@ofit said:
Hello @ralf, can you please test wireguard and openvpn performance (speed) on pfsense and openwrt in promox on your new box n5105 please. Thanks
I do have a wireguard proxy set up to another VM at OVH which seems to be working well, but not much use for a test as OVH is capped at 100Mbps.
So, initial tests using that (as it was already set up) seem pretty good for up to 100Mbps.
My direct setup is:
(unecrypted) laptop -> wifi -> 192.168.1.1 (pfsense) -> WAN -> internet -> gra.proof.ovh.net
I guess -R is slower because the ports on KS-LE-1 are 100 up, 1000 down.
CPU on proxmox hit about 6.5% on the first test and about 7.5% on the second, so not much impact. From the graph that shows all cores, running top -t 0.25 shows CPU getting up to about 30% (max 400%)
OneProvider.com
Product/Service: Dedicated Server +
Server location: Paris - FR
HARDWARE SPECIFICATIONS:
CPU: Intel Xeon E3-1220 v2 or better - 3.1 GHz - 4 core(s)
RAM: 32GB - DDR3
Hard Drive(s): 2x 1TB (SSD SATA)
Bandwidth: Unmetered @ 1Gbps (1 Gbps Guaranteed)
Price: €24.99 / 1 month
I got 2x SA530 3D NAND SATA SSD drives from Western Digital with Power On Hours: 120 , Intel Xeon E3-1230 V2 CPU and Dell Multi-bit ECC 4x 8GiB bus 1600 MT/s RAM.
https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Apologies for not adding more info. I did a similar proxy to a US VPS with Racknerd in LA and run iperf directly on that machine. I was getting about 300Mbps direct but for some reason the forwarding to a VM that did wireguard and forwarded on to the RN machine seemed to top out at about 130Mbps. Not sure why yet why it was much lower throughput than unwrapped, as CPU usage seemed pretty low everywhere.
Hi @vyas ,
Do you know why the Network speed is limited to less than 90 Mbits/sec?
Holy shit that CPU steal is high af
Signature currently under construction
Sorry for the inconvenience
My direct setup is:
My test set up using the tunnel is:
Doing a direct test first shows the wifi doesn't really limit bandwidth:
And multiple runs via the tunnel pretty much hit my usual speeds with OVH:
For comparison, iperf direct from the KS-LE-1:
Just fresh Delivered
10€/y Miami W24
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Jul 9 09:03:28 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.4 MiB Swap : 0.0 KiB Disk : 9.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-16-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 383.30 MB/s (95.8k) | 1.80 GB/s (28.1k) Write | 384.31 MB/s (96.0k) | 1.81 GB/s (28.2k) Total | 767.62 MB/s (191.9k) | 3.61 GB/s (56.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.82 GB/s (3.5k) | 1.78 GB/s (1.7k) Write | 1.92 GB/s (3.7k) | 1.90 GB/s (1.8k) Total | 3.75 GB/s (7.3k) | 3.68 GB/s (3.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 118 Mbits/sec | 187 Mbits/sec Online.net | Paris, FR (10G) | 327 Mbits/sec | 369 Mbits/sec Hybula | The Netherlands (40G) | 199 Mbits/sec | 748 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 29.8 Mbits/sec | 298 Mbits/sec Clouvider | NYC, NY, US (10G) | 650 Mbits/sec | 947 Mbits/sec Clouvider | Dallas, TX, US (10G) | 110 Mbits/sec | 247 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 272 Mbits/sec | 913 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 347 Mbits/sec | 752 Mbits/sec Online.net | Paris, FR (10G) | 159 Mbits/sec | 197 Mbits/sec Hybula | The Netherlands (40G) | 192 Mbits/sec | 744 Mbits/sec Uztelecom | Tashkent, UZ (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 735 Mbits/sec | 921 Mbits/sec Clouvider | Dallas, TX, US (10G) | 425 Mbits/sec | 921 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 331 Mbits/sec | 707 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1469 Multi Core | 1450 Full Test | https://browser.geekbench.com/v5/cpu/15912630Free NAT KVM | Free NAT LXC
Steam Deck 256GB NVMe (not plugged in)
## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Jul 11 02:19:08 AM EDT 2022 Basic System Information: --------------------------------- Uptime : 14 days, 13 hours, 24 minutes Processor : AMD Custom APU 0405 CPU cores : 8 @ 1700.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 14.5 GiB Swap : 1024.0 MiB Disk : 232.0 GiB Distro : SteamOS Kernel : 5.13.0-valve15-1-neptune-02197-gf6ec7ad3762a fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 136.12 MB/s (34.0k) | 209.60 MB/s (3.2k) Write | 136.48 MB/s (34.1k) | 210.70 MB/s (3.2k) Total | 272.60 MB/s (68.1k) | 420.31 MB/s (6.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 122.18 MB/s (238) | 64.87 MB/s (63) Write | 128.68 MB/s (251) | 69.26 MB/s (67) Total | 250.87 MB/s (489) | 134.13 MB/s (130) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 39.2 Mbits/sec | 85.0 Mbits/sec Online.net | Paris, FR (10G) | 36.9 Mbits/sec | 82.3 Mbits/sec Hybula | The Netherlands (40G) | 39.6 Mbits/sec | 83.5 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 37.6 Mbits/sec | 39.6 Mbits/sec Clouvider | NYC, NY, US (10G) | 41.1 Mbits/sec | 84.7 Mbits/sec Clouvider | Dallas, TX, US (10G) | 35.4 Mbits/sec | 28.0 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 40.2 Mbits/sec | 82.1 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 39.0 Mbits/sec | 54.4 Mbits/sec Online.net | Paris, FR (10G) | 38.6 Mbits/sec | busy Hybula | The Netherlands (40G) | 33.5 Mbits/sec | 87.6 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 32.3 Mbits/sec | 74.3 Mbits/sec Clouvider | NYC, NY, US (10G) | 36.9 Mbits/sec | 83.9 Mbits/sec Clouvider | Dallas, TX, US (10G) | 40.1 Mbits/sec | 86.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 40.0 Mbits/sec | 83.4 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 821 Multi Core | 3819 Full Test | https://browser.geekbench.com/v5/cpu/15943815Steam Deck 256GB NVMe (plugged in)
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 3 minutes Processor : AMD Custom APU 0405 CPU cores : 8 @ 2800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 14.5 GiB Swap : 1024.0 MiB Disk : 232.1 GiB Distro : SteamOS Kernel : 5.13.0-valve15-1-neptune-02197-gf6ec7ad3762a fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 132.74 MB/s (33.1k) | 214.68 MB/s (3.3k) Write | 133.09 MB/s (33.2k) | 215.81 MB/s (3.3k) Total | 265.84 MB/s (66.4k) | 430.49 MB/s (6.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 287.77 MB/s (562) | 318.51 MB/s (311) Write | 303.06 MB/s (591) | 339.72 MB/s (331) Total | 590.83 MB/s (1.1k) | 658.23 MB/s (642) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 39.9 Mbits/sec | 39.7 Mbits/sec Online.net | Paris, FR (10G) | 31.8 Mbits/sec | 46.3 Mbits/sec Hybula | The Netherlands (40G) | 38.1 Mbits/sec | 119 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 38.7 Mbits/sec | 97.4 Mbits/sec Clouvider | NYC, NY, US (10G) | 41.5 Mbits/sec | 140 Mbits/sec Clouvider | Dallas, TX, US (10G) | 28.3 Mbits/sec | 126 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 40.2 Mbits/sec | 109 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 38.3 Mbits/sec | 87.6 Mbits/sec Online.net | Paris, FR (10G) | 38.4 Mbits/sec | 56.6 Mbits/sec Hybula | The Netherlands (40G) | 37.7 Mbits/sec | 90.1 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 30.0 Mbits/sec | 52.0 Mbits/sec Clouvider | NYC, NY, US (10G) | 40.9 Mbits/sec | 83.7 Mbits/sec Clouvider | Dallas, TX, US (10G) | 39.3 Mbits/sec | 82.9 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 39.9 Mbits/sec | 83.0 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 829 Multi Core | 3789 Full Test | https://browser.geekbench.com/v5/cpu/15944316****Aliababa Cloud Offer 2GB KVM for 2.50$ 6Mbit Cap, 1.5TB Hong Kong
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 12 08:57:30 CST 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : Intel(R) Xeon(R) Platinum 8269CY CPU @ 2.50GHz CPU cores : 1 @ 2500.002 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 39.2 GiB Distro : Debian GNU/Linux 10 (buster) Kernel : 4.19.0-10-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.27 MB/s (1.5k) | 74.27 MB/s (1.1k) Write | 6.27 MB/s (1.5k) | 74.67 MB/s (1.1k) Total | 12.55 MB/s (3.1k) | 148.94 MB/s (2.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 71.66 MB/s (139) | 71.25 MB/s (69) Write | 75.47 MB/s (147) | 76.00 MB/s (74) Total | 147.14 MB/s (286) | 147.25 MB/s (143) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 7.15 Mbits/sec | 10.9 Mbits/sec Online.net | Paris, FR (10G) | 7.05 Mbits/sec | 9.40 Mbits/sec Hybula | The Netherlands (40G) | 7.17 Mbits/sec | 8.77 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 7.18 Mbits/sec | 8.80 Mbits/sec Clouvider | NYC, NY, US (10G) | 7.23 Mbits/sec | 10.7 Mbits/sec Clouvider | Dallas, TX, US (10G) | 7.07 Mbits/sec | 9.36 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 7.27 Mbits/sec | 10.8 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 730 Multi Core | 699 Full Test | https://browser.geekbench.com/v5/cpu/15959515Free NAT KVM | Free NAT LXC
15$/y AMS GreenCloud from 4th April Sale, still in Stock.
