It might be a little too late but maybe just edit and mention it in the OP that when posting YABS results, it would be good if members could include details such as the Provider, Plan, Location and Price ✌️
Other details like date of purchase can be included too or just indicate if it's a deal bought on a special occasion.
if you would be so kind to make a format, I'll gladly put it up on OP. gonna remove the manual indexing since its gotten too far behind.
N5105 router with 4x 2.5GbE from aliexpress. I've installed 8GB Crucial DRAM and 480GB WD Green NVMe.
Only just got it and set up proxmox on it, so before even bothering setting up the virtualised pfSense install, I thought I'd set up a quick VM for testing yabs.
@rober7 said: @SpeedyPage still performing good even after a few weeks, usually i had problems with other providers, after 1-2 weeks the performance drops at 50%.
Wrap that in code pls
Signature currently under construction
Sorry for the inconvenience
@ofit said:
Hello @ralf, can you please test wireguard and openvpn performance (speed) on pfsense and openwrt in promox on your new box n5105 please. Thanks
Wireguard is no longer supported on recent versions of pfsense, so I'm going to roll my own linux VM to share a route48.org amongst some other VMs on it. Obviously I won't be in much control of throughput on that, and it feels a bit like abuse for a free service.
I do have a wireguard proxy set up to another VM at OVH which seems to be working well, but not much use for a test as OVH is capped at 100Mbps. But was required as my ISP IP is changing every time I reboot the router, and I need a fixed IP for a corporate whitelisting. Also my home net is capped at 500Mbps too, so that'll be the upper limit. But I'll try out with a temporary wireguard route to another server in Europe or US when I get some time.
I've never used openvpn, and chose wireguard for all my systems as it seemed to be easier and better, so trying that will be really low priority as I'll probably need to be reading many docs for that!
Also openwrt, I'm not sure yet if I'll try it. Originally my plan was to give pfsense a quick test and then move to a linux based solution because I haven't used FreeBSD for about 20 years. However, pfsense worked really well and did everything I wanted off the bat, and I've since spent quite a bit of time setting up the routes as I want them. I may try a side-by-side openwrt test, but TBH as I used NIC pass-through, it depends on whether I can get away with stopping the pfsense VM and re-assigning the same NICs to another VM as long as only one is running at once. If proxmox doesn't let you do that, I'm less keen to change from pfsense as I'm happy with it so far.
Anyway, will let you know when I have some wireguard perf results.
Greencloud EPYCSG-2:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 04 Jul 2022 06:01:35 AM EDT Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 27 minutes Processor : AMD EPYC 7502P 32-Core Processor CPU cores : 2 @ 2495.312 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.9 GiB Swap : 1024.0 MiB Disk : 33.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 317.86 MB/s (79.4k) | 893.10 MB/s (13.9k) Write | 318.70 MB/s (79.6k) | 897.80 MB/s (14.0k) Total | 636.56 MB/s (159.1k) | 1.79 GB/s (27.