VirMach Tokyo 21.85/USD/y (pre-order).. finally! orz
Network seems to be under somewhat high load, apart from mediocre speeds, ping isn't exactly stable either.. perhaps everyone else is running YABS too right now?
Anyway, it's more than enough for idling
Ubuntu 22.04 installer, loaded via either netboot.xyz or grub loopback, does not work in 1GB RAM.
Hence, I install Ubuntu 20.04 cleanly and then immediately run do-release-upgrade -d.
Interested in adding this to the repo. Seems to work fine on all the machines I've tested. Would you like to PR the changes so that you're credited? Stick the three lines in just above the Processor line I'm thinking.
This is a Google Cloud instance.
Google Cloud charges $6,000+/month for the disk alone. Only the disk. I am not joking.
With "Extreme" persistent disk:
With "SSD" disk:
So yes, I just ran a fio test on a $6,000+/month disk and well
The funny part is that the server itself is cheaper, you're able to get 768GB of actual RAM for cheaper than this 500GB "extreme" disk
I guess I really should think about letting this lapse this year, even if it's just to get the same thing again, as the current KS-1 has double the RAM and disk for the same price. But I've had this for about 9 years and it'd be like getting rid of an old pet or something!
Come on, post yabs with provider/pricing etc.
ssd nodes
Dev Tools heaven like wp, vanilla, phpbb hash tools
There’s your answer. Try contacting support I guess
AMD EPYC™ L from server-factory.com
Basic System Information: --------------------------------- Processor : AMD EPYC 7702P 64-Core Processor CPU cores : 8 @ 1999.999 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.4 GiB Swap : 0.0 KiB Disk : 393.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 128.01 MB/s (32.0k) | 2.70 GB/s (42.2k) Write | 128.34 MB/s (32.0k) | 2.72 GB/s (42.5k) Total | 256.35 MB/s (64.0k) | 5.42 GB/s (84.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 9.03 GB/s (17.6k) | 12.92 GB/s (12.6k) Write | 9.51 GB/s (18.5k) | 13.78 GB/s (13.4k) Total | 18.55 GB/s (36.2k) | 26.71 GB/s (26.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.03 Gbits/sec | 988 Mbits/sec Online.net | Paris, FR (10G) | 1.03 Gbits/sec | busy WorldStream | The Netherlands (10G) | 1.04 Gbits/sec | 992 Mbits/sec WebHorizon | Singapore (400M) | 415 Mbits/sec | 406 Mbits/sec Clouvider | NYC, NY, US (10G) | 401 Mbits/sec | 945 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 421 Mbits/sec | 884 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 359 Mbits/sec | 875 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.03 Gbits/sec | 977 Mbits/sec Online.net | Paris, FR (10G) | 1.03 Gbits/sec | 970 Mbits/sec WorldStream | The Netherlands (10G) | 1.04 Gbits/sec | 976 Mbits/sec WebHorizon | Singapore (400M) | 467 Mbits/sec | 448 Mbits/sec Clouvider | NYC, NY, US (10G) | 80.2 Mbits/sec | 612 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 353 Mbits/sec | 887 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1016 Multi Core | 4097 Full Test | https://browser.geekbench.com/v5/cpu/14444333central.so rebench
AlphaVPS OVZ Sofia
Mon Apr 25 20:37:12 CEST 2022 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2666 v3 @ 2.90GHz CPU cores : 2 @ 2824.066 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.0 GiB Swap : 0.0 KiB Disk : 14.6 GiB Uptime : 0 days, 3 hours, 10 minutes. Distro : Debian GNU/Linux 11 (bullseye) Kernel : 4.19.0 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 120.90 MB/s (30.2k) | 372.37 MB/s (5.8k) Write | 121.22 MB/s (30.3k) | 374.33 MB/s (5.8k) Total | 242.12 MB/s (60.5k) | 746.71 MB/s (11.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 538.16 MB/s (1.0k) | 544.26 MB/s (531) Write | 566.76 MB/s (1.1k) | 580.51 MB/s (566) Total | 1.10 GB/s (2.1k) | 1.12 GB/s (1.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 905 Mbits/sec | 581 Mbits/sec Online.net | Paris, FR (10G) | 913 Mbits/sec | 608 Mbits/sec WorldStream | The Netherlands (10G) | 916 Mbits/sec | 456 Mbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 856 Mbits/sec | 286 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 783 Mbits/sec | 181 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 757 Mbits/sec | 288 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 743 Mbits/sec | 770 Mbits/sec Online.net | Paris, FR (10G) | 761 Mbits/sec | 759 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 559 Mbits/sec | 631 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 520 Mbits/sec | 512 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 784 Multi Core | 1538 Full Test | https://browser.geekbench.com/v5/cpu/14548059Main , ServerStatus , slackvpn <-- openVPN auto install script for Slackware 15
