server-factory.com | NL | IPv4 NAT or IPv4 | IPv6 | Storage VPS | 1 TiB @ 30€/year or 48€/2-years
Hi!
We successfully expanded our product portfolio with our new Storage VPS and would like to extend our pre-order promotion with yearly payment.
Storage VPS provisioning is instant!
Check our Website for Plans with more Storage!
1 TiB NAT
KVM Virtualization
STORAGE: 1 TiB HDD (ZFS RAID 10)
IPv4 NAT: Private Address with 20 Ports + SSH Port forwarded
IPv6: /64 Subnet
CPU: 1 (faire use)
RAM: 2 GiB
UPLINK: 1 Gbit/s
INCOMING TRAFFIC: UNMETERED
OUTGOING TRAFFIC: 4 TiB per month
30 € / year exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
48 € / 2-years exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
2 TiB NAT
KVM Virtualization
STORAGE: 2 TiB HDD (ZFS RAID 10)
IPv6: /64 Subnet
CPU: 2 (faire use)
RAM: 4 GiB
UPLINK: 1 Gbit/s
OUTGOING TRAFFIC: 8 TiB per month
60 € / year exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
96 € / 2-years exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
Plans with dedicated IPv4 Address:
1 TiB
KVM Virtualization
IPv4: 1
IPv6: /64 Subnet
CPU: 1 (faire use)
RAM: 2 GiB
UPLINK: 1 Gbit/s
42 € / year exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
72 € / 2-years exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
2 TiB
KVM Virtualization
IPv4: 1
IPv6: /64 Subnet
CPU: 2 (faire use)
RAM: 4 GiB
UPLINK: 1 Gbit/s
72 € / year exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
120 € / 2-years exclusive VAT, if you are from the EU, VAT applies
ORDER HERE
This offer will be hosted on:
HPE Cloudline CL3100 Gen10 Server with
2x Intel® Xeon® Gold 6152 Processor BASE CLOCK 2.1 GHZ / BOOST CLOCK UP TO 3.7 GHZ
512 GB 2666 MHz DDR4 ECC RAM from Samsung with 256 GB RAM dedicated to ZFS
2x Samsung PM893 240 GB Datacenter SATA SSD in RAID 1 for Proxmox Virtual Environment
12x Toshiba MG09 18 TB 7200rpm SATA HDD in ZFS RAID 10 for Virtual Private Server
2x 10 Gbit Uplink with LACP
General Information
Pay with Alipay | Bitcoin | Credit Card (Visa | Mastercard | American Express | UnionPay)
Manage IPv6 rDNS via our Client Panel
Debian 11 / Ubuntu 20.04 / AlmaLinux 8.5 / Rocky Linux 8.5 Template
Upload your own ISO
Looking Glass (IPv4: 188.239.191.7 - IPv6: 2a07:e040:1:7::1) => lg.nl.server-factory.com
Owned Hardware colocated in Serverius Datacenter 1 in Dronten, The Netherlands
RIPE NCC Member => Link
Own IPv6 Subnet => Link
All outgoing Mail Ports are blocked. You can send E-Mail trough our Mail Relay, for more information please contact us via ticket.
Check out our Reviews at Trustpilot => Link
No Refunds for this offer.
Have fun!
Kind regards,
mxmla
nice to see the 1 year plan max
Thank you
can old customers get double TRAFFIC on order?
Thanks for your question, we can not offer double Traffic at the moment, with the higher electricity pricing in NL this is already a very tight offer. We probably will not be able to offer it at this pricing again.
understood ... would have been perfect as a minio node.
feel free to select me as the only lucky winner : ) smiles
Is slow first connection issue (according to preorder users) fixed?
Thanks for your question! Yes, this is fixed, incoming IPv4 NAT connections are instant now.
and will users be able to customize port mapping in the future?
like others mentioned, some applications only support certain ports.
Thanks for your question! At the moment it is not planned to automate that, if you need a specific port please let me know and I will check if it is free. If it is just enough to forward the external Port to the internal specific port this is also possible.
will it be possible to use iptables on my VM to configure IPv4 port forwarding, or it will have to be manual on your end?
Public IPv4 Port XXXX (as assigned) <-> Port 12345 Internal IPv4
Yes. This is what i'm asking for and so is @cybertech
Is it customizable on user control panel?
I know it's possible via iptables on users' end but it surely will be much more convenient if it's available on control panel.
You can use iptables inside your VPS. Would be Public port as assigned > Internal Port as assigned > Your Port.
Please check my answer above. There is no management in our Client Area, sorry.
May I ask for which services specific ports are necessary (except 80, 443, 25 and so on)?
seems like port "rerouting" within the internal IP works.
External IP port xxxx (as assigned) <> Internal IP port xxxx (as assigned)
above port forwarding is fixed and already done by provider
Internal IP port xxxx (as assigned) <> Internal IP port custom (determined by user)
did the above in nftables
aaaaaaaand it works!!!!!!
awwww wyeahhhhhh
Yes. I'm aware of that but IMO customized port mapping should be available on the panel.
minus mail related ports plus NFS port and few extra ports that cloudflare supports.
Where can I find VNC connection info? The web novnc is kind of broken. Pressing keys only once = pressing twice in novnc
Is it a problem on my end?
Thanks for the feedback regarding the ports.
We only offer NOVNC, sorry. Just checked and from my point of view it is working as intended, no other customers are complaining, if this issue persists please open a Ticket with us.
All existing and new Storage VPS have Unmetered Incoming Traffic from now on, have fun
Once outgoing traffic limit is reached, incoming speed is capped to 10Mbps as well? Does the 10Mbps cap apply to storage vps now?
and traffic stats reset at 1st day every month or the order day of each month?
As soon as all outgoing Traffic was used, Incoming and Outgoing Network is limited to 10 Mbits.
Counters are reset on the order day each month.
anyone has a working solution for Nginx NAT?
You may want to install nginx on another vps then proxy to this storage vps
proxy via IPv6?
From a dedicated ipv4 vps to NAT ip or ivp6
i somehow managed to get nginx listen to assigned port, will take some time to figure it out
ok done.