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 989.76 MB/s (1.9k) | 971.55 MB/s (948) Write | 1.04 GB/s (2.0k) | 1.03 GB/s (1.0k) Total | 2.03 GB/s (3.9k) | 2.00 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 887 Mbits/sec | 1.05 Gbits/sec Online.net | Paris, FR (10G) | 1.42 Gbits/sec | 1.15 Gbits/sec Hybula | The Netherlands (40G) | 996 Mbits/sec | 1.04 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 1.15 Gbits/sec | 922 Mbits/sec Clouvider | NYC, NY, US (10G) | 593 Mbits/sec | 736 Mbits/sec Clouvider | Dallas, TX, US (10G) | 478 Mbits/sec | 509 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.03 Gbits/sec | 1.07 Gbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.03 Gbits/sec | 1.02 Gbits/sec Online.net | Paris, FR (10G) | 848 Mbits/sec | 696 Mbits/sec Hybula | The Netherlands (40G) | 1.02 Gbits/sec | 1.07 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 1.13 Gbits/sec | 932 Mbits/sec Clouvider | NYC, NY, US (10G) | 696 Mbits/sec | 739 Mbits/sec Clouvider | Dallas, TX, US (10G) | 736 Mbits/sec | 863 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 886 Mbits/sec | 1.05 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 958 Multi Core | 1856 Full Test | https://browser.geekbench.com/v5/cpu/15815962SoYouStart / OVH
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 8 minutes Processor : Intel(R) Xeon(R) CPU E3-1245 v5 @ 3.50GHz CPU cores : 8 @ 3500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 30.9 GiB Swap : 1024.0 MiB Disk : 446.3 GiB Distro : AlmaLinux 8.6 (Sky Tiger) Kernel : 4.18.0-372.13.1.el8_6.x86_64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 171.62 MB/s (42.9k) | 233.39 MB/s (3.6k) Write | 172.08 MB/s (43.0k) | 234.61 MB/s (3.6k) Total | 343.70 MB/s (85.9k) | 468.00 MB/s (7.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 210.04 MB/s (410) | 209.34 MB/s (204) Write | 221.20 MB/s (432) | 223.28 MB/s (218) Total | 431.24 MB/s (842) | 432.62 MB/s (422) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 248 Mbits/sec | 941 Mbits/sec Online.net | Paris, FR (10G) | 248 Mbits/sec | 941 Mbits/sec Hybula | The Netherlands (40G) | 248 Mbits/sec | 940 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 220 Mbits/sec | 739 Mbits/sec Clouvider | NYC, NY, US (10G) | 234 Mbits/sec | 896 Mbits/sec Clouvider | Dallas, TX, US (10G) | 67.0 Mbits/sec | 485 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 218 Mbits/sec | 837 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 244 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 244 Mbits/sec | 928 Mbits/sec Hybula | The Netherlands (40G) | 244 Mbits/sec | 926 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 216 Mbits/sec | 799 Mbits/sec Clouvider | NYC, NY, US (10G) | 220 Mbits/sec | 883 Mbits/sec Clouvider | Dallas, TX, US (10G) | 227 Mbits/sec | 855 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 222 Mbits/sec | 844 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1140 Multi Core | 4307Amadex.com Domainer + IT Supporter | Brbljaona Balkan Chat Website | ICT Jobs Croatia
WebHosting24 great and cheap deal in Miami
Mon 04 Jul 2022 12:26:09 PM EDT Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.4 MiB Swap : 976.0 MiB Disk : 8.8 GiB Uptime : 0 days, 0 hours, 43 minutes. Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 321.32 MB/s (80.3k) | 1.87 GB/s (29.3k) Write | 322.17 MB/s (80.5k) | 1.88 GB/s (29.4k) Total | 643.49 MB/s (160.8k) | 3.76 GB/s (58.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.81 GB/s (3.5k) | 1.62 GB/s (1.5k) Write | 1.91 GB/s (3.7k) | 1.73 GB/s (1.6k) Total | 3.73 GB/s (7.2k) | 3.35 GB/s (3.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 199 Mbits/sec | 218 Mbits/sec Online.net | Paris, FR (10G) | 353 Mbits/sec | 553 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 265 Mbits/sec | 350 Mbits/sec Clouvider | NYC, NY, US (10G) | 608 Mbits/sec | 946 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | busy | busy Clouvider | Los Angeles, CA, US (10G) | 295 Mbits/sec | 747 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 386 Mbits/sec | 720 Mbits/sec Online.net | Paris, FR (10G) | 171 Mbits/sec | 246 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | 261 Mbits/sec | 398 Mbits/sec Clouvider | NYC, NY, US (10G) | 779 Mbits/sec | 927 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 348 Mbits/sec | 599 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1463 Multi Core | 1475 Full Test | https://browser.geekbench.com/v5/cpu/15822110Main , ServerStatus , slackvpn <-- openVPN auto install script for Slackware 15
