@SmallWeb said:
Good impressions of LAX from customers so far. If you're intrigued to try out DirectAdmin on AMD Ryzens and NVMe SSD you can have an exclusive 50% off any LAX plan. Only 10 available. Code: NEWLAX
@SmallWeb said:
Additional terms of service were added last month but I believe more work needs to be done as well as future-proofing it (tos). On to my question.
@vyas said:
Waiting for code for New Amsterdam. Wait. Will that be new setup for AMS or for the city now known as New York? Smallweb is available at both places
New New New New New!
This upgrade has fer sure got me thinking on my long term hardware goals, but I definitely need to do them one by one rather than all at once :P
Migrate LAX Cancel cPanel Migrate NYC
After that I will just work on keeping the current active servers happy and healthy and that general stuff.
@gks said: Ordered one, to park my site a while. thank you.
We are writing to advise you of a migration planned for services hosted on Shared-NYC1 to a new server (Shared-NYC2) on 02 April 2020. The new server will utilise the same hardware, network and datacenter as it currently does (although hardware improvements are planned in the future - more on that later).
Why are we migrating?
This new server uses CentOS 8 as opposed to Debian 9 which will enable us to smoothly transition to CloudLinux 8 when that becomes publicly available.
What do I need to do?
As part of this migration your services IPv4/v6 will change and the old IPv4/v6 will stop resolving. Because of this, custom DNS solutions (like CloudFlare) will no longer resolve your domain once the migration is complete until you update your A record to our new IP address.
If you would like to manually update your A record post-migration please use the following IPv4:
However, we highly recommend updating to our nameservers to avoid any disruption to service.
Once the migration has completed for all accounts, we will forward the old hostname.
We can expedite this migration for your service or services upon request.
Also, limited edition Singapore plan is available. (1GB NVMe, £5/year). Sorry to copy Lee again but I promised customers this location last year and I'm not ready to deploy and manage it myself with all this other work going on so it's through a reseller for now.
@vyas said: Damn it Michael, no.... I mean hell no.
Can't tell what tone this ones in.
I find it helps in these cases to read it in a sexual context
You do that with ceiling fan manuals tho.
Of course, insert bolt into gape and screw firmly.
You prefer to blow up, or down?
My hardware is set to the strict factory standard configuration, no alternative settings, so blow down of course. I suspect you may be into swinging both ways with the direction, si or no?
6 left. Let's fill this bad boy up so I can pay my pal some upgrade fees.
Michael
Why not both? HTML page with "download as PDF" would be nice
Thanks very much my friend!
That sounds good too
Thank you
Michael
@SmallWeb never stop being so awesome
Just sent out:
Michael
Glad to see you're expanding and all the best with the migration :-)
Edit: smallweb is prem
Lee has inspired me to revive smallweb.net/blog
https://smallweb.net/blog/smallwebs-blogging-plans-for-2020/
Michael
Read more here:
https://smallweb.net/blog/new-limited-singapore-location/
Order form link:
https://smallweb.net/portal/order/main/packages/limited/?group_id=35
Michael
Finally! I can order butt.sg
Is that because wss.sg is taken?
@SmallWeb
Cheers.
thanks.. got one. first purchase from LeS
Would you be able to send me test ip via PM?
Thank you and that's very nice to know ?
For SGP? Sure thing ?
Michael
Michael
Only one of those promo codes remaining.
Michael
The usual.... just forgot to add a smiley :-)
Damn you because You have actually set something up in SGP so makes it tough to say no.
Cheers
And
Congratulations
Instruction not clear, fan stuck in wss.
It's literally called a 'switch'. DPDT.
Oh baby!
This always seems to happen..
Michael
We're giving you free attention!
Double Pole, Double Thrill
Always learning something new on LES.
ESL = English as Second Language
LES = Learning English (with) similies
(hashtag) SexyWeb
Michael