root@GreenCloud:~# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 12 16:49:35 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz CPU cores : 1 @ 2594.400 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : 18.6 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-16-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 202.74 MB/s (50.6k) | 571.02 MB/s (8.9k) Write | 203.28 MB/s (50.8k) | 574.02 MB/s (8.9k) Total | 406.03 MB/s (101.5k) | 1.14 GB/s (17.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 553.77 MB/s (1.0k) | 581.03 MB/s (567) Write | 583.19 MB/s (1.1k) | 619.73 MB/s (605) Total | 1.13 GB/s (2.2k) | 1.20 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.43 Gbits/sec | 4.10 Gbits/sec Online.net | Paris, FR (10G) | 7.80 Gbits/sec | 8.84 Gbits/sec Hybula | The Netherlands (40G) | 9.08 Gbits/sec | 8.14 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 1.80 Gbits/sec | 2.44 Gbits/sec Clouvider | NYC, NY, US (10G) | 1.61 Gbits/sec | 1.42 Gbits/sec Clouvider | Dallas, TX, US (10G) | 306 Mbits/sec | 673 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.01 Gbits/sec | 1.22 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 763 Multi Core | 759 Full Test | https://browser.geekbench.com/v5/cpu/15976820Free NAT KVM | Free NAT LXC
OneProvider.com
RAM: 32GB - DDR3
Yabs is here:
root@dtt:/home/ubuntu# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 13 Jul 2022 12:50:01 AM UTC Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 53 minutes Processor : Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz CPU cores : 8 @ 1801.250 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 9.0 GiB Disk : 915.2 GiB Distro : Ubuntu 20.04.4 LTS Kernel : 5.4.0-122-generic fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 89.54 MB/s (22.3k) | 162.19 MB/s (2.5k) Write | 89.77 MB/s (22.4k) | 163.04 MB/s (2.5k) Total | 179.32 MB/s (44.8k) | 325.24 MB/s (5.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 146.07 MB/s (285) | 146.58 MB/s (143) Write | 153.83 MB/s (300) | 156.34 MB/s (152) Total | 299.91 MB/s (585) | 302.92 MB/s (295) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 938 Mbits/sec | 939 Mbits/sec Online.net | Paris, FR (10G) | 942 Mbits/sec | 941 Mbits/sec Hybula | The Netherlands (40G) | 937 Mbits/sec | 938 Mbits/sec Uztelecom | Tashkent, UZ (10G) | busy | 850 Mbits/sec Clouvider | NYC, NY, US (10G) | 895 Mbits/sec | 891 Mbits/sec Clouvider | Dallas, TX, US (10G) | 572 Mbits/sec | 625 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 844 Mbits/sec | 857 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 926 Mbits/sec | 927 Mbits/sec Online.net | Paris, FR (10G) | 929 Mbits/sec | 928 Mbits/sec Hybula | The Netherlands (40G) | busy | busy Uztelecom | Tashkent, UZ (10G) | 876 Mbits/sec | 850 Mbits/sec Clouvider | NYC, NY, US (10G) | 877 Mbits/sec | 884 Mbits/sec Clouvider | Dallas, TX, US (10G) | 856 Mbits/sec | 851 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 840 Mbits/sec | 850 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 854 Multi Core | 3312 Full Test | https://browser.geekbench.com/v5/cpu/15979276https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
Hetzner CPX21
Thu Jul 14 05:31:20 AM UTC 2022
Processor : AMD EPYC Processor
CPU cores : 3 @ 2445.406 MHz
AES-NI : ✔ Enabled
RAM : 3.7 GiB
Swap : 0.0 KiB
Disk : 75.1 GiB
Distro : Ubuntu 22.04 LTS
Kernel : 5.15.0-40-generic
Test | Value
Single Core | 909
Multi Core | 2580
Full Test | https://browser.geekbench.com/v5/cpu/16001884
Oracle Cloud Ashburn, Virginia
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Jul 14 16:18:41 UTC 2022 ARM compatibility is considered *experimental* Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : Neoverse-N1 CPU cores : 4 @ ??? MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 23.4 GiB Swap : 0.0 KiB Disk : 101.7 GiB Distro : Ubuntu 22.04 LTS Kernel : 5.15.0-1013-oracle fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 13.11 MB/s (3.2k) | 26.88 MB/s (420) Write | 13.11 MB/s (3.2k) | 27.68 MB/s (432) Total | 26.23 MB/s (6.5k) | 54.56 MB/s (852) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 24.43 MB/s (47) | 24.12 MB/s (23) Write | 26.52 MB/s (51) | 26.91 MB/s (26) Total | 50.96 MB/s (98) | 51.03 MB/s (49) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 675 Mbits/sec | 702 Mbits/sec Online.net | Paris, FR (10G) | 435 Mbits/sec | 832 Mbits/sec Hybula | The Netherlands (40G) | 857 Mbits/sec | busy Uztelecom | Tashkent, UZ (10G) | 627 Mbits/sec | 326 Mbits/sec Clouvider | NYC, NY, US (10G) | 3.40 Gbits/sec | 3.17 Gbits/sec Clouvider | Dallas, TX, US (10G) | 493 Mbits/sec | 318 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.21 Gbits/sec | 766 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 853 Multi Core | 3296 Full Test | https://browser.geekbench.com/v5/cpu/16011718Contribute your idling VPS/dedi (link), Android (link) or iOS (link) devices to medical research
