Error 1015 Ray ID: 6fbcbb017883813f • 2022-04-14 13:18:58 UTC
You are being rate limited
What happened?
The owner of this website (solusvm.virmach.com) has banned you temporarily from accessing this website.
All I did was reset my password then try to get back to the login page to use it.
Now it doesn't accept the new password. So I reset it again and get rate limited again.
What happened?
Can I upgrade my order? Can 1536 upgrade 2560?Not enough memory。
I don't work for Virmach but previous answers in the thread to this question have been 'no'.
I seem to have looked at the answers, but I can't find it. Probably missed answer or deleted. I installed DirectAdmin and it seems that there is not enough memory. Or I can buy another one, thanks for your answer.
@knifered said:
Hi, I lost order id but only invoice:1414626. May U help me activate the VPS? I had sent message to your inbox, but no replay. Thanks.
regards,
@ovzlacom said: I seem to have looked at the answers, but I can't find it. Probably missed answer or deleted. I installed DirectAdmin and it seems that there is not enough memory. Or I can buy another one, thanks for your answer.
Entirely possible I'm thinking of the OGF. Can always wait and see but I'm pretty sure that's right.
What happened?
What happened?
DM your IP.
I got into it through the "VPS Control Panel" button in billing.virmach, but I will DM you my IP anyway.
It is weird, I remember seeing an upgrade button in the control panel somewhere, but then couldn't find it when I was also interested in upgrading. I take for granted that we don't get to ask for manual intervention as the process is intended (lol) to be as low hassle as possible at the hosting end.
I don't know if the end result is anything like what Virmach expected. LES did get a lot of new members and maybe some of them will stick around. But it is in practice an open offer rather than an exclusive one, since lots of people joined LES just in order to get it.
What happened?
DM your IP.
I‘m facing the same problem, "https://solusvm.virmach.com/login.php" keeps showing "Invalid Username or Password" even if I'm 100% sure both the username and password are correct.
When you try to reset the password, and after you click the link sent to your email and get the next email with your new password , you will be banned from the website. Changing IP will bypass the temporary ban but you still can not login in...
@willie said: I don't know if the end result is anything like what Virmach expected. LES did get a lot of new members and maybe some of them will stick around. But it is in practice an open offer rather than an exclusive one, since lots of people joined LES just in order to get it.
I've thought about this and I assume the exclusive offers are meant to have this effect, since you can see the enticing titles as a guest. I'm new here though so someone could probably explain the actual intention better. I did personally feel that it could be a good nudge in the right direction.
@willie said: It is weird, I remember seeing an upgrade button in the control panel somewhere, but then couldn't find it when I was also interested in upgrading. I take for granted that we don't get to ask for manual intervention as the process is intended (lol) to be as low hassle as possible at the hosting end.
If it doesn't appear it most likely means the plan dynamically changes and we can't have people hopping in between different sales due to how they're organized.
What happened?
DM your IP.
May I ask how you're 100% sure? It's possible it's related but this is the first report of this I've seen (the 100% correct username and password triggering a login error.)
What happened?
DM your IP.
Yes I can confirm that, coz I also tried another vps' user and pass which worked previously, and also can not login in.
and such info stored in my password vault, google and bitwarden.and I didn't change them.
What happened?
DM your IP.
And for the recently actived Tokyo VPS, I used the billing.virmach.com to bypass the login page to access the control panel. and changed the pass in the acc management page, it does recognize the correct password( if you put a wrong pass it will remind you) and show sucess message.
What happened?
DM your IP.
Can confirm, it also happened to me, reset password -> got email -> get limited by cloudflare -> try login from different ip -> invalid username or password.
Try resetting password several time, same thing happened, triple check credentials.
@VirMach said: I've thought about this and I assume the exclusive offers are meant to have this effect, since you can see the enticing titles as a guest. I'm new here though so someone could probably explain the actual intention better. I did personally feel that it could be a good nudge in the right direction.
Well that would up to @Mason I guess. I'd say that at worst we got a bunch of new members signed up who aren't that interested in becoming steady forum participants. That ties up a few database rows but is basically harmless, so no big deal. It's then mostly a matter of whether you're reasonably happy with how the sale has gone. So I hope it worked out ok from your perspective.
We’ve seen increased activity in other threads, not only this one.
If even 1% of the new users find other threads interesting and contribute in one way or another, we all win.
Activation request. Order ID: 7173497678
My order is 7179813098, Pls help to activate. Thanks.
3 days uptime with 384MB RAM🥳
some benchmark results:
Try this
@VirMach
I can increase your renewal fee if you keep posting your invoice ID here, that's about it.
DM your IP.
Thanks
There is a low memory installation method. My 2 slices:
I don't mind, still can login via clientarea.
My order is 9582631208, Pls help to activate. Thanks.
Order Number is: 3994794875 ,please open it .
https://clients.mrvm.net
我已经购买,需要开启服务器,我的Order Number is:3789306372
@VirMach My Order Number is: 7212795981. Pls help to activate. Thx!
Invoice #1417138
order #561597
thank you!
My order is 561633, Pls help to activate. Thanks.
Invoice #1414421
sir i lost my order number can you active my vps ?
As of now, the CPU steal is an issue on node 035. The Geekbench 5 score of my 3-core VPS is ~2200, which is more like 2 cores.
