KS-1 RBX seems available a lot recently
https://checkservers.ovh/ ...even though always says (1H LOW) .
Can Kimsufi servers be auto paid monthly now that using a "cloud" account ?
Thanked by (1)Asim
  • edited August 2022
    I dunno, but I guess this one is mine (actually GRA not RBX):
    OLD KS-01 Atom™ N2800 2c / 4t 1.86 GHz+ 2 GB DDR3 1066 MHz 500 GB SATA - Not Available Not Available €9.99 €3.99 ~ €4
    Either that or they've already ungraded it and it's this one:
    KS-01 Atom™ N2800 2c / 4t 1.86 GHz+ 4 GB DDR3 1066 MHZ 1 TB SATA Not Available Available GRA (1H LOW) RBX (1H LOW) €4.99 €4.99 ~ €5
    I let it expire at the end of last month, and finally got notice yesterday it was being deleted. (Which is kind of stupid, as I tried to raise a ticket about a week before expiry to close it, but they ask you to just let it terminate by itself).
    But I think most people find that the listed availability mysteriously disappears when you try to order it, because the stock is running from their old system and the ordering has migrated to OVH cloud so there's often discrepencies.
    It stuck at 1H RBX low.
    RBX is are as fuck.
    Hence I created https://github.com/Ne00n/Operation-Chicken-Nugget
    Thanked by (2)Asim ariq01
    RBX is are as fuck.
    readme updated.
    RBX is are as fuck.
    readme updated.
    Is rbx dc the best of all location or something?
  • @dosai said:
    RBX is are as fuck.
    readme updated.
    no but usually rare.
    @Neoon said:
    @dosai said:
    RBX is are as fuck.
    readme updated.
    I tried using the scripts and got this error
    Traceback (most recent call last):
      File "/usr/local/lib/python3.10/dist-packages/ovh/client.py", line 150, in __init__
        self._endpoint = ENDPOINTS[endpoint]
    KeyError: ''
    During handling of the above exception, another exception occurred:
      File "/home/astro/Downloads/Operation-Chicken-Nugget-master/consumerKey.py", line 7, in <module>
        client = ovh.Client(
      File "/usr/local/lib/python3.10/dist-packages/ovh/client.py", line 152, in __init__
        raise InvalidRegion("Unknown endpoint %s. Valid endpoints: %s",
    ovh.exceptions.InvalidRegion: ('Unknown endpoint %s. Valid endpoints: %s', '', dict_keys(['ovh-eu', 'ovh-us', 'ovh-ca', 'kimsufi-eu', 'kimsufi-ca', 'soyoustart-eu', 'soyoustart-ca']))
    Team push-ups!
  • @Astro said:
    @Neoon said:
    @dosai said:
    RBX is are as fuck.
    readme updated.
    KeyError: ''
    As the error says, you need to supply a valid endpoint.
    Depending on where you have your ovh account.
  • @Neoon ah my bad. The readme didn't mention anything other than application key etc so didn't edit that
    Team push-ups!
    I updated the readme, plus the config, to add the option to order the server on a different location rather than France only.
    Managed to get an order in. Any idea how long it takes to process?
    Team push-ups!
  • I just ordered one and it took ~10 minutes to process.
    If you enable auto pay, instant in most cases but if you just generate an invoice, depends when they get stock again
