so for a long distance of 20 meters that's probably better
@Falzo do you know anything about those fancy cables?
The KISS principle, I see
Thanks for the good wishes, mate!
I sometimes worry that I'm so correct in all I say, that there might be something wrong with me
I can imagine
Thanks for the advice!
Haha alright
no you won't.
Thanks. Then I'll go for the cheaper one
Future proof your entire life 😛
I'd got for cat6 if they have it on hand...likely to be similar price as 5e
7 & 8 tends to be a lot stiffer than 5/6 so is a pain to pull in
Good advice. Thanks!