HostTheBest.com - Utah NVME VPS - Plan 1 / UTAHKVM4GB - $4.99 first month, then $9.99/month (not worth it!)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-02-18 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 26 Apr 2022 04:46:04 PM UTC Basic System Information: --------------------------------- Processor : QEMU Virtual CPU version 2.5+ CPU cores : 6 @ 2299.996 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 4.0 GiB Disk : 55.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 193.94 MB/s (48.4k) | 2.33 GB/s (36.5k) Write | 194.45 MB/s (48.6k) | 2.34 GB/s (36.7k) Total | 388.39 MB/s (97.0k) | 4.68 GB/s (73.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 8.54 GB/s (16.6k) | 6.48 GB/s (6.3k) Write | 9.00 GB/s (17.5k) | 6.91 GB/s (6.7k) Total | 17.54 GB/s (34.2k) | 13.40 GB/s (13.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.16 Gbits/sec | 1.39 Gbits/sec Online.net | Paris, FR (10G) | 1.14 Gbits/sec | 719 Mbits/sec WorldStream | The Netherlands (10G) | 1.16 Gbits/sec | 1.21 Gbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 2.68 Gbits/sec | 314 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 2.97 Gbits/sec | 3.30 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 5.22 Gbits/sec | 520 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3097 Multi Core | 12566 Full Test | https://browser.geekbench.com/v4/cpu/16540308 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 659 Multi Core | 3088 Full Test | https://browser.geekbench.com/v5/cpu/14565101VirMach Tokyo 21.85/USD/y (pre-order).. finally! orz
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-02-18 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Apr 27 13:51:31 UTC 2022 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 2 @ 3693.062 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.4 GiB Swap : 0.0 KiB Disk : 48.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 294.98 MB/s (73.7k) | 1.36 GB/s (21.2k) Write | 295.76 MB/s (73.9k) | 1.36 GB/s (21.4k) Total | 590.74 MB/s (147.6k) | 2.73 GB/s (42.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.27 GB/s (4.4k) | 2.91 GB/s (2.8k) Write | 2.39 GB/s (4.6k) | 3.11 GB/s (3.0k) Total | 4.67 GB/s (9.1k) | 6.02 GB/s (5.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | busy | busy Online.net | Paris, FR (10G) | 54.0 Mbits/sec | 58.0 Mbits/sec WorldStream | The Netherlands (10G) | 82.5 Mbits/sec | 49.3 Mbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | busy | 49.2 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 132 Mbits/sec | 51.9 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | busy | 58.3 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 869 Multi Core | 1374 Full Test | https://browser.geekbench.com/v5/cpu/14581547Contribute your idling VPS/dedi (link), Android (link) or iOS (link) devices to medical research
SoYouStart SYS-2-SSD-32 (Xeon D1541, 2 x 450 NVMe, GRA datacenter)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-02-18 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Apr 28 14:48:08 UTC 2022 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz CPU cores : 16 @ 800.018 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.2 GiB Swap : 1024.0 MiB Disk : 411.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 403.62 MB/s (100.9k) | 468.03 MB/s (7.3k) Write | 404.68 MB/s (101.1k) | 470.49 MB/s (7.3k) Total | 808.30 MB/s (202.0k) | 938.53 MB/s (14.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 456.61 MB/s (891) | 464.64 MB/s (453) Write | 480.87 MB/s (939) | 495.58 MB/s (483) Total | 937.48 MB/s (1.8k) | 960.23 MB/s (936) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 262 Mbits/sec | 8.76 Gbits/sec Online.net | Paris, FR (10G) | busy | busy WorldStream | The Netherlands (10G) | 262 Mbits/sec | 9.26 Gbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 243 Mbits/sec | 1.47 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 236 Mbits/sec | 1.34 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 243 Mbits/sec | 1.04 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 259 Mbits/sec | 2.87 Gbits/sec Online.net | Paris, FR (10G) | busy | 2.52 Gbits/sec WorldStream | The Netherlands (10G) | 258 Mbits/sec | 2.74 Gbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 247 Mbits/sec | 1.63 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 234 Mbits/sec | 1.01 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 756 Multi Core | 5373 Full Test | https://browser.geekbench.com/v5/cpu/14601583Nexril 1GB Dallas, Ubuntu 20.04 vs Ubuntu 22.04: Geekbench score increased by 4~5%.