FiberVM - Linux Cloud VPS S - Singapore
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jul 15 16:03:06 UTC 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 19 minutes Processor : Intel(R) Xeon(R) E-2236 CPU @ 3.40GHz CPU cores : 4 @ 3400.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 8.0 GiB Swap : 2.0 GiB Disk : 62.4 GiB Distro : Ubuntu 22.04 LTS Kernel : 5.15.35-1-pve fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 766.61 MB/s (191.6k) | 2.46 GB/s (38.5k) Write | 768.63 MB/s (192.1k) | 2.48 GB/s (38.7k) Total | 1.53 GB/s (383.8k) | 4.95 GB/s (77.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.49 GB/s (4.8k) | 2.49 GB/s (2.4k) Write | 2.62 GB/s (5.1k) | 2.66 GB/s (2.6k) Total | 5.12 GB/s (10.0k) | 5.15 GB/s (5.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 670 Mbits/sec | 343 Mbits/sec Online.net | Paris, FR (10G) | 711 Mbits/sec | 253 Mbits/sec Hybula | The Netherlands (40G) | 826 Mbits/sec | busy Uztelecom | Tashkent, UZ (10G) | 659 Mbits/sec | 668 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | 636 Mbits/sec Clouvider | Dallas, TX, US (10G) | busy | 326 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 812 Mbits/sec | 497 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | 136 Mbits/sec Online.net | Paris, FR (10G) | 745 Mbits/sec | 453 Mbits/sec Hybula | The Netherlands (40G) | busy | busy Uztelecom | Tashkent, UZ (10G) | 635 Mbits/sec | 620 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | 184 Mbits/sec Clouvider | Dallas, TX, US (10G) | busy | 474 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 306 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1171 Multi Core | 3814 Full Test | https://browser.geekbench.com/v5/cpu/16030676Virmach $6/yr plan from 2017 that was migrated (Dallas):
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jul 15 13:42:00 EDT 2022 Basic System Information: --------------------------------- Uptime : 0 days, 3 hours, 59 minutes Processor : AMD Ryzen 9 3950X 16-Core Processor CPU cores : 2 @ 3493.436 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 460.4 MiB Swap : 32.0 MiB Disk : 4.8 GiB Distro : CentOS Stream 8 Kernel : 4.18.0-394.el8.x86_64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 273.13 MB/s (68.2k) | 141.43 MB/s (2.2k) Write | 273.85 MB/s (68.4k) | 142.17 MB/s (2.2k) Total | 546.98 MB/s (136.7k) | 283.60 MB/s (4.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 699.85 MB/s (1.3k) | 841.44 MB/s (821) Write | 737.04 MB/s (1.4k) | 897.48 MB/s (876) Total | 1.43 GB/s (2.8k) | 1.73 GB/s (1.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 794 Mbits/sec | 181 Mbits/sec Online.net | Paris, FR (10G) | busy | 201 Mbits/sec Hybula | The Netherlands (40G) | 757 Mbits/sec | 677 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 495 Mbits/sec | 178 Mbits/sec Clouvider | NYC, NY, US (10G) | 866 Mbits/sec | 220 Mbits/sec Clouvider | Dallas, TX, US (10G) | 798 Mbits/sec | 177 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 781 Mbits/sec | 296 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.Virmach $6/yr plan from 2017 that was migrated (New York):
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 15 Jul 2022 01:44:13 PM EDT Basic System Information: --------------------------------- Uptime : 2 days, 45 hours, 0 minutes Processor : AMD EPYC-Rome Processor CPU cores : 2 @ 3799.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 472.9 MiB Swap : 32.0 MiB Disk : 4.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 95.32 MB/s (23.8k) | 330.85 MB/s (5.1k) Write | 95.58 MB/s (23.8k) | 332.59 MB/s (5.1k) Total | 190.91 MB/s (47.7k) | 663.44 MB/s (10.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 397.13 MB/s (775) | 807.30 MB/s (788) Write | 418.23 MB/s (816) | 861.07 MB/s (840) Total | 815.37 MB/s (1.5k) | 1.66 GB/s (1.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 596 Mbits/sec | 73.7 Mbits/sec Online.net | Paris, FR (10G) | 526 Mbits/sec | 106 Mbits/sec Hybula | The Netherlands (40G) | 758 Mbits/sec | 571 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 696 Mbits/sec | 76.1 Mbits/sec Clouvider | NYC, NY, US (10G) | 862 Mbits/sec | 486 Mbits/sec Clouvider | Dallas, TX, US (10G) | 697 Mbits/sec | 24.1 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 694 Mbits/sec | 89.3 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.>
New / sub brand of Cloud V?
