Says it's a Threadripper in the plan title, but I think it's actually an AMD EPYC 7351 based on AuthenticAMD Family 23 Model 1 Stepping 2 as the CPU type in Geekbench.
AMD EPYC 7351 only has a turbo speed of 2.9ghz. Looking at clock speed it's possibly Ryzen with the CPU model set as a generic "AMD EPYC" in whichever hypervisor they're using.
That's true. Forgot to look at that.
From Geekbench -
Processor Information
Name AMD EPYC Processor (with IBPB)
Topology 2 Processors, 2 Cores
Identifier AuthenticAMD Family 23 Model 1 Stepping 2
Base Frequency 3.49 GHz
L1 Instruction Cache 64.0 KB
L1 Data Cache 32.0 KB
L2 Cache 512 KB
L3 Cache 8.00 MB
For a Threadripper vCPU, the GB score is pretty weak.. similar to Intel Gold, atleast EPYC would give you ~850 for single core and Threadripper would give you ~1200 for single core
Note:
a. Some penalty in GB5 score- Zorin OS versus Ubuntu (Kernel version, etc..)
b. I tried something today that I had not anticipated doing- setting up RAID1. Both Kingston SATA disks, not quite rockets but good workhorses. Steps in a nutshell
Reinstalled Linux (Ubuntu)
Set up RAID1 (2 x 240 GB SATA disks) --> read up on relevant posts, RAID is not backup is now etched in my head.
Default ZFS config, right now the system is using about 900MB including bloatmox UI.
I don't really see much memory usage, but I am also not doing a lot of I/O operations.
I would give it a try if you got 32GB systems or higher, but I won't do it on 16GB systems.
Since on 16GB you already giving 1GB away for the system and bloatmox and another potential 1GB per TB storage for ZFS.
I don't have exact figures, just starting using ZFS and its amazing.
means ZFS is gonna eat up to 50% of the available memory for ARC. it does not neccessarily release that easily, so even if memory consumption for now is low, it will raise to 16GB over time no matter what. if you can afford it, that's a good thing, if you might need it otherwise you need to be careful to not lose the speed benefit afterwards because the system starts to swap a lot.
@ehab said: @Falzo I didn't search but can you please tell why you like ZFS for proxmox?
I do not. or at least I make that decision carefully depending on how many VMs with how much RAM should go on there. as just said ZFS potentially consumes lots of RAM for its ARC unless you restrict it. also the system can not claim ARC back like it would do with regular filecache because it is controlled by ZFS and the kernel only sees blocked memory.
so it can be dangerous if you think you can commit 32GB to your VMs but ZFS is gonna eat half of that.
with that said, obviously one still can benefit from ZFS if calculated/balanced properly as the caching works pretty well. as an example I have a SYS dedi with 4x2TB where I do not need the full 32GB for the VMs because it's rather a backup box.
apart from the backup VM I only have a win rdp with 10GB RAM on it and another 10GB for different gameservers... limit zfs to 8GB and still have breathing room for the main system...
on the other hand if you plan to have more VMs on a box and eventually even overcommit on memory slightly to take advantage of KSM and stuff, I probably would not use ZFS - and most likely no HDD anymore anyway.
I was actually expecting that ZFS would release memory if its getting thin.
But thanks for the reminder to set a cap at xGB and override the default one.
theoretically would there be performance loss with capping ram?
I'd say that heavily depends on your real world workload.
the more RAM you can use for ARC the better simply because you can hold more data in there. however if you move a 4GB file one time and do not touch it directly afterwards it might simply clog you cache for nothing. you want your cache be hot and re-used frequently. most likely you can achieve that with a smaller one already 🤷♂️
for most regular use cases I think on a 32GB machine you do not need 16GB and if ARC is restricted to 8 or even 4GB you won't see or feel much of a difference performance wise after all.
@Neoon said: The 50% is a LIE, that used 90% of the hole system memory.
it shouldn't though, did you check the cache stats before changing the max limit? of course regular filecache will come on top, so might have looked different... but yeah, as said before. needs to be handled with a bit of care ;-)
The System was hitting 90%+, KSM did already engage.
