How to install php modules extensions in Directadmin the right way
Guys
help.directadmin.com/item.php?id=252
the above link is one way and the other is to go to directadmin custom build interface.
Now I installed a php extension using the link above and then by mistake I installed the same way in direkctadmin custom build interface
Can this cause issue? What did exactly happen? When to use what?