Was able to access my Hostcram VPS after a long time (long story, too). So, posting a YABS - 6 months later.
Sun Jul 17 00:14:15 UTC 2022 Basic System Information: --------------------------------- Uptime : 17 days, 12 hours, 26 minutes Processor : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz CPU cores : 1 @ 3500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.0 GiB Swap : 1.5 GiB Disk : 9.7 GiB Distro : Ubuntu 18.04.6 LTS Kernel : 5.13.19-6-pve fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.25 GB/s (313.7k) | 3.01 GB/s (47.1k) Write | 1.25 GB/s (314.5k) | 3.03 GB/s (47.4k) Total | 2.51 GB/s (628.2k) | 6.05 GB/s (94.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.61 GB/s (5.1k) | 1.25 MB/s (1) Write | 2.75 GB/s (5.3k) | 1.58 MB/s (1) Total | 5.37 GB/s (10.4k) | 2.84 MB/s (2) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 86.6 Mbits/sec | 71.6 Mbits/sec Online.net | Paris, FR (10G) | 85.6 Mbits/sec | 69.6 Mbits/sec Hybula | The Netherlands (40G) | 86.6 Mbits/sec | 85.8 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 82.5 Mbits/sec | 53.7 Mbits/sec Clouvider | NYC, NY, US (10G) | 89.4 Mbits/sec | 85.6 Mbits/sec Clouvider | Dallas, TX, US (10G) | 85.8 Mbits/sec | 63.6 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 89.6 Mbits/sec | 86.8 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6803 Multi Core | 6836 Full Test | https://browser.geekbench.com/v4/cpu/16586715 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1590 Multi Core | 1561 Full Test | https://browser.geekbench.com/v5/cpu/16057115VPS reviews | | MicroLXC | English is my nth language.
Hi @vyas ,
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 17 Jul 2022 03:17:08 PM CEST Basic System Information: --------------------------------- Uptime : 13 days, 7 hours, 18 minutes Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 4 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 0.0 KiB Disk : 155.5 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.18.4-xanmod1 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 468.01 MB/s (117.0k) | 2.12 GB/s (33.2k) Write | 469.25 MB/s (117.3k) | 2.13 GB/s (33.4k) Total | 937.27 MB/s (234.3k) | 4.26 GB/s (66.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.24 GB/s (4.3k) | 2.18 GB/s (2.1k) Write | 2.35 GB/s (4.6k) | 2.32 GB/s (2.2k) Total | 4.59 GB/s (8.9k) | 4.51 GB/s (4.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.93 Gbits/sec | 4.02 Gbits/sec Online.net | Paris, FR (10G) | 6.16 Gbits/sec | 6.05 Gbits/sec Hybula | The Netherlands (40G) | 6.73 Gbits/sec | 5.59 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 4.67 Gbits/sec | 851 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.78 Gbits/sec | 1.40 Gbits/sec Clouvider | Dallas, TX, US (10G) | 479 Mbits/sec | 458 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.10 Gbits/sec | 1.05 Gbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 6.89 Gbits/sec | 3.83 Gbits/sec Online.net | Paris, FR (10G) | 6.05 Gbits/sec | 5.88 Gbits/sec Hybula | The Netherlands (40G) | 6.82 Gbits/sec | 5.04 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 5.01 Gbits/sec | 3.62 Gbits/sec Clouvider | NYC, NY, US (10G) | 2.04 Gbits/sec | 909 Mbits/sec Clouvider | Dallas, TX, US (10G) | 1.33 Gbits/sec | 985 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.14 Gbits/sec | 476 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6063 Multi Core | 17497 Full Test | https://browser.geekbench.com/v4/cpu/16586996 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1375 Multi Core | 3826 Full Test | https://browser.geekbench.com/v5/cpu/16067574virmach after fixing their network in tokyo
iHostART VPS FluxNode
# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 19 Jul 2022 02:53:01 AM CEST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU cores : 8 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.9 GiB Swap : 1016.0 KiB Disk : 218.4 GiB Distro : Ubuntu 20.04.4 LTS Kernel : 5.4.0-122-generic fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 39.63 MB/s (9.9k) | 461.32 MB/s (7.2k) Write | 39.72 MB/s (9.9k) | 463.75 MB/s (7.2k) Total | 79.36 MB/s (19.8k) | 925.07 MB/s (14.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 666.30 MB/s (1.3k) | 667.40 MB/s (651) Write | 701.70 MB/s (1.3k) | 711.85 MB/s (695) Total | 1.36 GB/s (2.6k) | 1.37 GB/s (1.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 675 Mbits/sec | 854 Mbits/sec Online.net | Paris, FR (10G) | 628 Mbits/sec | 708 Mbits/sec Hybula | The Netherlands (40G) | 700 Mbits/sec | 838 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 565 Mbits/sec | 693 Mbits/sec Clouvider | NYC, NY, US (10G) | 553 Mbits/sec | 617 Mbits/sec Clouvider | Dallas, TX, US (10G) | 221 Mbits/sec | 304 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 464 Mbits/sec | 525 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 601 Multi Core | 4014 Full Test | https://browser.geekbench.com/v5/cpu/16095841NexusBytes $16/y vps