Link to previous benchmark: https://talk.lowendspirit.com/discussion/comment/58999/#Comment_58999
Ubuntu 20.04 (zram swap, ext4 filesystem)
sunny@vps6:~$ curl -sL yabs.sh | bash -s -- -r # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-02-18 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue 26 Apr 2022 09:38:56 PM CDT Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.8 MiB Swap : 1000.4 MiB Disk : 14.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 439.90 MB/s (109.9k) | 2.93 GB/s (45.9k) Write | 441.06 MB/s (110.2k) | 2.95 GB/s (46.1k) Total | 880.97 MB/s (220.2k) | 5.89 GB/s (92.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.75 GB/s (5.3k) | 2.84 GB/s (2.7k) Write | 2.90 GB/s (5.6k) | 3.03 GB/s (2.9k) Total | 5.66 GB/s (11.0k) | 5.87 GB/s (5.7k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 162 Mbits/sec | 862 Mbits/sec Online.net | Paris, FR (10G) | 458 Mbits/sec | 864 Mbits/sec Clouvider | NYC, NY, US (10G) | 916 Mbits/sec | 921 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 865 Mbits/sec | 841 Mbits/sec Online.net | Paris, FR (10G) | 866 Mbits/sec | 860 Mbits/sec Clouvider | NYC, NY, US (10G) | 912 Mbits/sec | 912 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1335 Multi Core | 1261 Full Test | https://browser.geekbench.com/v5/cpu/14571928Ubuntu 22.04 (zram swap, xfs filesystem)
do-release-upgrade -d.sunny@vps6:~$ curl -sL yabs.sh | bash -s -- -r # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-02-18 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Apr 28 07:18:32 PM CDT 2022 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.622 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 971.1 MiB Swap : 997.6 MiB Disk : 15.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 341.66 MB/s (85.4k) | 2.94 GB/s (45.9k) Write | 342.56 MB/s (85.6k) | 2.95 GB/s (46.2k) Total | 684.22 MB/s (171.0k) | 5.89 GB/s (92.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.69 GB/s (5.2k) | 2.94 GB/s (2.8k) Write | 2.83 GB/s (5.5k) | 3.13 GB/s (3.0k) Total | 5.52 GB/s (10.7k) | 6.07 GB/s (5.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 141 Mbits/sec | 870 Mbits/sec Online.net | Paris, FR (10G) | busy | 873 Mbits/sec Clouvider | NYC, NY, US (10G) | 875 Mbits/sec | 923 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 869 Mbits/sec | 863 Mbits/sec Online.net | Paris, FR (10G) | 870 Mbits/sec | 863 Mbits/sec Clouvider | NYC, NY, US (10G) | 915 Mbits/sec | 913 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1407 Multi Core | 1315 Full Test | https://browser.geekbench.com/v5/cpu/14608842Interested in adding this to the repo. Seems to work fine on all the machines I've tested. Would you like to PR the changes so that you're credited? Stick the three lines in just above the Processor line I'm thinking.