Greencloud 4th of July special - $47/2y:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # --:-- --:--:-- 107k # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Jul 4 03:35:08 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 10 minutes Processor : Intel(R) Xeon(R) CPU E5-2698 v4 @ 2.20GHz CPU cores : 4 @ 2199.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.2 GiB Swap : 1024.0 MiB Disk : 45.2 GiB Distro : CentOS Linux 7 (Core) Kernel : 3.10.0-862.2.3.el7.x86_64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 251.33 MB/s (62.8k) | 3.20 GB/s (50.0k) Write | 252.00 MB/s (63.0k) | 3.21 GB/s (50.3k) Total | 503.33 MB/s (125.8k) | 6.42 GB/s (100.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.60 GB/s (8.9k) | 4.16 GB/s (4.0k) Write | 4.84 GB/s (9.4k) | 4.44 GB/s (4.3k) Total | 9.44 GB/s (18.4k) | 8.61 GB/s (8.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.52 Gbits/sec | 1.86 Gbits/sec Online.net | Paris, FR (10G) | 2.21 Gbits/sec | 1.80 Gbits/sec Hybula | The Netherlands (40G) | 1.62 Gbits/sec | 1.69 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 635 Mbits/sec | 819 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.70 Gbits/sec | 3.91 Gbits/sec Clouvider | Dallas, TX, US (10G) | 563 Mbits/sec | 1.29 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.64 Gbits/sec | 3.36 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 684 Multi Core | 2498 Full Test | https://browser.geekbench.com/v5/cpu/15813864# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 05 Jul 2022 09:25:20 AM UTC Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 7 minutes Processor : Intel(R) Xeon(R) CPU E3-1275 v6 @ 3.80GHz CPU cores : 8 @ 3800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.6 GiB Swap : 0.0 KiB Disk : 937.1 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.18.8-xanmod1 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 818.44 MB/s (204.6k) | 1.19 GB/s (18.7k) Write | 820.60 MB/s (205.1k) | 1.20 GB/s (18.8k) Total | 1.63 GB/s (409.7k) | 2.40 GB/s (37.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.39 GB/s (2.7k) | 1.46 GB/s (1.4k) Write | 1.46 GB/s (2.8k) | 1.55 GB/s (1.5k) Total | 2.85 GB/s (5.5k) | 3.01 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 793 Mbits/sec | 817 Mbits/sec Online.net | Paris, FR (10G) | 791 Mbits/sec | 834 Mbits/sec Hybula | The Netherlands (40G) | 793 Mbits/sec | 930 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 775 Mbits/sec | 532 Mbits/sec Clouvider | NYC, NY, US (10G) | 750 Mbits/sec | 374 Mbits/sec Clouvider | Dallas, TX, US (10G) | 638 Mbits/sec | 103 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 736 Mbits/sec | 235 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 789 Mbits/sec | 906 Mbits/sec Online.net | Paris, FR (10G) | 787 Mbits/sec | busy Hybula | The Netherlands (40G) | 793 Mbits/sec | 920 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 772 Mbits/sec | 734 Mbits/sec Clouvider | NYC, NY, US (10G) | 769 Mbits/sec | 436 Mbits/sec Clouvider | Dallas, TX, US (10G) | 724 Mbits/sec | 293 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 711 Mbits/sec | 307 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5575 Multi Core | 19039 Full Test | https://browser.geekbench.com/v4/cpu/16580240 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1178 Multi Core | 4689 Full Test | https://browser.geekbench.com/v5/cpu/15833453YABs without provider/plan/price
I agree, @LetMeBeSad is a repeat offender too.