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 18 Jul 2022 09:37:53 PM EDT Basic System Information: --------------------------------- Uptime : 85 days, 10 hours, 18 minutes Processor : Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz CPU cores : 1 @ 2095.146 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.4 MiB Swap : 0.0 KiB Disk : 9.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 136.90 MB/s (34.2k) | 1.74 GB/s (27.2k) Write | 137.26 MB/s (34.3k) | 1.75 GB/s (27.3k) Total | 274.17 MB/s (68.5k) | 3.49 GB/s (54.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.18 GB/s (4.2k) | 2.09 GB/s (2.0k) Write | 2.29 GB/s (4.4k) | 2.23 GB/s (2.1k) Total | 4.47 GB/s (8.7k) | 4.33 GB/s (4.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 987 Mbits/sec | 953 Mbits/sec Online.net | Paris, FR (10G) | 956 Mbits/sec | 949 Mbits/sec Hybula | The Netherlands (40G) | 996 Mbits/sec | 954 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 377 Mbits/sec | 861 Mbits/sec Clouvider | NYC, NY, US (10G) | 456 Mbits/sec | 900 Mbits/sec Clouvider | Dallas, TX, US (10G) | 97.1 Mbits/sec | 101 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 224 Mbits/sec | 584 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.virtono KVM1G - 2.5 e
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 18 Jul 2022 09:37:29 PM EDT Basic System Information: --------------------------------- Uptime : 0 days, 23 hours, 20 minutes Processor : Intel Xeon Processor (Skylake, IBRS) CPU cores : 1 @ 2300.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 976.4 MiB Swap : 1023.0 MiB Disk : 28.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 87.75 MB/s (21.9k) | 310.10 MB/s (4.8k) Write | 87.98 MB/s (21.9k) | 311.73 MB/s (4.8k) Total | 175.74 MB/s (43.9k) | 621.83 MB/s (9.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 296.11 MB/s (578) | 292.31 MB/s (285) Write | 311.84 MB/s (609) | 311.78 MB/s (304) Total | 607.95 MB/s (1.1k) | 604.10 MB/s (589) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 439 Mbits/sec | 651 Mbits/sec Online.net | Paris, FR (10G) | 466 Mbits/sec | 523 Mbits/sec Hybula | The Netherlands (40G) | 427 Mbits/sec | 862 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 372 Mbits/sec | 515 Mbits/sec Clouvider | NYC, NY, US (10G) | 240 Mbits/sec | 148 Mbits/sec Clouvider | Dallas, TX, US (10G) | 79.3 Mbits/sec | 139 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 173 Mbits/sec | 81.6 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 562 Mbits/sec | 512 Mbits/sec Online.net | Paris, FR (10G) | 472 Mbits/sec | 523 Mbits/sec Hybula | The Netherlands (40G) | 511 Mbits/sec | 869 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 369 Mbits/sec | 592 Mbits/sec Clouvider | NYC, NY, US (10G) | 287 Mbits/sec | 370 Mbits/sec Clouvider | Dallas, TX, US (10G) | 169 Mbits/sec | 131 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 303 Mbits/sec | 347 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 562 Multi Core | 562 Full Test | https://browser.geekbench.com/v5/cpu/16096368VirMach BF plan after ryzen migration to frankfurt
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Jul 18 21:38:21 EDT 2022 Basic System Information: --------------------------------- Uptime : 8 days, 12 hours, 5 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 1 @ 3693.062 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.6 GiB Swap : 256.0 MiB Disk : 34.2 GiB Distro : AlmaLinux 8.6 (Sky Tiger) Kernel : 4.18.0-372.13.1.el8_6.x86_64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 290.96 MB/s (72.7k) | 1.07 GB/s (16.7k) Write | 291.73 MB/s (72.9k) | 1.07 GB/s (16.8k) Total | 582.70 MB/s (145.6k) | 2.15 GB/s (33.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.40 GB/s (4.7k) | 4.20 GB/s (4.1k) Write | 2.53 GB/s (4.9k) | 4.48 GB/s (4.3k) Total | 4.94 GB/s (9.6k) | 8.68 GB/s (8.