Humble janitor of LES
Proud papa of YABS
@yoursunny gets a credit of ten push ups or an extra month of storage on Lunarmach Eclipse plan for his work.
Basic System Information: --------------------------------- Processor : 12th Gen Intel(R) Core(TM) i5-12500 CPU cores : 12 @ 4238.564 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.6 GiB Swap : 0.0 KiB Disk : 952.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.99 GB/s (499.1k) | 2.84 GB/s (44.5k) Write | 2.00 GB/s (500.4k) | 2.86 GB/s (44.7k) Total | 3.99 GB/s (999.5k) | 5.71 GB/s (89.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.76 GB/s (7.3k) | 3.92 GB/s (3.8k) Write | 3.96 GB/s (7.7k) | 4.18 GB/s (4.0k) Total | 7.72 GB/s (15.0k) | 8.11 GB/s (7.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 932 Mbits/sec | 941 Mbits/sec Online.net | Paris, FR (10G) | 937 Mbits/sec | 945 Mbits/sec WorldStream | The Netherlands (10G) | 935 Mbits/sec | 942 Mbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 890 Mbits/sec | 491 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 859 Mbits/sec | 393 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 837 Mbits/sec | 339 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 920 Mbits/sec | 920 Mbits/sec Online.net | Paris, FR (10G) | 924 Mbits/sec | 930 Mbits/sec WorldStream | The Netherlands (10G) | 921 Mbits/sec | 928 Mbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 879 Mbits/sec | 541 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 827 Mbits/sec | 301 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 8022 Multi Core | 37522 Full Test | https://browser.geekbench.com/v4/cpu/16542005 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1887 Multi Core | 9345 Full Test | https://browser.geekbench.com/v5/cpu/14615619No need for PR you can add it, ill leave the place for you where you think it will fit best
Cheers
Sat Apr 30 09:12:32 UTC 2022 Basic System Information: --------------------------------- Processor : AMD EPYC 7B12 CPU cores : 96 @ 2249.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 47.1 GiB Swap : 0.0 KiB Disk : 9.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 30.16 MB/s (7.5k) | 246.80 MB/s (3.8k) Write | 30.17 MB/s (7.5k) | 248.10 MB/s (3.8k) Total | 60.34 MB/s (15.0k) | 494.90 MB/s (7.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 235.43 MB/s (459) | 232.45 MB/s (227) Write | 247.94 MB/s (484) | 247.93 MB/s (242) Total | 483.38 MB/s (943) | 480.39 MB/s (469) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.41 Gbits/sec | 1.78 Gbits/sec Online.net | Paris, FR (10G) | 2.06 Gbits/sec | 1.82 Gbits/sec WorldStream | The Netherlands (10G) | 1.77 Gbits/sec | 1.80 Gbits/sec WebHorizon | Singapore (400M) | busy | busy Clouvider | NYC, NY, US (10G) | 6.57 Gbits/sec | 4.65 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 4.92 Gbits/sec | 3.78 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 3.19 Gbits/sec | 3.95 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | busy Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 997 Multi Core | 29548 Full Test | https://browser.geekbench.com/v5/cpu/14633926This looks like the work of SuperVirBot.
96 cores, with 997 each = 29k? uh wat.
GeekBench might not scale up far enough for 96 cores, maybe ~32 is the max it's written for.