ShockHosting SSD-KVM-2GB - NJ US - $29.99/year (4th of July Deal) ⚡
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 04 Jul 2022 04:28:07 PM EDT Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 6 minutes Processor : Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz CPU cores : 1 @ 3199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 975.0 MiB Disk : 28.4 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 264.91 MB/s (66.2k) | 3.46 GB/s (54.1k) Write | 265.61 MB/s (66.4k) | 3.48 GB/s (54.4k) Total | 530.52 MB/s (132.6k) | 6.95 GB/s (108.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 9.32 GB/s (18.2k) | 7.95 GB/s (7.7k) Write | 9.82 GB/s (19.1k) | 8.48 GB/s (8.2k) Total | 19.15 GB/s (37.4k) | 16.44 GB/s (16.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 828 Mbits/sec | 469 Mbits/sec Online.net | Paris, FR (10G) | 882 Mbits/sec | 262 Mbits/sec Hybula | The Netherlands (40G) | 882 Mbits/sec | 823 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 577 Mbits/sec | 307 Mbits/sec Clouvider | NYC, NY, US (10G) | 940 Mbits/sec | 939 Mbits/sec Clouvider | Dallas, TX, US (10G) | 746 Mbits/sec | 155 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 796 Mbits/sec | 619 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 705 Mbits/sec | 435 Mbits/sec Online.net | Paris, FR (10G) | 823 Mbits/sec | 431 Mbits/sec Hybula | The Netherlands (40G) | 714 Mbits/sec | 725 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 676 Mbits/sec | 410 Mbits/sec Clouvider | NYC, NY, US (10G) | 926 Mbits/sec | 926 Mbits/sec Clouvider | Dallas, TX, US (10G) | 904 Mbits/sec | 775 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 885 Mbits/sec | 632 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1036 Multi Core | 1005 Full Test | https://browser.geekbench.com/v5/cpu/15825267For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars!
I agree too and it is super annoying. Ban him from posting on this thread
@TheDP that sounds like a good idea
LMBS probably builds servers himself.
Exactly. 90% comes from my personal builds. Plenty of them is located in local DC.
AWS r6g.medium, 30GB gp2 disk, us-west-2. No iperf tests, because AWS bandwidth is expensive
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 5 15:16:05 UTC 2022 ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 33 minutes Processor : Neoverse-N1 CPU cores : 1 @ ??? MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.7 GiB Swap : 0.0 KiB Disk : 29.4 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-cloud-arm64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.20 MB/s (1.5k) | 73.91 MB/s (1.1k) Write | 6.19 MB/s (1.5k) | 76.11 MB/s (1.1k) Total | 12.39 MB/s (3.0k) | 150.03 MB/s (2.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 64.38 MB/s (125) | 63.70 MB/s (62) Write | 69.89 MB/s (136) | 71.07 MB/s (69) Total | 134.27 MB/s (261) | 134.77 MB/s (131) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 741 Multi Core | 743 Full Test | https://browser.geekbench.com/v5/cpu/15839087Virmach Ryzen Atlanta 7$/y
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 5 14:06:34 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3693.028 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 983.4 MiB Swap : 256.0 MiB Disk : 34.2 GiB Distro : Debian GNU/Linux 10 (buster) Kernel : 5.10.65-rt fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 389.00 MB/s (97.2k) | 268.02 MB/s (4.1k) Write | 390.02 MB/s (97.5k) | 269.43 MB/s (4.2k) Total | 779.03 MB/s (194.7k) | 537.45 MB/s (8.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.05 GB/s (2.0k) | 1.53 GB/s (1.4k) Write | 1.10 GB/s (2.1k) | 1.63 GB/s (1.5k) Total | 2.15 GB/s (4.2k) | 3.17 GB/s (3.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 761 Mbits/sec | 321 Mbits/sec Online.net | Paris, FR (10G) | 821 Mbits/sec | 306 Mbits/sec Hybula | The Netherlands (40G) | 811 Mbits/sec | 786 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 639 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 931 Mbits/sec | 933 Mbits/sec Clouvider | Dallas, TX, US (10G) | 590 Mbits/sec | 168 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 906 Mbits/sec | 665 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1402 Multi Core | 1416 Full Test | https://browser.geekbench.com/v5/cpu/15841780Free NAT KVM | Free NAT LXC
Check your PM
10€/y NY WH24