So without setting a hard limit to ZFS I guess with any I/O intensive application you may get banged anytime.
RawSRV.com, $9.50/month dedicated core VPS in Miami
Main selling point is the 10 Gbps (shared) Unmetered and Path.net DDoS Protection
Main use is probably for GRE tunnels and such, but I'm using it to send data to Dropbox from multiple servers.
This is the lowest score of Ryzen 3900x I have ever seen
LowHosting RKVMPROTECTED16 - 1 month free gift from LowHosting.
I wish I can keep it forever
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 06 Dec 2021 12:45:16 AM GMT Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 6 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 15.6 GiB Swap : 256.0 MiB Disk : 117.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 599.76 MB/s (149.9k) | 3.58 GB/s (55.9k) Write | 601.35 MB/s (150.3k) | 3.60 GB/s (56.2k) Total | 1.20 GB/s (300.2k) | 7.18 GB/s (112.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.88 GB/s (5.6k) | 3.02 GB/s (2.9k) Write | 3.03 GB/s (5.9k) | 3.22 GB/s (3.1k) Total | 5.92 GB/s (11.5k) | 6.25 GB/s (6.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 928 Mbits/sec | 464 Mbits/sec Online.net | Paris, FR (10G) | 904 Mbits/sec | 885 Mbits/sec WorldStream | The Netherlands (10G) | 930 Mbits/sec | 914 Mbits/sec WebHorizon | Singapore (1G) | 122 Mbits/sec | 290 Mbits/sec Clouvider | NYC, NY, US (10G) | 860 Mbits/sec | 263 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 768 Mbits/sec | 235 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 800 Mbits/sec | 235 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 10.7 Mbits/sec | 99.3 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 884 Mbits/sec | 545 Mbits/sec Online.net | Paris, FR (10G) | 889 Mbits/sec | 623 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | 96.5 Mbits/sec | 180 Mbits/sec Clouvider | NYC, NY, US (10G) | 839 Mbits/sec | 209 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 672 Mbits/sec | 183 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1461 Multi Core | 6964 Full Test | https://browser.geekbench.com/v5/cpu/11444968🔥 RackNerd BF2021 VPS from $10.88/year & free ClientExec 😎 HostCram FastestVPS 🤑 Virmach BF&CM 2021 👈 Affiliate link ⚡
✔️SellSSL.com - Sectigo PositiveSSL from 15 USD per year!
AlphaVPS
Won a giveaway for 1 year
1GB Dedicated RAM
512GB RAID60 HDD
1.5TB Bandwidth
1 Shared CPU core
1Gbps Port
1 IPv4 IP
/64 of IPv6
BG
Dell 710 II with 2x L5630 and SAS-2 HDD's
Old homelab server that screams for faster disks.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # man dec 6 19:30:18 CET 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU L5630 @ 2.13GHz CPU cores : 16 @ 2128.068 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 47.0 GiB Swap : 23.6 GiB Disk : 3.5 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.25 MB/s (312) | 15.82 MB/s (247) Write | 1.28 MB/s (320) | 16.32 MB/s (255) Total | 2.53 MB/s (632) | 32.14 MB/s (502) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 45.89 MB/s (89) | 52.07 MB/s (50) Write | 48.51 MB/s (94) | 55.63 MB/s (54) Total | 94.41 MB/s (183) | 107.71 MB/s (104) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 850 Mbits/sec | 428 Mbits/sec Online.net | Paris, FR (10G) | 824 Mbits/sec | 397 Mbits/sec WorldStream | The Netherlands (10G) | 808 Mbits/sec | 339 Mbits/sec WebHorizon | Singapore (1G) | 193 Mbits/sec | 275 Mbits/sec Clouvider | NYC, NY, US (10G) | 677 Mbits/sec | 290 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 674 Mbits/sec | 163 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 617 Mbits/sec | 152 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 481 Mbits/sec | 163 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 830 Mbits/sec | 463 Mbits/sec Online.net | Paris, FR (10G) | 816 Mbits/sec | 315 Mbits/sec WorldStream | The Netherlands (10G) | 853 Mbits/sec | 495 Mbits/sec WebHorizon | Singapore (1G) | 154 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 737 Mbits/sec | 301 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 612 Mbits/sec | 295 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 417 Multi Core | 3290 Full Test | https://browser.geekbench.com/v5/cpu/11458232hostingbot.com - Jacksonville - Ryzen Threadripper - 10Gbps - 512MB - $4.95/month
