★ VirMach ★ RYZEN ★ NVMe ★★ $30/2YR- 768MB ★ $40/2YR - 1.5GB ★ $50/2YR - 2.5GB ★ $70/2YR - 4GB ★ LES
1161719212268
  • Activation request. Order ID: 7173497678
  • My order is 7179813098, Pls help to activate. Thanks.
  • 3 days uptime with 384MB RAM🥳
    root@TYOC039:~# uptime
     23:38:42 up 3 days,  1:12,  1 user,  load average: 0.44, 0.27, 0.15
    root@TYOC039:~# free -h
                   total        used        free      shared  buff/cache   available
    Mem:           347Mi        80Mi       165Mi       1.0Mi       101Mi       255Mi
    Swap:          2.0Gi        17Mi       2.0Gi
    some benchmark results:
    Spoiler
    #                     v2022-02-18                    #
    Thu Apr 14 23:21:55 JST 2022
    Processor  : AMD Ryzen 9 5900X 12-Core Processor
    CPU cores  : 1 @ 3693.060 MHz
    RAM        : 347.1 MiB
    Swap       : 2.0 GiB
    Disk       : 9.7 GiB
    Read       | 190.53 MB/s  (47.6k) | 256.92 MB/s   (4.0k)
    Write      | 191.04 MB/s  (47.7k) | 258.27 MB/s   (4.0k)
    Total      | 381.57 MB/s  (95.3k) | 515.20 MB/s   (8.0k)
    Read       | 696.51 MB/s   (1.3k) | 1.23 GB/s     (1.2k)
    Write      | 733.52 MB/s   (1.4k) | 1.31 GB/s     (1.2k)
    Total      | 1.43 GB/s     (2.7k) | 2.55 GB/s     (2.4k)
    Clouvider       | London, UK (10G)          | 215 Mbits/sec   | 52.0 Mbits/sec
    Online.net      | Paris, FR (10G)           | 217 Mbits/sec   | 32.0 Mbits/sec
    WorldStream     | The Netherlands (10G)     | 192 Mbits/sec   | 18.3 Mbits/sec
    WebHorizon      | Singapore (400M)          | 382 Mbits/sec   | 112 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 252 Mbits/sec   | 20.5 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 253 Mbits/sec   | 41.6 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 227 Mbits/sec   | 52.6 Mbits/sec
    Iveloz Telecom  | Sao Paulo, BR (2G)        | busy            | busy
    -------------------- A Bench.sh Script By Teddysun -------------------
     Version            : v2022-02-22
     Usage              : wget -qO- bench.sh | bash
     CPU Model          : AMD Ryzen 9 5900X 12-Core Processor
     CPU Cores          : 1 @ 3693.060 MHz
     CPU Cache          : 512 KB
     AES-NI             : Enabled
     VM-x/AMD-V         : Enabled
     Total Disk         : 9.7 GB (3.8 GB Used)
     Total Mem          : 347.1 MB (80.9 MB Used)
     Total Swap         : 2.0 GB (17.6 MB Used)
     System uptime      : 3 days, 1 hour 5 min
     Load average       : 0.02, 0.09, 0.07
     OS                 : Debian GNU/Linux 11
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.10.0-13-amd64
     TCP CC             : bbr
     Virtualization     : Dedicated
     Organization       : AS23959 Owl Limited
     Region             : Moscow
     I/O Speed(1st run) : 742 MB/s
     I/O Speed(2nd run) : 889 MB/s
     I/O Speed(3rd run) : 934 MB/s
     I/O Speed(average) : 855.0 MB/s
     Node Name        Upload Speed      Download Speed      Latency
     Speedtest.net    327.09 Mbps       300.03 Mbps         1.21 ms
     Los Angeles, US  252.12 Mbps       174.60 Mbps         109.68 ms
     Dallas, US       166.54 Mbps       117.35 Mbps         127.49 ms
     Montreal, CA     168.50 Mbps       86.12 Mbps          176.62 ms
     Paris, FR        144.19 Mbps       54.48 Mbps          231.99 ms
     Amsterdam, NL    116.40 Mbps       72.71 Mbps          325.03 ms
     Shanghai, CN     168.97 Mbps       46.80 Mbps          188.30 ms
     Nanjing, CN      35.20 Mbps        191.10 Mbps         37.30 ms
     Guangzhou, CN    21.81 Mbps        128.25 Mbps         55.12 ms
     Hongkong, CN     272.01 Mbps       663.82 Mbps         110.80 ms
     Seoul, KR        626.65 Mbps       605.33 Mbps         34.17 ms
     Finished in        : 6 min 9 sec
     Timestamp          : 2022-04-14 23:37:38 JST
    Thanked by (1)bdl
  • @cornercase said:
    Error 1015 Ray ID: 6fbcbb017883813f • 2022-04-14 13:18:58 UTC
    You are being rate limited
    What happened?
    The owner of this website (solusvm.virmach.com) has banned you temporarily from accessing this website.
    All I did was reset my password then try to get back to the login page to use it.
    Now it doesn't accept the new password. So I reset it again and get rate limited again. :/
    What happened?
    Try this
    Thanked by (1)cornercase
  • @VirMach
    Can I upgrade my order? Can 1536 upgrade 2560?Not enough memory。
  • @ovzlacom said:
    @VirMach
    I don't work for Virmach but previous answers in the thread to this question have been 'no'.