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 5 16:34:26 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.4 MiB Swap : 0.0 KiB Disk : 9.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 341.38 MB/s (85.3k) | 1.42 GB/s (22.3k) Write | 342.28 MB/s (85.5k) | 1.43 GB/s (22.4k) Total | 683.66 MB/s (170.9k) | 2.86 GB/s (44.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.25 GB/s (2.4k) | 1.78 GB/s (1.7k) Write | 1.32 GB/s (2.5k) | 1.90 GB/s (1.8k) Total | 2.58 GB/s (5.0k) | 3.68 GB/s (3.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 230 Mbits/sec | 489 Mbits/sec Online.net | Paris, FR (10G) | 359 Mbits/sec | 899 Mbits/sec Hybula | The Netherlands (40G) | 312 Mbits/sec | 825 Mbits/sec Uztelecom | Tashkent, UZ (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 993 Mbits/sec | 956 Mbits/sec Clouvider | Dallas, TX, US (10G) | 99.1 Mbits/sec | 109 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 258 Mbits/sec | 659 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 62.0 Mbits/sec | 550 Mbits/sec Online.net | Paris, FR (10G) | 34.5 Mbits/sec | 294 Mbits/sec Hybula | The Netherlands (40G) | 42.4 Mbits/sec | 789 Mbits/sec Uztelecom | Tashkent, UZ (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 975 Mbits/sec | 943 Mbits/sec Clouvider | Dallas, TX, US (10G) | 68.2 Mbits/sec | 923 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 52.2 Mbits/sec | 907 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1395 Multi Core | 1387 Full Test | https://browser.geekbench.com/v5/cpu/15843854Free NAT KVM | Free NAT LXC
Oracle free, time to do some SYS admin work now and install everything
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 5 20:58:29 UTC 2022 ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : Neoverse-N1 CPU cores : 4 @ ??? MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 23.4 GiB Swap : 0.0 KiB Disk : 193.7 GiB Distro : Ubuntu 20.04.4 LTS Kernel : 5.13.0-1036-oracle fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 122.96 MB/s (30.7k) | 415.61 MB/s (6.4k) Write | 122.88 MB/s (30.7k) | 427.97 MB/s (6.6k) Total | 245.85 MB/s (61.4k) | 843.58 MB/s (13.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 189.08 MB/s (369) | 185.69 MB/s (181) Write | 205.26 MB/s (400) | 207.17 MB/s (202) Total | 394.34 MB/s (769) | 392.87 MB/s (383) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 3.29 Gbits/sec | 3.99 Gbits/sec Online.net | Paris, FR (10G) | 3.99 Gbits/sec | 3.17 Gbits/sec Hybula | The Netherlands (40G) | 4.03 Gbits/sec | 4.01 Gbits/sec Uztelecom | Tashkent, UZ (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 796 Mbits/sec | 2.27 Gbits/sec Clouvider | Dallas, TX, US (10G) | 414 Mbits/sec | 550 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 552 Mbits/sec | 1.15 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 868 Multi Core | 3352 Full Test | https://browser.geekbench.com/v5/cpu/15844089Signature currently under construction
done, credits to @TheDP
ralf@yabs:~$ bash yabs.sh |tee yabs.1gig.passthru.txt # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 6 Jul 16:06:30 BST 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Celeron(R) N5105 @ 2.00GHz CPU cores : 4 @ 1996.800 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 975.0 MiB Disk : 3.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 184.64 MB/s (46.1k) | 471.62 MB/s (7.3k) Write | 185.12 MB/s (46.2k) | 474.10 MB/s (7.4k) Total | 369.76 MB/s (92.4k) | 945.72 MB/s (14.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 348.13 MB/s (679) | 181.17 MB/s (176) Write | 366.63 MB/s (716) | 193.24 MB/s (188) Total | 714.77 MB/s (1.3k) | 374.42 MB/s (364) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 524 Mbits/sec | 538 Mbits/sec Online.net | Paris, FR (10G) | 520 Mbits/sec | 532 Mbits/sec Hybula | The Netherlands (40G) | 520 Mbits/sec | 535 Mbits/sec Uztelecom | Tashkent, UZ (10G) | busy | 475 Mbits/sec Clouvider | NYC, NY, US (10G) | 317 Mbits/sec | 517 Mbits/sec Clouvider | Dallas, TX, US (10G) | 142 Mbits/sec | 413 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 216 Mbits/sec | 464 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 676 Multi Core | 2109 Full Test | https://browser.geekbench.com/v5/cpu/15857804@SpeedyPage still performing good even after a few weeks, usually i had problems with other providers, after 1-2 weeks the performance drops at 50%.