Anyway: VirMach JP 4GB special
# # # # # # # # # # # # # # # # # # # # Benchy v1.5 # # https://github.com/L1so/benchy # # AIO Benchmarking tool # # # # # # # # # # # # # # # # # # # # # 30 Apr 2022 22:39 EDT # # # # # # # # # # # # # # # # # # # # Server Information --------------------- OS : Debian GNU/Linux 11 (bullseye) Uptime : 2 Days, 22 Hours, 58 Minute, 38 Seconds Location : Japan CPU : AMD Ryzen 9 5900X 12-Core Processor Core : 3 @ 3693.062 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Virt : kvm Disk & Memory Usage --------------------- Disk : 79.60 GiB Disk Usage : 5.30 GiB (8% Used) Mem : 3.83 GiB Mem Usage : 116 MB (3% Used) Swap : 255.99 MiB Disk Performance Check (ext4 on /dev/vda1) +---------------------------------------------------------------------------+ | Size | Read | Write | Total | IOPS (R,W,T) | +===========================================================================+ | 4k | 233.77 MB/s | 234.39 MB/s | 468.16 MB/s | 59.8k | 60.0k | 119.8k | | 64k | 787.74 MB/s | 791.89 MB/s | 1.54 GB/s | 12.6k | 12.7k | 25.3k | | 512k | 1.25 GB/s | 1.32 GB/s | 2.57 GB/s | 2.6k | 2.7k | 5.3k | | 1m | 1.48 GB/s | 1.58 GB/s | 3.07 GB/s | 1.5k | 1.6k | 3.1k | +---------------------------------------------------------------------------+ Network Performance Test (Region: Asia) +--------------------------------------------------------------------------------------+ | Prot. | Provider | Location | Send | Receive | Latency | +======================================================================================+ | IPv4 | Uztelecom | Tashkent, UZ | 283 Mbits/sec | 75.9 Mbits/sec | 250 ms | | | Biznet | Jakarta, ID | 143 Mbits/sec | 50.4 Mbits/sec | 104 ms | +--------------------------------------------------------------------------------------+ +-----------------------------------------------+ | Geekbench 5.4.4 Tryout for Linux x86 (64-bit) | +===============================================+ | Single Core | 827 | | Multi Core | 1890 | +-----------------------------------------------+ | https://browser.geekbench.com/v5/cpu/14648705 | +-----------------------------------------------+ | Benchy time spent | 4 Minutes 58 Seconds | +-----------------------------------------------+ [... and a YABS for more network tests] iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 275 Mbits/sec | 104 Mbits/sec Online.net | Paris, FR (10G) | 402 Mbits/sec | 151 Mbits/sec Hybula | The Netherlands (40G) | 414 Mbits/sec | 385 Mbits/sec WorldStream | The Netherlands (10G) | busy | 145 Mbits/sec WebHorizon | Singapore (400M) | 665 Mbits/sec | 417 Mbits/sec Clouvider | NYC, NY, US (10G) | 145 Mbits/sec | 106 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 50.3 Mbits/sec | 194 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 233 Mbits/sec | 116 Mbits/secBut this is benchy not yabs 👀
jk
Hostcram
Killer Core: KVM-3C
Oneprovider (Dedicated Cloud Instance) London
EPYC 7401P (2 vCore)
8GB DDR4
125GB SSD(NVMe)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-04-30 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 05 May 2022 09:05:46 PM CEST Basic System Information: --------------------------------- Processor : AMD EPYC 7402 24-Core Processor CPU cores : 2 @ 2799.902 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 512.0 MiB Disk : 122.5 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 265.11 MB/s (66.2k) | 1.78 GB/s (27.9k) Write | 265.81 MB/s (66.4k) | 1.79 GB/s (28.0k) Total | 530.92 MB/s (132.7k) | 3.58 GB/s (55.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.34 GB/s (4.5k) | 2.54 GB/s (2.4k) Write | 2.47 GB/s (4.8k) | 2.70 GB/s (2.6k) Total | 4.82 GB/s (9.4k) | 5.24 GB/s (5.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 298 Mbits/sec | 8.49 Gbits/sec Online.net | Paris, FR (10G) | 296 Mbits/sec | 6.44 Gbits/sec Hybula | The Netherlands (40G) | 296 Mbits/sec | 13.0 Gbits/sec Clouvider | NYC, NY, US (10G) | 282 Mbits/sec | 2.52 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 25.3 Mbits/sec | 76.7 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 267 Mbits/sec | 1.37 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 941 Multi Core | 1844 Full Test | https://browser.geekbench.com/v5/cpu/14736481Basic System Information: --------------------------------- Processor : AMD EPYC 7B12 CPU cores : 96 @ 2249.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 755.9 GiB Swap : 0.0 KiB Disk : 492.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 226.98 MB/s (56.7k) | 616.82 MB/s (9.6k) Write | 227.58 MB/s (56.8k) | 620.06 MB/s (9.6k) Total | 454.56 MB/s (113.6k) | 1.23 GB/s (19.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.11 GB/s (2.1k) | 1.12 GB/s (1.0k) Write | 1.17 GB/s (2.2k) | 1.19 GB/s (1.1k) Total | 2.28 GB/s (4.4k) | 2.32 GB/s (2.2k)This is a Google Cloud instance.