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 07 Dec 2021 04:38:54 PM EST Basic System Information: --------------------------------- Processor : AMD EPYC Processor (with IBPB) CPU cores : 2 @ 3493.432 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 473.3 MiB Swap : 0.0 KiB Disk : 14.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 54.86 MB/s (13.7k) | 591.19 MB/s (9.2k) Write | 54.96 MB/s (13.7k) | 594.30 MB/s (9.2k) Total | 109.82 MB/s (27.4k) | 1.18 GB/s (18.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.27 GB/s (2.4k) | 1.37 GB/s (1.3k) Write | 1.33 GB/s (2.6k) | 1.47 GB/s (1.4k) Total | 2.60 GB/s (5.0k) | 2.84 GB/s (2.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.18 Gbits/sec | 963 Mbits/sec Online.net | Paris, FR (10G) | 1.19 Gbits/sec | 886 Mbits/sec WorldStream | The Netherlands (10G) | 1.13 Gbits/sec | 896 Mbits/sec WebHorizon | Singapore (1G) | 118 Mbits/sec | 418 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.45 Gbits/sec | 3.38 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 727 Mbits/sec | 3.94 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.59 Gbits/sec | 1.48 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 284 Mbits/sec | 724 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3401 Multi Core | 5604 Full Test | https://browser.geekbench.com/v4/cpu/16433062 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 680 Multi Core | 1241 Full Test | https://browser.geekbench.com/v5/cpu/11479007AMD EPYC 7351 only has a turbo speed of 2.9ghz. Looking at clock speed it's possibly Ryzen with the CPU model set as a generic "AMD EPYC" in whichever hypervisor they're using.
From Geekbench -
L2 Cache 512 KB
L3 Cache 8.00 MB
yes i agree
Inception Hosting
2 CPU Core
2 GB Ram (DDR4)
30 GB Pure NVMe SSD Disk space (Raid 1)
6000 GB Bandwidth @ 1 gbit (shared)
1 x IPv4 address
1 x /64 IPv6
Free complimentary DDOS protection
Free Direct Admin license on request.
€25 /year
Phoenix , AZ
Possibly my last post on this topic (my custom multi disk rig)
fio before RAID
Sunday 28 November 2021 01:41:45 PM IST Basic System Information: --------------------------------- RAM : 22.4 GiB Swap : 906.8 MiB Disk : 658.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 80.20 MB/s (20.0k) | 137.93 MB/s (2.1k) Write | 80.41 MB/s (20.1k) | 138.66 MB/s (2.1k) Total | 160.61 MB/s (40.1k) | 276.59 MB/s (4.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 175.53 MB/s (342) | 196.37 MB/s (191) Write | 184.86 MB/s (361) | 209.45 MB/s (204) Total | 360.39 MB/s (703) | 405.83 MB/s (395)fio after RAID1
Thursday 09 December 2021 07:02:26 PM IST Basic System Information: --------------------------------- RAM : 22.4 GiB Swap : 0.0 KiB Disk : 245.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 122.85 MB/s (30.7k) | 213.10 MB/s (3.3k) Write | 123.17 MB/s (30.7k) | 214.22 MB/s (3.3k) Total | 246.02 MB/s (61.5k) | 427.33 MB/s (6.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 218.67 MB/s (427) | 233.33 MB/s (227) Write | 230.29 MB/s (449) | 248.87 MB/s (243) Total | 448.97 MB/s (876) | 482.21 MB/s (470)Note:
Yabs again on Gravelands KS-LE but on ZFS Raid 1, 1TB
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Dec 10 16:04:52 CET 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz CPU cores : 8 @ 3900.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 0.0 KiB Disk : fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 24.24 MB/s (6.0k) | 215.76 MB/s (3.3k) Write | 24.26 MB/s (6.0k) | 216.90 MB/s (3.3k) Total | 48.50 MB/s (12.1k) | 432.66 MB/s (6.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 871.90 MB/s (1.7k) | 303.55 MB/s (296) Write | 918.23 MB/s (1.7k) | 323.77 MB/s (316) Total | 1.79 GB/s (3.4k) | 627.32 MB/s (612) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 96.9 Mbits/sec | 941 Mbits/sec Online.net | Paris, FR (10G) | 98.8 Mbits/sec | 941 Mbits/sec WorldStream | The Netherlands (10G) | 96.8 Mbits/sec | 940 Mbits/sec WebHorizon | Singapore (1G) | busy | 252 Mbits/sec Clouvider | NYC, NY, US (10G) | 94.4 Mbits/sec | 899 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 90.4 Mbits/sec | 182 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 90.2 Mbits/sec | 808 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 82.4 Mbits/sec | 590 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 861 Multi Core | 3513 Full Test | https://browser.geekbench.com/v5/cpu/11529538Free NAT KVM | Free NAT LXC