`Basic System Information:
Uptime : 10 days, 22 hours, 35 minutes
Processor : AMD EPYC-Milan Processor
CPU cores : 2 @ 3693.060 MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 0.0 KiB
Disk : 58.1 GiB
Distro : Ubuntu 22.04 LTS
Kernel : 5.19.0-051900rc3-generic
Clouvider | London, UK (10G) | 784 Mbits/sec | 632 Mbits/sec
Online.net | Paris, FR (10G) | 793 Mbits/sec | 836 Mbits/sec
Clouvider | NYC, NY, US (10G) | 922 Mbits/sec | 881 Mbits/sec
Test | Value
Single Core | 1375
Multi Core | 2585
Full Test | https://browser.geekbench.com/v5/cpu/15871043
Virmach- AMS (FFxxx?) with Ryzen - after migration.
was from BF 2021. at USD 11/year- maybe I will renew??
Thu 07 Jul 2022 09:44:52 PM EDT Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 20 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3692.348 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.1 GiB Swap : 256.0 MiB Disk : 24.3 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-11-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 296.99 MB/s (74.2k) | 746.21 MB/s (11.6k) Write | 297.77 MB/s (74.4k) | 750.14 MB/s (11.7k) Total | 594.76 MB/s (148.6k) | 1.49 GB/s (23.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.20 GB/s (2.3k) | 1.36 GB/s (1.3k) Write | 1.26 GB/s (2.4k) | 1.45 GB/s (1.4k) Total | 2.47 GB/s (4.8k) | 2.82 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 936 Mbits/sec | 937 Mbits/sec Online.net | Paris, FR (10G) | busy | 937 Mbits/sec Hybula | The Netherlands (40G) | 939 Mbits/sec | 937 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 880 Mbits/sec | 721 Mbits/sec Clouvider | NYC, NY, US (10G) | 871 Mbits/sec | 740 Mbits/sec Clouvider | Dallas, TX, US (10G) | 535 Mbits/sec | 206 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 779 Mbits/sec | 647 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1271 Multi Core | 1398 Full Test | https://browser.geekbench.com/v5/cpu/15885749VPS reviews | | MicroLXC | English is my nth language.
