@Ympker said:
I hear ya mate
Affinity Designer Review reads: "..has tons of features and equals even Photoshop in many regards.. "
Me: "But can I remove background with it? "
hahaha
I've been editing (basically, removing backgrounds XD) of product photos (my offline business) in PS since long. Its the only thing which I use PS for these days.
If you didn't wanna use PS to remove background or you to lazy to do it.
you can use Remove.bg ( https://www.remove.bg/ ) its start from $9/month for 40 image
@thedp said: Ok we need to talk about a logo for me then ?
Too bad,
I'm not that good when making a logo ( or finding a design inspiration ) that's why I'm not a pro graphic designer and choosing to be a web developer
I sense you have more patience and love on art. Good work indeed.
Just a reminder. Logo designing is not what @DianTama did, which seems to be joining two existing elements and just put one inside another.
Further explanation would be needed. Did you designed the wheel and the terminal icon before joining them?
At minimum the individual elements would need to be modified enough from their original forms to evade issues.
Otherwise is an easy way to get sued for copyright infringement if it were to be used for the project. Specially if it ever go commercial.
Just my 2cents. I think this should be considered when picking a winner.
There is more value in a logo designed completely from scratch than a logo that took existing publicly available arts as elements to form a new logo.
If that's the case, @ben47955 has a clear path to victory
This was obviously a troll. I did that in like 10 seconds. I believe if I win this, it would be a insult to whoever spend spend time to make a logo that look professionals. But hey, that's the community choice.
Freelance Web Developer & Web Designer - Available for hire!
PS: No hate, your logo looks good!
https://talk.lowendspirit.com/discussion/comment/52171/#Comment_52171
How about this piece of original art?