KS-LE in ROUBAAAIX with ZFS Raid 1
## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Dec 11 00:55:08 CET 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz CPU cores : 8 @ 3900.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 0.0 KiB Disk : fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 22.59 MB/s (5.6k) | 225.80 MB/s (3.5k) Write | 22.60 MB/s (5.6k) | 226.99 MB/s (3.5k) Total | 45.19 MB/s (11.2k) | 452.80 MB/s (7.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 614.95 MB/s (1.2k) | 655.12 MB/s (639) Write | 647.62 MB/s (1.2k) | 698.75 MB/s (682) Total | 1.26 GB/s (2.4k) | 1.35 GB/s (1.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 95.3 Mbits/sec | 935 Mbits/sec Online.net | Paris, FR (10G) | 95.4 Mbits/sec | 935 Mbits/sec WorldStream | The Netherlands (10G) | 94.9 Mbits/sec | 934 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 38.6 Mbits/sec | 316 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 20.3 Mbits/sec | 71.6 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 24.4 Mbits/sec | 310 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 14.0 Mbits/sec | 123 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 727 Mbits/sec | 739 Mbits/sec Online.net | Paris, FR (10G) | 736 Mbits/sec | 547 Mbits/sec WorldStream | The Netherlands (10G) | 725 Mbits/sec | 769 Mbits/sec WebHorizon | Singapore (1G) | 137 Mbits/sec | 116 Mbits/sec Clouvider | NYC, NY, US (10G) | 255 Mbits/sec | 167 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 148 Mbits/sec | 74.8 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 864 Multi Core | 3758 Full Test | https://browser.geekbench.com/v5/cpu/11536641Free NAT KVM | Free NAT LXC
wow thats good IO for HDD
how much ram is it needed to set aside for this?
and
told you so ;-)
Applied this now on the machines and reboot, will see if that's enough.
3-4GB should be fine tho, I hope.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 12 Dec 2021 10:17:42 PM EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 1 @ 2599.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 29.5 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 58.42 MB/s (14.6k) | 721.75 MB/s (11.2k) Write | 58.53 MB/s (14.6k) | 725.55 MB/s (11.3k) Total | 116.95 MB/s (29.2k) | 1.44 GB/s (22.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.08 GB/s (4.0k) | 2.28 GB/s (2.2k) Write | 2.19 GB/s (4.2k) | 2.43 GB/s (2.3k) Total | 4.28 GB/s (8.3k) | 4.71 GB/s (4.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.76 Gbits/sec | 667 Mbits/sec Online.net | Paris, FR (10G) | 1.80 Gbits/sec | 540 Mbits/sec WorldStream | The Netherlands (10G) | 1.58 Gbits/sec | busy WebHorizon | Singapore (1G) | 207 Mbits/sec | 177 Mbits/sec Clouvider | NYC, NY, US (10G) | 3.88 Gbits/sec | 817 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 4.93 Gbits/sec | 2.48 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 2.95 Gbits/sec | 674 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 361 Mbits/sec | 1.34 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 842 Multi Core | 841 Full Test | https://browser.geekbench.com/v5/cpu/11575424RawSRV.com, $9.50/month dedicated core VPS in Miami
Hosthatch HK revisit
biennial deal
very slight steal observed but going strong after few months. lovely I/O
iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 322 Mbits/sec | 290 Mbits/sec Online.net | Paris, FR (10G) | 454 Mbits/sec | 390 Mbits/sec WorldStream | The Netherlands (10G) | 422 Mbits/sec | 216 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 418 Mbits/sec | 319 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 405 Mbits/sec | 354 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 441 Mbits/sec | 369 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 306 Mbits/sec | 138 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 580 Mbits/sec | 338 Mbits/sec Online.net | Paris, FR (10G) | 615 Mbits/sec | 333 Mbits/sec WorldStream | The Netherlands (10G) | 576 Mbits/sec | 133 Mbits/sec WebHorizon | Singapore (1G) | 433 Mbits/sec | 588 Mbits/sec Clouvider | NYC, NY, US (10G) | 530 Mbits/sec | 385 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 514 Mbits/sec | 376 Mbits/secI bench YABS 24/7/365 unless it's a leap year.