  • edited April 2022
    @ovzlacom said:
    @VirMach
    I seem to have looked at the answers, but I can't find it. Probably missed answer or deleted. I installed DirectAdmin and it seems that there is not enough memory. Or I can buy another one, thanks for your answer.
    @knifered said:
    @knifered said:
    Hi, I lost order id but only invoice:1414626. May U help me activate the VPS? I had sent message to your inbox, but no replay. Thanks.
    regards,
    @VirMach Sir! Help!
    I can increase your renewal fee if you keep posting your invoice ID here, that's about it.
  • @ovzlacom said: I seem to have looked at the answers, but I can't find it. Probably missed answer or deleted. I installed DirectAdmin and it seems that there is not enough memory. Or I can buy another one, thanks for your answer.
    Entirely possible I'm thinking of the OGF. Can always wait and see but I'm pretty sure that's right.
    What happened?
    DM your IP.
    What happened?
    DM your IP.
    I got into it through the "VPS Control Panel" button in billing.virmach, but I will DM you my IP anyway.
    Thanks
  • edited April 2022
    @ovzlacom said: I installed DirectAdmin and it seems that there is not enough memory.
    There is a low memory installation method. My 2 slices:
    Total Memory 990.9 MB
    Free Memory 83.57 MB
    Available Memory 269.46 MB
    Total Swap Memory 1024 MB
    Free Swap Memory 801.25 MB
    Cached Swap Memory 19.66 MB
    Thanked by (2)skorous FrankZ
  • williewillie OG
    edited April 2022
    It is weird, I remember seeing an upgrade button in the control panel somewhere, but then couldn't find it when I was also interested in upgrading. I take for granted that we don't get to ask for manual intervention as the process is intended (lol) to be as low hassle as possible at the hosting end.
    I don't know if the end result is anything like what Virmach expected. LES did get a lot of new members and maybe some of them will stick around. But it is in practice an open offer rather than an exclusive one, since lots of people joined LES just in order to get it.
    What happened?
    DM your IP.
    I‘m facing the same problem, "https://solusvm.virmach.com/login.php" keeps showing "Invalid Username or Password" even if I'm 100% sure both the username and password are correct.
    When you try to reset the password, and after you click the link sent to your email and get the next email with your new password , you will be banned from the website. Changing IP will bypass the temporary ban but you still can not login in...
    @willie said: I don't know if the end result is anything like what Virmach expected. LES did get a lot of new members and maybe some of them will stick around. But it is in practice an open offer rather than an exclusive one, since lots of people joined LES just in order to get it.
    I've thought about this and I assume the exclusive offers are meant to have this effect, since you can see the enticing titles as a guest. I'm new here though so someone could probably explain the actual intention better. I did personally feel that it could be a good nudge in the right direction.
    @willie said: It is weird, I remember seeing an upgrade button in the control panel somewhere, but then couldn't find it when I was also interested in upgrading. I take for granted that we don't get to ask for manual intervention as the process is intended (lol) to be as low hassle as possible at the hosting end.
    If it doesn't appear it most likely means the plan dynamically changes and we can't have people hopping in between different sales due to how they're organized.
    Thanked by (2)FrankZ stevewatson301
    @kisser said:
    What happened?
    DM your IP.
    May I ask how you're 100% sure? It's possible it's related but this is the first report of this I've seen (the 100% correct username and password triggering a login error.)
  • edited April 2022
    @VirMach said:
    @kisser said:
    What happened?
    DM your IP.
    Yes I can confirm that, coz I also tried another vps' user and pass which worked previously, and also can not login in.
    and such info stored in my password vault, google and bitwarden.and I didn't change them.
  • @kisser said:
    @VirMach said:
    @kisser said:
    What happened?
    DM your IP.
    And for the recently actived Tokyo VPS, I used the billing.virmach.com to bypass the login page to access the control panel. and changed the pass in the acc management page, it does recognize the correct password( if you put a wrong pass it will remind you) and show sucess message.
  • @VirMach said:
    @kisser said:
    What happened?
    DM your IP.
    Can confirm, it also happened to me, reset password -> got email -> get limited by cloudflare -> try login from different ip -> invalid username or password.
    Try resetting password several time, same thing happened, triple check credentials.
    I don't mind, still can login via clientarea.
  • My order is 9582631208, Pls help to activate. Thanks.
  • @VirMach said: I've thought about this and I assume the exclusive offers are meant to have this effect, since you can see the enticing titles as a guest. I'm new here though so someone could probably explain the actual intention better. I did personally feel that it could be a good nudge in the right direction.
    Well that would up to @Mason I guess. I'd say that at worst we got a bunch of new members signed up who aren't that interested in becoming steady forum participants. That ties up a few database rows but is basically harmless, so no big deal. It's then mostly a matter of whether you're reasonably happy with how the sale has gone. So I hope it worked out ok from your perspective.
  • Order Number is: 3994794875 ,please open it .
    We’ve seen increased activity in other threads, not only this one.
    If even 1% of the new users find other threads interesting and contribute in one way or another, we all win.
  • 我已经购买,需要开启服务器,我的Order Number is:3789306372
  • edited April 2022
    @VirMach My Order Number is: 7212795981. Pls help to activate. Thx!
  • Invoice #1417138
    order #561597
    thank you!
  • My order is 561633, Pls help to activate. Thanks.
  • edited April 2022
    Invoice #1414421
    sir i lost my order number can you active my vps ?
  • As of now, the CPU steal is an issue on node 035. The Geekbench 5 score of my 3-core VPS is ~2200, which is more like 2 cores.
