@Falzo said: @VirMach mate, you should really consider giving that idiot who shared this offer via his aff and without needed infos a proper kick in the butt for not respecting the exclusivity and rules.
maybe next time really already mark such offers as not applicable to any affiliate payouts in the opening post and on the page... just saying.
It's not the end of the world. I know I was as strict as possible with my wording, but we'll figure out a good solution for all these people. I have a lot of ideas regarding affiliate system reform but we'll have to have some free time to try to implement it all. I wanted to start measuring how many problematic customers get sent per affiliate and figure out a good way to either terminate their contract with us or reduce their earnings but it would have to be done properly. It's not something I can do on the fly right now and it would end up being unfair in some way to some affiliates due to the way the system currently works.
Plus we don't really know how all of this was communicated from each affiliate, what if they did also write a TLDR of it and people ignored that too? It would take too long to properly investigate every instance right now.
It's still not the affiliate that didn't respect these rules, none of the rules really said you must refer people to this page if you want to speak about this product. I mean it's common sense, but you get my point, playing the devil's advocate, it could easily be argued the other way around as well so I can't just shut down their affiliate account over it. What I could technically do though since this is an exclusive offer is shut down affiliate payouts for it but the problem with that is, I'm pretty sure WHMCS never coded the affiliate program properly to where it would keep track of all that and it instead goes based off universal rules and it's fully retroactive meaning I can't have "promotion periods" where it turns off and on for those particular referrals. At this point I'm just rambling though, I don't know.
We could have probably executed all of it better as well but I unfortunately also do not have the time for that, I'd have to spend entire days trying to think of all the things that could go wrong with it and I'd never be satisfied. Then that means we'd have to standardize all offers and make them very boring.
I hear you... just sad to see, that your efforts even with this special here get shot at so hard and you end up again having to clean up stuff and take sh*t from ignorant people etc.
you'll find a way though, I am pretty sure, best of luck with the sales ;-)
@Mamyyy said:
Node 39.
Trying to install Oracle Linux via Netboot.xyz but my instance turned off halfway.
Is thare anything I shou
I guess you do not have enough ram for that distro, as far i know ubuntu 18.04 + is not go on 768mb, for other distros i have no idea there are no spech but know anything "new" ask a lot ram to mount ISO and finish install
You might do better from an iso as it doesn't need to buffer all the packages, etc....
I've checked all my emails and support tickets but found no order number. (Many guys said they got order number from one of them.) The only number I got is Invoice 1413507.
Please help me activate it if possible, or I request for a refund, in fact I prefer your service.
Thank you for your efforts!@VirMach
@realEthanZou said:
I mean to be patient but the FOMO is kicking in. I placed order 4767433618 on day 2 and it’s still not activated. Generally what’s the lead time?
Did you post your order ID here before? Maybe I missed it, I'll take a look now.
@knifered said:
Hi, I lost order id but only invoice:1414626. May U help me activate the VPS? I had sent message to your inbox, but no replay. Thanks.
regards,
@realEthanZou said: Node35. Performance of 3 cores isn't much better than 2 cores. And the network is kinda disappointing.
Maybe there are a lot of new deployments on that node and many are running yabs on a shared 1gb/s connection.
I would expect after most folks go into idle mode it will probably get better. Gota love that disk speed though
Due to my negligence, I forgot to save my order number. At present, I only have the invoice number: 1413457. Can you help me activate my VPS? thank you!
@VirMach said:
All order IDs should be activated. If you provided order ID and it's not activated, let me know. If you provided anything other than order ID, I can't immediately activate it right now but I'll probably go through each location in bulk anyway at some point in time so you'll receive your service most likely, you just have to be more patient.
@lechang said:
My Order Number is: 5363464785, please.
Excuse me, I guess you missed my order, may I have your attention please?
@Sean said: @VirMach
Order #560836
OrderNumber 8477795567
Invoice #1415112
Error 1015 Ray ID: 6fbcbb017883813f • 2022-04-14 13:18:58 UTC
You are being rate limited
What happened?
The owner of this website (solusvm.virmach.com) has banned you temporarily from accessing this website.
All I did was reset my password then try to get back to the login page to use it.
I haven't seen the order id when I buy VPS. My invoice id is #1417952. Pls help activate. Thanks.
Node 39.
Still thinking about the bus thing.
^ Just no. Getting epilepsy.
Order Number is: 2762579265
Thanks!
Order #560916
Sorry ,I lost my Order number, my invoice is 1414420. Please help me active it. Thank you!@VirMach
Order Number is: 7363285526 ,please open it .
I've just placed the order#561460,
Pls View Ticket :#364672,
Invoice#1416919,
Pls activate it as u see fit, thank u for ur effort!
Thank you!@VirMach
Order Number is: 6930100111
Thanks.
Twice. Thanks for the swift response this time.
@VirMach Sir! Help!
Certainement qui est en droit de vous rendre absurde, est en droit de vous rendre injuste - Voltaire
I cannot find an order id , I got nothing after I paid.The only number I got is Invoice 1418055.
Please help me activate it if possible.
My Order Number is: 5013327118
Invoice #1418073
Please active it .
thanks.
Domain for Sale: Lea·com $3000,000 USD. Contact by email: [email protected]
I find out if lost the order number you can view the link to show the an order number:
https://billing.virmach.com/cart.php?a=complete
please。
It doesn't make sense.
I guess it's related with your cookies or sessions.
Order Number is: 8515385929 ,please open it .
