It might be a little too late but maybe just edit and mention it in the OP that when posting YABS results, it would be good if members could include details such as the Provider, Plan, Location and Price ✌️
Other details like date of purchase can be included too or just indicate if it's a deal bought on a special occasion.
if you would be so kind to make a format, I'll gladly put it up on OP. gonna remove the manual indexing since its gotten too far behind.
N5105 router with 4x 2.5GbE from aliexpress. I've installed 8GB Crucial DRAM and 480GB WD Green NVMe.
Only just got it and set up proxmox on it, so before even bothering setting up the virtualised pfSense install, I thought I'd set up a quick VM for testing yabs.
@rober7 said: @SpeedyPage still performing good even after a few weeks, usually i had problems with other providers, after 1-2 weeks the performance drops at 50%.
Wrap that in code pls
Signature currently under construction
Sorry for the inconvenience
@ofit said:
Hello @ralf, can you please test wireguard and openvpn performance (speed) on pfsense and openwrt in promox on your new box n5105 please. Thanks
Wireguard is no longer supported on recent versions of pfsense, so I'm going to roll my own linux VM to share a route48.org amongst some other VMs on it. Obviously I won't be in much control of throughput on that, and it feels a bit like abuse for a free service.
I do have a wireguard proxy set up to another VM at OVH which seems to be working well, but not much use for a test as OVH is capped at 100Mbps. But was required as my ISP IP is changing every time I reboot the router, and I need a fixed IP for a corporate whitelisting. Also my home net is capped at 500Mbps too, so that'll be the upper limit. But I'll try out with a temporary wireguard route to another server in Europe or US when I get some time.
I've never used openvpn, and chose wireguard for all my systems as it seemed to be easier and better, so trying that will be really low priority as I'll probably need to be reading many docs for that!
Also openwrt, I'm not sure yet if I'll try it. Originally my plan was to give pfsense a quick test and then move to a linux based solution because I haven't used FreeBSD for about 20 years. However, pfsense worked really well and did everything I wanted off the bat, and I've since spent quite a bit of time setting up the routes as I want them. I may try a side-by-side openwrt test, but TBH as I used NIC pass-through, it depends on whether I can get away with stopping the pfsense VM and re-assigning the same NICs to another VM as long as only one is running at once. If proxmox doesn't let you do that, I'm less keen to change from pfsense as I'm happy with it so far.
Anyway, will let you know when I have some wireguard perf results.
Greencloud EPYCSG-2:
SoYouStart / OVH
Amadex.com Domainer + IT Supporter | Brbljaona Balkan Chat Website | ICT Jobs Croatia
WebHosting24 great and cheap deal in Miami
Main , ServerStatus , slackvpn <-- openVPN auto install script for Slackware 15
Greencloud 4th of July special - $47/2y:
YABs without provider/plan/price
I agree, @LetMeBeSad is a repeat offender too.
ShockHosting SSD-KVM-2GB - NJ US - $29.99/year (4th of July Deal) ⚡
I agree too and it is super annoying. Ban him from posting on this thread
@TheDP that sounds like a good idea
LMBS probably builds servers himself.
Exactly. 90% comes from my personal builds. Plenty of them is located in local DC.
AWS r6g.medium, 30GB gp2 disk, us-west-2. No iperf tests, because AWS bandwidth is expensive
Virmach Ryzen Atlanta 7$/y
Check your PM
10€/y NY WH24
Oracle free, time to do some SYS admin work now and install everything
done, credits to @TheDP
`Basic System Information:
Uptime : 10 days, 22 hours, 35 minutes
Processor : AMD EPYC-Milan Processor
CPU cores : 2 @ 3693.060 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 58.1 GiB
Distro : Ubuntu 22.04 LTS
Kernel : 5.19.0-051900rc3-generic
Clouvider | London, UK (10G) | 784 Mbits/sec | 632 Mbits/sec
Online.net | Paris, FR (10G) | 793 Mbits/sec | 836 Mbits/sec
Clouvider | NYC, NY, US (10G) | 922 Mbits/sec | 881 Mbits/sec
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1375
Multi Core | 2585
Full Test | https://browser.geekbench.com/v5/cpu/15871043
Virmach- AMS (FFxxx?) with Ryzen - after migration.
was from BF 2021. at USD 11/year- maybe I will renew??
crowncloud 12th gen I9 frankfurt , 22$ per month . respectable performance , truly the Ultimate Processing Power
Webhosting24 - 20x22 - Munich DE - €22/year (New Year Special)
deinserverhost root server 17.4 euro
ran geekbench 5 separately
https://browser.geekbench.com/v5/cpu/15886709