With "SSD" disk:
Sir, this is a Wendy's
Proud papa of YABS
Appreciate it, mate! Just added it into the script and pushed the changes live
Proud papa of YABS
$ bash yabs.sh # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-05-06 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 6 May 22:40:47 BST 2022 Basic System Information: --------------------------------- Uptime : 165 days, 12 hours, 0 minutes Processor : Intel(R) Atom(TM) CPU N2800 @ 1.86GHz CPU cores : 4 @ 1333.317 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 513.0 MiB Disk : 457.7 GiB Distro : Debian GNU/Linux 10 (buster) Kernel : 5.8.0-0.bpo.2-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 337.00 KB/s (84) | 4.68 MB/s (73) Write | 355.00 KB/s (88) | 4.93 MB/s (77) Total | 692.00 KB/s (172) | 9.62 MB/s (150) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 21.82 MB/s (42) | 25.43 MB/s (24) Write | 23.33 MB/s (45) | 28.07 MB/s (27) Total | 45.15 MB/s (87) | 53.51 MB/s (51) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 94.2 Mbits/sec | 94.1 Mbits/sec Online.net | Paris, FR (10G) | busy | busy Hybula | The Netherlands (40G) | 94.1 Mbits/sec | 94.1 Mbits/sec Clouvider | NYC, NY, US (10G) | 92.0 Mbits/sec | 92.6 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 89.4 Mbits/sec | 76.9 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 89.3 Mbits/sec | 89.7 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 92.9 Mbits/sec | 92.8 Mbits/sec Online.net | Paris, FR (10G) | 92.8 Mbits/sec | busy Hybula | The Netherlands (40G) | 92.8 Mbits/sec | 92.8 Mbits/sec Clouvider | NYC, NY, US (10G) | 90.7 Mbits/sec | 91.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 87.9 Mbits/sec | 88.6 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 109 Multi Core | 300 Full Test | https://browser.geekbench.com/v5/cpu/14756744I guess I really should think about letting this lapse this year, even if it's just to get the same thing again, as the current KS-1 has double the RAM and disk for the same price. But I've had this for about 9 years and it'd be like getting rid of an old pet or something!
hosthatch lax new bench
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2022-05-06 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 07 May 2022 01:59:33 PM EDT Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 1 minutes Processor : AMD Ryzen 9 3950X 16-Core Processor CPU cores : 1 @ 3499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.8 GiB Swap : 256.0 MiB Disk : 34.2 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-10-amd64 fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 228.17 MB/s (57.0k) | 356.14 MB/s (5.5k) Write | 228.77 MB/s (57.1k) | 358.02 MB/s (5.5k) Total | 456.94 MB/s (114.2k) | 714.16 MB/s (11.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.22 GB/s (4.3k) | 3.26 GB/s (3.1k) Write | 2.34 GB/s (4.5k) | 3.48 GB/s (3.3k) Total | 4.56 GB/s (8.9k) | 6.74 GB/s (6.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 156 Mbits/sec | 766 Mbits/sec Online.net | Paris, FR (10G) | 879 Mbits/sec | 686 Mbits/sec Hybula | The Netherlands (40G) | 331 Mbits/sec | 506 Mbits/sec Clouvider | NYC, NY, US (10G) | 494 Mbits/sec | 216 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 815 Mbits/sec | 267 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 704 Mbits/sec | 268 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1058 Multi Core | 1069 Full Test | https://browser.geekbench.com/v5/cpu/14773171VirMach - Amsterdam - $11.58 USD Annually
just patiently waiting for mine 😎
