A man without pp who have some common sense? Thought it would not be allowed to exist.
What does pp stand for? I assume PayPal?
I assume you assumed quite wrong...
cpu steal only is a problem if it affects the performance of your VM. as you wrote you get a whopping 2200 gb5 multicore score, I fail to see, how this could be a problem. remember it's a shared environment in any case, so 2200 on a 3 vcore machine is an awesome result already.
to add to that, afaik you are not allowed to use all full vcores constantly anyway with Virmach, so we have to assume your use case is one that doesn't need that power at all, which make the percentage in steal a rather cosmetic thing.
TL;DR; what exactly are you complaining about? any real practical or technical issues? or artificial numbers in a graph?
Apologies for not stating my concerns clearly.
In short, with 40% CPU usage from my applications, the CPU steal would easily go above 15%. There's not much room for my apps, considering Virmach allows 50% CPU usage on average.
@realEthanZou said: In short, with 40% CPU usage from my applications, the CPU steal would easily go above 15%. There's not much room for my apps, considering Virmach allows 50% CPU usage on average.
I see. no idea how they count the average but the amount of steal obviously shouldn't count towards your usage.
however, if your apps constantly need that kind of CPU power, I guess you booked the wrong product then. regardless of steal or not, what happens if one your apps suddenly gets a spike due to whatever reason for a longer time period?
all provider with such kind of aup/tos might suspend you then - do you want to risk that? I mean, no idea what your apps are about, but if they are important, in general providers that rely on you for keeping the load low are the wrong choice ... at least my pov.
maybe something is a little off with your expectations ;-) ;-)
@NerdUno said: RackNerd activation takes less than 10 minutes. With VirMach, we're at 2 full days and still waiting. Is this normal behavior?
For this special, it is absolutely to be expected. It says manual activation at the very beginning. If you want RackNerd you know where it is.
Hetzner cpu performance in their shared core cloud product varies and the larger VM's tend to not be that great. They have a dedicated core VM product that costs a lot more, if you need high cpu. Plus of course they have dedicated servers. I always use a dedicated server if I'm something cpu heavy.
Through no fault of my own I did not save the order ID.
According to LowEndSpirit I don't mind placing a new order and waiting for the old one to be refunded automatically after a month.
According to the thread I will get a refund after a month, but according to the comments I will get an activation after some time.
It's been 10 days since I placed the order, so to avoid wasting it, I'd like to know if I'll get an activation or a refund if possible, thanks!
@VirMach
it's been more than two days, the VPS can't be used, several reboots don't work, I'm confused. initially from the first order VPS often restarts itself. and this peak can not be used. sent a ticket but no response. sorry i posted it here. because I'm confused.
the settings are the same as the other 2 vps in virmach. this just confuses me
@vgood said: @VirMach what happen??
Invoice #1404808
Status Unknown
IPv4 Address 1
IP Address 194.xxx.xxx.xx
Virtualization Type (KVM)
Hostname xxxxxxxx
Node RYZE.SJC-Z003.VMS
Server Information
Configurable Options
Additional Information
Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
If it has not booted at all, connect through the console and see if there is an error message. In my case, the install image was messed up so I used a different one.
how to enter the console, obviously vps is off, from solusvm error (unknown) An error occurred processing your request. The host is currently unavailable. Please try again later
can't do anything. several reboots from the client area and solusvm didn't work either. do not know until when
@xiaosan628 said:
I don't want to wait. The ticket has not been processed. Your staff close ticket order directly!!
Please arrange a refund to my bank account, thank you!
This is a payment receipt for Invoice 1413353 sent on 04/05/2022
Ryzen Special 1536 - PuzzledGainsboro-VM (04/05/2022 - 04/04/2024) $40.00 USD
Selection Location: Tokyo, JP - Koto Ward, Tokyo -
Recurring price has been increased $5 for the last ticket created and $5 more for the other three tickets, I've discounted the increase by $5 (you were previously charged $5 for one of them, so total three instead of four increases.)
Invoice #1404808
Status Unknown
IPv4 Address 1
Hostname xxxxxxxx
Server Information
I think Nginx went down, taking a look. We don't yet have ALL the notifications configured for these new nodes so I do apologize for this not being handled sooner.
@realEthanZou said:
As of now, the CPU steal is an issue on node 035. The Geekbench 5 score of my 3-core VPS is ~2200, which is more like 2 cores.
Replying to you since there was a discussion about this on page 20.
It's not just you benchmarking that's the issue, it's everyone at once. There's a good number of people on these nodes now so even if 5% of them are benchmarking constantly it's enough to cause that level of CPU steal. It's calmed down since your post though. Right now we're at 50% or so CPU usage. When you made the post we were probably closer to 80%
(edit) But now more creations are being processed so I'd imagine some steal to go up again until it calms down again.
Invoice #1404808
Status Unknown
IPv4 Address 1
Hostname xxxxxxxx
Server Information
I replied to this above, this looks like it had CPU lockups potentially. Still looking.
@VirMach
OK, I'm waiting for it to return to normal. I hope it's back to normal soon
@VirMach said: think Nginx went down, taking a look. We don't yet have ALL the notifications configured for these new nodes so I do apologize for this not being handled sooner.
This seems to be having the same issue SJC007 recently had. I'm trying to remember what batch of hardware this was that sent out because it could start coming up as an issue with the entire San Jose batch if it's not just isolated to a single machine. I may modify BIOS settings and mess with something software side because it's vaguely what I remember happening in relation to Hugepages.
6 days ago, before the VPS was off, the VPS often restarted itself at random times, sometimes 24 hours and sometimes 12 hours restarting itself, even though the normal use of CPU RAM is only about 20%. it looks like a serious problem like in the handwere including in the bios as you said. hopefully it will be resolved soon, cheers
@VirMach said: This seems to be having the same issue SJC007 recently had. I'm trying to remember what batch of hardware this was that sent out because it could start coming up as an issue with the entire San Jose batch if it's not just isolated to a single machine. I may modify BIOS settings and mess with something software side because it's vaguely what I remember happening in relation to Hugepages.
thanks @VirMach
vps back online,
I want to ask, the reinstall menu doesn't have any images yet, is it really not set yet?
even though this is necessary for us
thank you
Hello, I have purchased a vps in Tokyo for a long time, please turn it on for me
order number: #1802504375
My Invoice #1419487. Please approve it for me.
many thanks
I come from Vietnam. SEO service for Vietnamese companys
This is a payment receipt for Invoice 1415672 sent on 04/09/2022
Whose fault do you think it was, if not yours?
My order is #560999, Pls help to activate. Thanks.
Sorry I made a typo!
It's my fault!!!
@VirMach
SJCZ003 might be down, worked yesterday... for me
Does the high percentage of CPU steal occur in Tokyo only or is it occurring in other locations as well?
Thankyou for your comment. We have activated double your services.
Case #5
(edit) Uhoh, looks worse.
Looks like it froze. Rebooting and checking logs.
I missed your original post so I apologize for that but yes, it's normal behavior for manual activation.
Cancelled & refunded. This is a storage offer from another website. Sorry but I can't have people migrating here to spam their order IDs from that.
@VirMach
(edit) I've applied the THP disabler on this node to see if it improves.
Order #1861408866, thanks in advance.
(PayPal was so automated I thought it was broken and also added funds by another method, so I guess that's my renewal funds taken care of... lol)
storage vps preorder is still available?
I thought it was over on OGF and you stopped accepting preorder here.
Thanks for the special offer, as requested here is my order ID: 6118963062
thanks @VirMach
vps back online,
thank you
