Does anyone have experience running LXC inside OVZ7? Not sure if it is even possible, but I figure if Docker works in OVZ7 then the cgroups/subuid mappings must work, which is pretty similar to what LXC requires.
@dahartigan put an order in for a 2GB plan VZ7 plan, UK is probably best bet but if that is going to be to much latency for you then Phoenix is fine too.
I would love to find out, for curiosity's sake. I don't currently have any VZ7 boxes to play with..
I am happy to give someone one for the sake of finding out, if they document it here then they can keep it for a year.
I don't see it going well personally but you are welcome to try.
You will need to be pretty experienced I guess and know how to fake certain dependencies.
If OP doesn't want that, I'd be happy to try and document any success, then return the VPS when the experiment is over. For science..
Please feel free to take first crack at it. I'll put a few hours into it if you draw a blank.
@AnthonySmith thank you :-) I placed the order, I hope that's the right one.
It will do, I assumed you would have wanted a bit more disk space and picked the regular one but I suppose it matters not
Just keep in mind the templates are VERY minimal.
That's perfect, thanks Ant :-)
Keeping it in the low end spirit of things :-P
