Tailscale SSH
Some of you are probably using tailscale, and they introduced a new SSH feature that allows you to work with SSH, set up access control lists, and without needing to add stuff in ~/.ssh/config.
https://tailscale.com/blog/tailscale-ssh/
Personally, I've never used Tailscale, I plan to try it some time in the future though.
What is tailscale? I hear it first time.
Private network via VPN mesh
See also zerotier
Also see https://github.com/tonarino/innernet, it sets up private vpn mesh using your own server, it's open source and built with unix philosophy
Tailscale is what people say to sound smart.
What do you use for VPN?
- I use openvpn and wireguard.
Oh, i use Tailscale.
„Homo homini rattus.“
