★ VirMach ★ RYZEN ★ NVMe ★★ $30/2YR- 768MB ★ $40/2YR - 1.5GB ★ $50/2YR - 2.5GB ★ $70/2YR - 4GB ★ LES
1313234363768
  • edited May 2022
    @AlwaysSkint said:
    You fellas are a bad influence. Deposited 6 bucks (mein Gott, the exchange rate is crap in PayPal!) and initiated a NY to NYC migration without data. Just for "shits & giggles".
    Certainement qui est en droit de vous rendre absurde, est en droit de vous rendre injuste - Voltaire
  • edited May 2022
    @VirMach Total awesomeness! =)
    BF 2021 $17.01/yr NYKVM -> NYC (NYCB014)
    Uptime     : 0 days, 0 hours, 14 minutes
    CPU cores  : 2 @ 3500.000 MHz
    RAM        : 3.3 GiB
    Swap       : 256.0 MiB
    Disk       : 34.6 GiB
    Kernel     : 5.10.0-8-amd64
    Read       | 367.95 MB/s  (91.9k) | 1.34 GB/s    (21.0k)
    Write      | 368.92 MB/s  (92.2k) | 1.35 GB/s    (21.1k)
    Total      | 736.87 MB/s (184.2k) | 2.69 GB/s    (42.1k)
    Read       | 2.46 GB/s     (4.8k) | 2.84 GB/s     (2.7k)
    Write      | 2.59 GB/s     (5.0k) | 3.03 GB/s     (2.9k)
    Total      | 5.06 GB/s     (9.8k) | 5.88 GB/s     (5.7k)
    Clouvider       | London, UK (10G)          | 184 Mbits/sec   | 146 Mbits/sec
    Online.net      | Paris, FR (10G)           | 387 Mbits/sec   | 129 Mbits/sec
    Hybula          | The Netherlands (40G)     | 255 Mbits/sec   | 738 Mbits/sec
    Clouvider       | NYC, NY, US (10G)         | 737 Mbits/sec   | 849 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 463 Mbits/sec   | 385 Mbits/sec
    Clouvider       | Los Angeles, CA, US (10G) | 445 Mbits/sec   | 268 Mbits/sec
    Geekbench 5 Benchmark Test:
    Single Core     | 931
    Multi Core      | 1712
    Full Test       | https://browser.geekbench.com/v5/cpu/14821300
    There appears to be a lack of a netboot option, or I couldn't see the wood for the trees. Other than that, most pleased.
    Just need my AMS node to become unstuck. ;)
  • @FrankZ said:
    @skorous - Yea, I thought you would have received one of those emails titled "Your cloud service is almost ready" with the IP info.
    Yeah, I'll wait a while and see what happens. Both my Seattle and Atlanta box went fine. Just unfortunate this box is/was my dns master so I'm a little antsy.
    Sorry for assuming.
    Nope, no need. :)
  • edited May 2022
    I have a question to ask:
    After the order number is displayed after payment, click the button in the customer area. There is no information about this purchase in the customer area. I thought this might be related to the inexplicable addition of several subordinate accounts with the same name when I created the account (let me choose which account when logging in. Generally, I choose the first account), but I tried. All subordinate accounts have no relevant information. The only relevant information is the order number given to me after payment.Is this normal? If it's not normal, what should I do?
    If necessary, I can provide screenshots of Alipay payment vouchers
    my order number is 7174175706
    (my English is not very good, so I use machine translation)
  • Order #565257 Approved
  • edited May 2022
    Hi @axty
    Let us try to double check a few things as this is the first time I have heard of a situation like this.
    If you check in the billing panel under Services tab, My Services and then check all the pages, is there no service for this order marked "Pending" or "Rejected"?
    and
    If you check under the Billing tab, My invoices is there an invoice for this purchase, and is it marked "Paid", or "Cancelled" ?
    @AlwaysSkint - Good to see that worked out for you. Have you been rubbing Bobby’s nose ?
    Thanked by (1)AlwaysSkint
  • edited May 2022
    Hi @axty
    and
    I checked that there is only one service I have purchased and used normally in the My services tab.
    In the My invoices tab, there is
    only the bill I paid for the normal service at that time + the invoice that was automatically cancelled because it was not paid in time in OGF.
    It sounds incredible - he mysteriously disappeared except for the order number and the voucher of my payment method.
  • @FrankZ said:
    How big is it supposed to be? It looks like it's 80gig.
    I think he is talking about the 15 GB that it shows in the top part of the screen shot.
    @xuweidiy - Since the disk is showing 80GB have you tried the "extent volume" option?
    @skorous said: It's weird. My NY vps that was on one of the nodes being migrated is now on Ryzen but my IP didn't change so I can't communicate with anything. Pinging some random local IPs it appears that I'm not alone either ....
    Have you tried manually changing to the new IP and gateway in the network config of your VPS via VNC, and then rebooting? You should set the network config to static and not use dhcp to see if this will work.
