Tip: Install OS via netboot.xyz without ISO support
It can happen your vm provider has a broken iso mount or does not support it at all. You can install your OS using netboot.xyz the following way:
1- Have your vm already installed with one of the provided templates e.g: debian 9. ssh into your vm as root install the ipxe package:
# apt-get install ipxe
# update-grub
Get your ip, gateway from your vm info email, provider cp or on debian this way and store it as it will be needed later.
# cat /etc/network/interfaces
or # ip r
# reboot
2- From your vnc or console, you should be able to see similar grub menu
after you press enter then quickly keep pressing CTRL+B ,or you can set to boot from CD only in you cp... then you should
enter your ip info you stored from the above step 1 like show in next image
if your vm supports ipv6 then it may try to configure it so you press enter like shown:
let it boot and should be good
I wrote this article when i got a HH vm and uploading iso is broken at time of this article.
References :
1- https://unix.stackexchange.com/questions/190865/is-it-possible-to-add-some-pxe-network-boot-option-to-grub
2- http://www.panticz.de/Install-GRUB-iPXE-netboot
@AnthonySmith @vyas @Ympker @Not_Oles @Mason
hopefully this will help all the HH iso lost souls.
Looking nice mate
wish i knew how to do this since 3 years ago.
Don't we all ?
Nice and short How To btw
p.s
Upgraded to Debain Bullseye while moving from Debian 9, lack of coffee is my excuse
I wish I knew how to do this 3 days ago...
I like it!
Congrats!
Thanks for the guide @ehab
Thanks for the guide. It is illustrative and done easy step by step
Dentistry is my passion
thanks alot!
This finally made it possible for me to install my OS on an old Dedicated server.
Follow up tip, if you have a IPMI or iLo that messes with you.
I installed Centos, selected the text-based installation and was then asked if I wanted a VNC server started instead of running the text-based installation.
Much faster and more stable then my "broken" IPMI.
https://clients.mrvm.net
Imgur
Unlucky, that's what I experience from Vultr.
System halt...
did you try another booting another os?
No, I copied from the thread. Debian OS is my fav and recently deployed. If Debian fails, users around the globe may encounter the same issue. Probably Vultr has sth. wrong.
Arch won't work out it seems
is there a Centos version of this?
not sure, but you can add the kernel and update the grub yourself.
Thanks, used Debian 9 instead and followed this guide. Works pefect
guess the following two lines could do the job ( and the third to finalize the boot menu). you may have to adjust the GRUB_TIMEOUT value, making it larger so the screen may stop for a while rather than splash away when you get into the VNC.
it looks CloudCone's VPS/KVM doesn't support this booting method. have updated grub and menu but when rebooting there's no ipxe item on the screen. guess theirs are not compatible.
@aRNoLD said:
install debian
then
have vnc open and this should get into the ipxe boot, try it.
apt install ipxe
produce the following outputthe second line,
grub-reboot "Network boot (iPXE)"
produced the followingthen from the splash screen, it said "Falling back to Grub Legacy" and then gave only four options of original OS/Debian booting, but without ipxe options.
guess CloudCone doesn't support ipxe booting?
@aRNoLD is it a kvm? just asking since you grabbed all the text! how did you do that
https://imgur.com/a/AQf6272
Yes, the control panel shows its platform is KVM. That's one point that I feel weird.
the text is copied from SSH terminal.
i have some credit with them, when i get time i will try to have me some fun.
I noticed that some Live CDs or even network boot won't really boot at all and just stucks at the initramfs fallback terminal or even kernel panic
on static IP configuration, must be something, or probably they need DHCP to work
if the provider does not have DHCP you must manually add those in the boot menu command line "press e" or at the seed file. But if you get a kernel panic then either ram is not enough or you are an unlucky b*
j/k
Okay will def trying that later to see it works
or maybe, it depends
but I am not sure how to run them, the specific commands.
from URL: https://rpmfind.net/linux/RPM/centos/7.9.2009/x86_64/Packages/ipxe-bootimgs-20180825-3.git133f4c.el7.noarch.html , and you'll see there are several files