Stratagem Tritium - limited to 200mbps. I believe plans higher than this are on 1g
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 13 Dec 2021 04:57:09 PM EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz CPU cores : 1 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 976.4 MiB Swap : 0.0 KiB Disk : 19.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 70.80 MB/s (17.7k) | 102.40 MB/s (1.6k) Write | 70.98 MB/s (17.7k) | 102.94 MB/s (1.6k) Total | 141.78 MB/s (35.4k) | 205.35 MB/s (3.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 97.73 MB/s (190) | 96.62 MB/s (94) Write | 102.92 MB/s (201) | 103.05 MB/s (100) Total | 200.66 MB/s (391) | 199.68 MB/s (194) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 198 Mbits/sec | 191 Mbits/sec Online.net | Paris, FR (10G) | 197 Mbits/sec | 191 Mbits/sec WorldStream | The Netherlands (10G) | busy | 191 Mbits/sec WebHorizon | Singapore (1G) | 108 Mbits/sec | 111 Mbits/sec Clouvider | NYC, NY, US (10G) | 185 Mbits/sec | 187 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 164 Mbits/sec | 181 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 171 Mbits/sec | 179 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 96.2 Mbits/sec | 96.3 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 197 Mbits/sec | 189 Mbits/sec Online.net | Paris, FR (10G) | 196 Mbits/sec | 188 Mbits/sec WorldStream | The Netherlands (10G) | 196 Mbits/sec | 188 Mbits/sec WebHorizon | Singapore (1G) | 125 Mbits/sec | busy Clouvider | NYC, NY, US (10G) | 184 Mbits/sec | 184 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 155 Mbits/sec | 176 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2695 Multi Core | 2610 Full Test | https://browser.geekbench.com/v4/cpu/16438249 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 606 Multi Core | 604 Full Test | https://browser.geekbench.com/v5/cpu/11590080Racknerd. Today I observed high steal, so I decided to run YABS:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 14 Dec 2021 09:05:11 PM UTC Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 978.8 MiB Swap : 978.8 MiB Disk : 14.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 140.40 MB/s (35.1k) | 972.85 MB/s (15.2k) Write | 140.77 MB/s (35.1k) | 977.97 MB/s (15.2k) Total | 281.17 MB/s (70.2k) | 1.95 GB/s (30.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.28 GB/s (2.5k) | 1.62 GB/s (1.5k) Write | 1.34 GB/s (2.6k) | 1.73 GB/s (1.6k) Total | 2.62 GB/s (5.1k) | 3.36 GB/s (3.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 131 Mbits/sec | 251 Mbits/sec Online.net | Paris, FR (10G) | 422 Mbits/sec | 217 Mbits/sec WorldStream | The Netherlands (10G) | 415 Mbits/sec | 265 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 748 Mbits/sec | 525 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 489 Mbits/sec | 361 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 563 Mbits/sec | 321 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 111 Mbits/sec | 189 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 709 Multi Core | 728 Full Test | https://browser.geekbench.com/v5/cpu/11610699This is the lowest score of Ryzen 3900x I have ever seen