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 929 Mbits/sec | 933 Mbits/sec Online.net | Paris, FR (10G) | 929 Mbits/sec | 906 Mbits/sec Hybula | The Netherlands (40G) | 933 Mbits/sec | 938 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 868 Mbits/sec | 751 Mbits/sec Clouvider | NYC, NY, US (10G) | 866 Mbits/sec | 751 Mbits/sec Clouvider | Dallas, TX, US (10G) | 452 Mbits/sec | 254 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 757 Mbits/sec | 544 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 908 Mbits/sec | 922 Mbits/sec Online.net | Paris, FR (10G) | 913 Mbits/sec | 923 Mbits/sec Hybula | The Netherlands (40G) | 910 Mbits/sec | 924 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 826 Mbits/sec | 776 Mbits/sec Clouvider | NYC, NY, US (10G) | 864 Mbits/sec | 807 Mbits/sec Clouvider | Dallas, TX, US (10G) | 756 Mbits/sec | 488 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 757 Mbits/sec | 730 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1151 Multi Core | 1173 Full Test | https://browser.geekbench.com/v5/cpu/16096355server-factory epyc XS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Jul 19 03:39:02 CEST 2022 Basic System Information: --------------------------------- Uptime : 5 days, 9 hours, 16 minutes Processor : AMD EPYC 7702P 64-Core Processor CPU cores : 1 @ 1999.999 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.6 GiB Swap : 0.0 KiB Disk : 50.0 GiB Distro : AlmaLinux 8.6 (Sky Tiger) Kernel : 4.18.0-348.7.1.el8_5.x86_64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 21.09 MB/s (5.2k) | 338.39 MB/s (5.2k) Write | 21.11 MB/s (5.2k) | 340.18 MB/s (5.3k) Total | 42.20 MB/s (10.5k) | 678.57 MB/s (10.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.37 GB/s (2.6k) | 1.77 GB/s (1.7k) Write | 1.45 GB/s (2.8k) | 1.89 GB/s (1.8k) Total | 2.82 GB/s (5.5k) | 3.66 GB/s (3.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.03 Gbits/sec | 950 Mbits/sec Online.net | Paris, FR (10G) | 1.02 Gbits/sec | 807 Mbits/sec Hybula | The Netherlands (40G) | 1.04 Gbits/sec | 994 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 427 Mbits/sec | 646 Mbits/sec Clouvider | NYC, NY, US (10G) | 280 Mbits/sec | 812 Mbits/sec Clouvider | Dallas, TX, US (10G) | 119 Mbits/sec | 436 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 315 Mbits/sec | 813 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.03 Gbits/sec | 979 Mbits/sec Online.net | Paris, FR (10G) | 1.02 Gbits/sec | 784 Mbits/sec Hybula | The Netherlands (40G) | 1.04 Gbits/sec | 983 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 379 Mbits/sec | 622 Mbits/sec Clouvider | NYC, NY, US (10G) | 373 Mbits/sec | 896 Mbits/sec Clouvider | Dallas, TX, US (10G) | 309 Mbits/sec | 898 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 316 Mbits/sec | 843 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.racknerd NY flash sale $6.79/y
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 18 Jul 2022 09:40:12 PM EDT Basic System Information: --------------------------------- Uptime : 7 days, 11 hours, 10 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU cores : 1 @ 2799.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 598.4 MiB Swap : 640.0 MiB Disk : 9.1 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 75.22 MB/s (18.8k) | 489.73 MB/s (7.6k) Write | 75.42 MB/s (18.8k) | 492.30 MB/s (7.6k) Total | 150.65 MB/s (37.6k) | 982.04 MB/s (15.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 714.29 MB/s (1.3k) | 582.37 MB/s (568) Write | 752.24 MB/s (1.4k) | 621.15 MB/s (606) Total | 1.46 GB/s (2.8k) | 1.20 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 781 Mbits/sec | 336 Mbits/sec Online.net | Paris, FR (10G) | 551 Mbits/sec | 243 Mbits/sec Hybula | The Netherlands (40G) | 718 Mbits/sec | 630 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 550 Mbits/sec | 276 Mbits/sec Clouvider | NYC, NY, US (10G) | 855 Mbits/sec | 793 Mbits/sec Clouvider | Dallas, TX, US (10G) | 375 Mbits/sec | 185 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 655 Mbits/sec | 404 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 498 Multi Core | 499 Full Test | https://browser.geekbench.com/v5/cpu/16096369IDK, the control panel is indeed Cloud V though
Also note that the VPS doesn't allow TIOCSTI.
