17/18 up and working well. One VM on ATLZ007 that is down, (EDIT: ATL just came back up) and one VM with a broken $3 migration (no bootable disk).
I would not call this anything close to a deadpool, but if I was 0/3 like @dedicados I might think different.
@tridinebandim said:
i have 4 vps with virmach which didn't get a hichkup during the transition. it seems one of them hicking up now
what is your success score like? mine 3/4
edit: did a last check
5/6, but I would have traded all 5 (and more!) of the working ones for the one that has been broken for 50 days.
Amusingly one of the 5 was also migrated to the wrong data center, but I hardly care, that probably was the second most important to me, so I'd rather have it working...
EDIT: Wait what do you mean hichkup? My other VPS that I cared about was down for >24 hours I dunno if that counts as a hichkup. Honestly I'm just happy to have that one back...
I guess I'm currently 2/4 depending. 2 of 3 vps up (one has been random, one is partly blacklisted by comcast), 1 vps with disconnected node for at least a month, vpsshared down but idk if that "counts".
I was about to report 3 VMs down, and awaiting a dedi re-install for about 10 days until I looked again, and another 2 VMs have since went unreachable. The network status page was updated today, so that's a good sign, but less helpful if you don't have a record of which node a VM you're on. Here's to hoping all will be forgiven with some super-duper BF deals. :-)
Renewed my VPS from FFME001.VIRM.AC node,
updated the OS, rebooted, and Poof! Server offline.
have raised a (non priority) ticket - at this time, do not want to even experiment with a $ 15 charge even though I know it is not an error on my part.
Wait and watch.
p.s: where can I find the SolusVM login credentials (email probably deleted, oops!)
@acidpuke said:
My biggest issue is I got 2 dedicated replacement servers that have centos7 on them with no way to install another OS.
I have had these going on 10 days now and cant do anything with them.
Appreciate the effort but their worthless if I can't install my OS on the them
Same here. I may attempt to do what @AlwaysSkint suggested a little while back and just attempt to install debian over top of centos. What's the worst that could happen -- I break it and have to wait for dedi controls anyway? Worth a shot, I guess.
@FrankZ said: One VM on ATLZ007 that is down, (EDIT: ATL just came back up)
Ugh finally! Was worried it'd be awhile before getting resolved. They seem to be playing whack-a-mole, though. Had 2 up and 2 down for awhile, then ATLZ007 came back, but now I'm noticing another down so still 2 up, 2 down. Currently affected nodes are LAXA031 and TPAZ002, neither of which appear on the network issues/announcements page.
# Python program to check if the number is an Armstrong number or not
# take input from the user
num = int(input("Enter a number: "))
# initialize sum
sum = 0
# find the sum of the cube of each digit
temp = num
while temp > 0:
digit = temp % 10
sum += digit ** 3
temp //= 10
# display the result
if num == sum:
print(num,"is an Armstrong number")
else:
print(num,"is not an Armstrong number")
that is why i asked if is deadpool now.... =(
Maybe.
But I hope they don't.
Anyway, some people can start migrating to Dewlance.
i would if my data where accesible xD
0/3
13/14
also mostly ppl that have issue track this topic I would presume that under <5% of VPS have issue, dedis I duno as they all need to migrated
AMS and Frankfurt looks pretty decent now.
I guess the longer distance from China the better? :P
Personally I'm going with this...
Certainement qui est en droit de vous rendre absurde, est en droit de vous rendre injuste - Voltaire
ATZ007 was one of my down, so 14/14 up
still have some issue on 2 that some processes crash not sure why
Thanks for the heads up - hopefully will stay up this time.
That's 12/12 VPS now (- likely due to distance from China).
That just leaves:
Have been trying to migrate outta Dallas, with no luck, but this is small fry stuff. No big deal.
Dataplane.org's current server hosting provider list
meanwhile invoices are coming. should i pay them even if not answer from support and servers down?...
100usd/mo are not millions, but would like to know if my servers are going back =S
What OS do you want on it?
Wait and watch.
Ryzen migrate is not working
I am trying to migrate from tokyo to frankfurt
Anyone have same migrate issue?
Humble janitor of LES
Proud papa of YABS
Proud papa of YABS
test
Proud papa of YABS