    I expect that the migrate script has gone fubar and the developer is trying to get it straitened out.
    It has to be a pita to develop a migrate script for all the different packages that virbot made over the years.
    There is a problem with the WINDOWS system template. After reinstallation, it is only 14G, and it cannot be expanded or compressed.
  • edited May 2022
    @axty - Thank you for posting all the relevant info and screen shots.
    Now we can tag @VirMach so he can take a look.
    I expect that VirMach will fix it or refund you when he gets a chance, so you should not worry.
    Thanked by (1)ZA_capetown
    Thank you very much! Have a nice day!
  • Is your place now, SanJose, is the internet network back to normal? on my vps it's still slow and very annoying so far. it's a long way from the first time the vps is active, it's very good and fast. Very sad, there has been no response from VirMach regarding this. for the LA server @VirMach has also reported rescheduling several times and who knows when it will be ready.
    @TrueBlumfeld said:
    @vgood said:
    me too, the LAN has been collapsing for two days..
  • Order #1414627
    @TrueBlumfeld said:
    just test ping 8.8.8.8 , almost unavailable (loss 33% ,average respond time 1114 ms
    @TrueBlumfeld said:
  • edited May 2022
    When will my Tokyo server be available?
    It's been almost a month since I paid and the order has been on hold. I haven't been rushed, I logged on to the website every day to see if the server status is on, but unfortunately nothing has changed, this endless waiting is breaking my spirit and I don't see any hope. I hope Virmach team can solve my problem and tell me when I can use Tokyo server.
    My Order Number is: 9423759481
    My English is not very good, so I used the machine translation.
  • edited May 2022
    Wow, still confused, the problem is not finished. I don't know what Virmach's side has yet to respond to, problem solving always comes and I don't know how long.
    I've been wanting 2 months and haven't been able to maximize this @VirMach ryzen VPS, and the problems always come up differently.
    very sad
    **edit what about the others in this forum
    @TrueBlumfeld
  • @VirMach Can you not make customers think you are such a junk company? How many people will be cheated? No refund. It took a long time to start up. It couldn't be connected within a few days after starting up. There was no after-sales service! In addition to licking the dog, does this post dare to tell the truth?Can forum management drive out such garbage companies?
  • The worst VPS is Virmach, how did you do it?
  • @xiaosan628 said:
    @VirMach Can you not make customers think you are such a junk company? How many people will be cheated? No refund. It took a long time to start up. It couldn't be connected within a few days after starting up. There was no after-sales service! In addition to licking the dog, does this post dare to tell the truth?! ... Can forum management drive out such garbage companies?
    This review was brought to you by Angry Dad (TM)
  • edited May 2022
    I don't think it has anything to do with you, if you're going to war, I just think the enemy I'm facing might be a dog
    edited May 2022
    oh please. your just a strawberry hiding behind keyboard talking about war.
    what do you do for training, lifting water bottle to drink watching cartoon?
  • edited May 2022
    Ban 'em, ban 'em all! :#
    (Translate that.)
  • bdlbdl OG
    edited May 2022
    Request a refund, it will be better for your blood pressure/health.
    (Translate that.)
  • Here's a big bone for you
  • edited May 2022
    @bdl Even has the speeling correct. ;)
    @cybertech said: you're just a strawberry..
    "Get it right, get it right" - the mantra from my French teacher. Otherwise, spot on. :)
    @xiaosan628 said: Here's a big bone for you
    Are MJJ actually capable of that?
    Thanked by (2)bdl FrankZ
  • Don't be stingy with your bones. Give them what they deserve@virmach!Maybe my Chinese is better than yours, it's not surprising. What is the point of caring about the details? What does that mean?
    m8, u know i jus don care right 🤭
    edited May 2022
    you English weak. why buy virmach. virmach many detail.
    simple, you dont buy service machine. better to buy bone eat. big bone big eat. bone cheap, bone good. buy bone.
  • yup
    Here's a picture of a Happy Dog plane for you
  • For those of you who are upset about the issues that you are facing with your VirMach Special. I do understand that you are frustrated and your expectations have not been met. All I say is that complaining about it here will not make it any better. VirMach is not a place where the squeaky wheel gets the oil. Explain your problem with enough details in a reasonable way and it will get resolved eventually. I say eventually, because these are not normal times for VirMach and resolutions of big issues are going to happen before individual requests. Complain and start name calling and you will probably be dropped to the bottom of the to do list. It's your choice how you want to deal with it. I do not work for VirMach, but have been a customer for seven years and have many services with VirMach. I am facing some of the same issues you are but I do not complain because VirMach has been a great value for me and just keeps getting better as the years go by so I am grateful not upset. I also know that Virmach is working many, many hours trying to resolve all the issues and even if I do not see the results today I have confidence that it will be resolved as soon as is possible, which is all I can ask.
    Have a good day and now you can feel free to flame me.