GreenCloud LET 5555 RO
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : Intel(R) Xeon(R) CPU E5-2698 v3 @ 2.30GHz CPU cores : 5 @ 2299.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 4.8 GiB Swap : 2.0 GiB Disk : 52.9 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 177.59 MB/s (44.3k) | 1.29 GB/s (20.2k) Write | 178.06 MB/s (44.5k) | 1.30 GB/s (20.4k) Total | 355.65 MB/s (88.9k) | 2.60 GB/s (40.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.19 GB/s (2.3k) | 1.17 GB/s (1.1k) Write | 1.25 GB/s (2.4k) | 1.25 GB/s (1.2k) Total | 2.44 GB/s (4.7k) | 2.43 GB/s (2.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 856 Mbits/sec | 2.16 Gbits/sec Online.net | Paris, FR (10G) | busy | 4.41 Gbits/sec Hybula | The Netherlands (40G) | 6.37 Gbits/sec | 5.18 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 1.94 Gbits/sec | 1.61 Gbits/sec Clouvider | NYC, NY, US (10G) | 1.26 Gbits/sec | 1.62 Gbits/sec Clouvider | Dallas, TX, US (10G) | 353 Mbits/sec | 504 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 839 Mbits/sec | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 575 Multi Core | 2687 Full Test | https://browser.geekbench.com/v5/cpu/16124595Brazil, G-Core
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Jul 21 21:41:24 UTC 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : QEMU Virtual CPU version 2.5+ CPU cores : 1 @ 2394.374 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 483.3 MiB Swap : 0.0 KiB Disk : 19.6 GiB Distro : Debian GNU/Linux 10 (buster) Kernel : 4.19.0-5-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 265.75 MB/s (66.4k) | 1.92 GB/s (30.0k) Write | 266.45 MB/s (66.6k) | 1.93 GB/s (30.2k) Total | 532.20 MB/s (133.0k) | 3.86 GB/s (60.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.96 GB/s (3.8k) | 2.02 GB/s (1.9k) Write | 2.07 GB/s (4.0k) | 2.16 GB/s (2.1k) Total | 4.04 GB/s (7.8k) | 4.18 GB/s (4.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 98.5 Mbits/sec | 92.0 Mbits/sec Online.net | Paris, FR (10G) | 104 Mbits/sec | 91.2 Mbits/sec Hybula | The Netherlands (40G) | 103 Mbits/sec | 91.1 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 98.7 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 107 Mbits/sec | 95.9 Mbits/sec Clouvider | Dallas, TX, US (10G) | 98.8 Mbits/sec | 63.6 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 106 Mbits/sec | 91.0 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 104 Mbits/sec | 91.7 Mbits/sec Online.net | Paris, FR (10G) | 105 Mbits/sec | 90.9 Mbits/sec Hybula | The Netherlands (40G) | 103 Mbits/sec | 88.9 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 98.4 Mbits/sec | 76.4 Mbits/sec Clouvider | NYC, NY, US (10G) | 108 Mbits/sec | 94.8 Mbits/sec Clouvider | Dallas, TX, US (10G) | 106 Mbits/sec | 94.2 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 105 Mbits/sec | 92.6 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.Free NAT KVM | Free NAT LXC
Hosthatch - Singapore - 32gb VPS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-06-11 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Jul 22 10:21:33 UTC 2022 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 7 minutes Processor : AMD EPYC 7443 24-Core Processor CPU cores : 8 @ 2844.652 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.4 GiB Swap : 0.0 KiB Disk : 112.7 GiB Distro : Ubuntu 22.04 LTS Kernel : 5.15.0-1013-kvm fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 237.89 MB/s (59.4k) | 2.79 GB/s (43.6k) Write | 238.51 MB/s (59.6k) | 2.80 GB/s (43.8k) Total | 476.40 MB/s (119.1k) | 5.59 GB/s (87.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 9.54 GB/s (18.6k) | 9.90 GB/s (9.6k) Write | 10.05 GB/s (19.6k) | 10.55 GB/s (10.3k) Total | 19.59 GB/s (38.2k) | 20.46 GB/s (19.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 511 Mbits/sec | 774 Mbits/sec Online.net | Paris, FR (10G) | 810 Mbits/sec | 676 Mbits/sec Hybula | The Netherlands (40G) | 704 Mbits/sec | 1.00 Gbits/sec Uztelecom | Tashkent, UZ (10G) | 1.18 Gbits/sec | 1.15 Gbits/sec Clouvider | NYC, NY, US (10G) | 489 Mbits/sec | 580 Mbits/sec Clouvider | Dallas, TX, US (10G) | busy | 378 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 502 Mbits/sec | 579 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 532 Mbits/sec | 752 Mbits/sec Online.net | Paris, FR (10G) | 912 Mbits/sec | 983 Mbits/sec Hybula | The Netherlands (40G) | 503 Mbits/sec | 578 Mbits/sec Uztelecom | Tashkent, UZ (10G) | 504 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 562 Mbits/sec | 555 Mbits/sec Clouvider | Dallas, TX, US (10G) | 564 Mbits/sec | 496 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 460 Mbits/sec | 599 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1083 Multi Core | 6499 Full Test | https://browser.geekbench.com/v5/cpu/16165754How much do you pay for this?
Short answer : A LOT
More than LES limits allow.
Edit: regular price isn’t too bad considering the specs and location
https://hosthatch.com/ssd-vps