crowncloud 12th gen I9 frankfurt , 22$ per month . respectable performance , truly the Ultimate Processing Power
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 08 Jul 2022 02:26:56 AM UTC Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 5 minutes Processor : 12th Gen Intel(R) Core(TM) i9-12900K CPU cores : 4 @ 3187.200 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.8 GiB Swap : 487.0 MiB Disk : 97.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-10-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 659.44 MB/s (164.8k) | 3.25 GB/s (50.9k) Write | 661.18 MB/s (165.2k) | 3.27 GB/s (51.1k) Total | 1.32 GB/s (330.1k) | 6.53 GB/s (102.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.99 GB/s (5.8k) | 3.02 GB/s (2.9k) Write | 3.15 GB/s (6.1k) | 3.23 GB/s (3.1k) Total | 6.15 GB/s (12.0k) | 6.26 GB/s (6.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 893 Mbits/sec | 931 Mbits/sec Online.net | Paris, FR (10G) | 892 Mbits/sec | 929 Mbits/sec Hybula | The Netherlands (40G) | 905 Mbits/sec | 897 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 816 Mbits/sec | 666 Mbits/sec Clouvider | NYC, NY, US (10G) | 776 Mbits/sec | 797 Mbits/sec Clouvider | Dallas, TX, US (10G) | 634 Mbits/sec | 214 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 585 Mbits/sec | 278 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1856 Multi Core | 5933 Full Test | https://browser.geekbench.com/v5/cpu/15886164Webhosting24 - 20x22 - Munich DE - €22/year (New Year Special)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 08 Jul 2022 04:25:29 AM CEST Basic System Information: --------------------------------- Uptime : 17 days, 5 hours, 46 minutes Processor : Intel(R) Xeon(R) CPU E5-2697 v3 @ 2.60GHz CPU cores : 2 @ 2599.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 975.0 MiB Disk : 96.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 221.88 MB/s (55.4k) | 227.87 MB/s (3.5k) Write | 222.47 MB/s (55.6k) | 229.07 MB/s (3.5k) Total | 444.35 MB/s (111.0k) | 456.94 MB/s (7.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 876.39 MB/s (1.7k) | 1.88 GB/s (1.8k) Write | 922.96 MB/s (1.8k) | 2.01 GB/s (1.9k) Total | 1.79 GB/s (3.5k) | 3.89 GB/s (3.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 863 Mbits/sec | 927 Mbits/sec Online.net | Paris, FR (10G) | 893 Mbits/sec | 933 Mbits/sec Hybula | The Netherlands (40G) | 968 Mbits/sec | 950 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 328 Mbits/sec | 838 Mbits/sec Clouvider | NYC, NY, US (10G) | 371 Mbits/sec | 595 Mbits/sec Clouvider | Dallas, TX, US (10G) | 158 Mbits/sec | 177 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 289 Mbits/sec | 225 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 420 Mbits/sec | 906 Mbits/sec Online.net | Paris, FR (10G) | 410 Mbits/sec | 771 Mbits/sec Hybula | The Netherlands (40G) | 466 Mbits/sec | 935 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 146 Mbits/sec | 743 Mbits/sec Clouvider | NYC, NY, US (10G) | 94.1 Mbits/sec | 279 Mbits/sec Clouvider | Dallas, TX, US (10G) | 93.5 Mbits/sec | 214 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 111 Mbits/sec | 239 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 777 Multi Core | 1541 Full Test | https://browser.geekbench.com/v5/cpu/15886184For domain registrations, create an account at Dynadot (ref) and spend $9.99 within 48 hours to receive $5 DynaDollars!
deinserverhost root server 17.4 euro
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fr 8. Jul 04:37:03 CEST 2022 Basic System Information: --------------------------------- Uptime : 0 days, 17 hours, 32 minutes Processor : Common KVM processor CPU cores : 8 @ 2849.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 15.6 GiB Swap : 768.0 MiB Disk : 196.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-15-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 84.60 MB/s (21.1k) | 733.39 MB/s (11.4k) Write | 84.82 MB/s (21.2k) | 737.25 MB/s (11.5k) Total | 169.43 MB/s (42.3k) | 1.47 GB/s (22.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 772.06 MB/s (1.5k) | 707.41 MB/s (690) Write | 813.08 MB/s (1.5k) | 754.52 MB/s (736) Total | 1.58 GB/s (3.0k) | 1.46 GB/s (1.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.01 Gbits/sec | 1.57 Gbits/sec Online.net | Paris, FR (10G) | 1.67 Gbits/sec | busy Hybula | The Netherlands (40G) | 1.63 Gbits/sec | 699 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 742 Mbits/sec | 1.38 Gbits/sec Clouvider | NYC, NY, US (10G) | 420 Mbits/sec | 857 Mbits/sec Clouvider | Dallas, TX, US (10G) | 189 Mbits/sec | 430 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 251 Mbits/sec | 676 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.ran geekbench 5 separately
https://browser.geekbench.com/v5/cpu/15886709
