★ VirMach ★ RYZEN ★ NVMe ★★ $30/2YR- 768MB ★ $40/2YR - 1.5GB ★ $50/2YR - 2.5GB ★ $70/2YR - 4GB ★ LES
16263646668
  • I just want to login, but I am stuck with the Cloudflare captcha page forever, solving infinite captcha...
    "Humanity is f*cked up" - Jay
  • @bakageta said:
    I decided to give alma's elevate util a try instead of bothering anyone with a ticket, seems to have gone fine. One interesting thing I've noticed, my old dedi had a pretty typical supermicro micro-atx board and was presumably a 1u, while this new one is a supermicro blade, 12 nodes in a 3u if the model number I see is accurate. That feels like a solid attempt to keep these viable for a while, hopefully I get a nice long run out of this one.
    I've done it several times ( including on this one I just got ) and it's always been fine. It does a pretty good job of telling you what it's not going to handle well so you can prepare.
    Thanked by (1)bakageta
  • edited August 2022
    Got all my boxes, stuck on CentOS though. Reinstalls can take a week, so guess I'll attempt to live with CentOS until then.
    Proof that FAT32 is a robot, can't solve captcha correctly!
  • LAXA032 always "Operation Timed Out After 90001 Milliseconds With 0 Bytes Received" from 08.14
    edited August 2022
    @add_iT said:
    @cybertech said:
    TYOC040 is down
    @VirMach said:
    @cybertech said:
    TYOC040 is down
    This isn't down. If you have issues with your service please make a priority ticket, but at this point it might be best to private message me here. Private message from only @cybertech please, just in case more people are affected.
    same with me, just check from monitor it has been down, also i cannot access panel from billing panel it said timeout
    @Anoneko said:
    @VirMach said:
    @cybertech said:
    TYOC040 is down
    Mine TYOC040 is also offline, basic control timed out and solusvm refuses to respond, monitoring tells me this is the second time in two weeks, the last time it happened was on August 2 and it lasted a day and 5 hours. Oops, I also seem to have sent a ticket after experiencing a similar situation in early July and it is still waiting for staff review.
    By the way the login button on your new home page points to an invalid link.
    mine shows up on WHMCS and SolusVM, but reinstalling it doesn't work. both VM and VNC still offline after clicking reinstall on SolusVM
  • Looks like TYOC031 is being hammered quite hard right now, hope the anti-abuse script finds the culprit soon.
  • Boss please help me, now there are several problems with vps:
    Migration order not completed Ticket#461588
    vps offline for two months
    The vps is about to expire but the renewal bill has not yet been paid.
    Node Name:SJCZ004
    Hostname:DVww-13
    @VirMach
  • @Ademan said: (basically the output from hexdump -C /dev/vda although rescue doesn't have hexdump so I had to download an image of /dev/vda first)
    Try vda1 instead of vda.
    Thanked by (1)Ademan
    Thanks but there is no /dev/vda1 (I presume) because the partition table on /dev/vda is boned. fdisk -l lists no partitions for /dev/vda either.
  • TYO-C040 offline since 2d 17hr ago, and i can't reinstall it
    benchmark score of the vps I've ever had
    @VirMach said:
    @Brueggus said:
    @VirMach said: We finally set up Chicago Hivelocity. Since Chicago servers already got moved, a lot of people will be going there from former Buffalo location but it'll also be available on Ryzen button.
    <3
    You likely have lots of other stuff on your mind right now, but will we get the Ryzen migration button enabled for services that have been auto-migrated to a (more or less) arbitrary location eventually?
    This was already supposed to be enabled but there's so many segmentation of packages and locations that there's obviously some cases where it's not going through. I'm going to see if we can change the filter today to make it more of a free-for-all.
    In case some examples help, I don't see the button for my services with IDs 132295, 616449, 564859 and 52388.
    Need a free NAT LXC? -> https://microlxc.net/
  • same here, storage vps where working and are offline now =(
    opened a ticket but not answer yet
  • Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
  • @dedicados said: storage vps where were working and are offline now
    AlwaysGrammarly
  • CHI2Z028 went down almost 4 hours ago now. It had been solid after the migration to it from a crapcrossing server until now.
  • @AlwaysSkint said: AlwaysGrammarly
    that fixed my server, thanks. stupid
    C'mon now. If you're going to be like that you have to at least use, "Bite my shiny metal ass".
    Thanked by (1)dedicados
  • LOL
  • haha you are right.
    i am kidding dont worry guys.
    Thanked by (1)skorous
    @VirMach said:
    @gogogo said:
    @netrix said: on my side, even paid migration was not automated (#596130 since 26/07/2022).
    me too. @VirMach ach hasn't been around in a long time.
    Migrations to Tokyo end up having a lot of issues and they're vastly more popular than other requests. I don't know if yours is a Tokyo request but if it is then please understand there are hundreds of requests we're trying to catch up with in Tokyo.
    My server in Chicago CHI026 is down and I can't get into the background
    It keeps showing Operation Timed Out After 90001 Milliseconds With 0 Bytes Received
    You moved the server that was working fine in Buffalo to Chicago without my permission, and now it doesn't work at all. What do you want to do? I have nothing to say. Please fix the problem now, thanks
    I opened a ticket #462238
    @VirMach
  • SJC2005 appears to be offline (was ok a few days ago, idk when it went out), and other SJC server (SJC2003?) has been out for quite a while. Client alert area says SJC2008 is having trouble. Altogether it sounds like the whole SJ site is not doing too well.
    uh oh OGF users are coming
    Thanked by (1)AlwaysSkint
    I just hope that virmach's service can be more stable. It was very stable before, but since it was launched in Japan, it has not been normal, and it has been tossing and turning again and again.
  • My VM on TYOC035 has been down for 24hrs+. Seems the whole node is down.
    @VirMach long time no see
  • vyasvyas OGContent Writer
    My new wallpaper :/)
  • Invoice # 1416230, please give me a refund. VPS has been offline for 7 days and I don't want to use it anymore. I hope your VPS can be sold after it is stable. Thank you!
  • Have you read the opening post?
    Refunds? Personal Order Status Updates? Management? Look At My Ticket First?
    No. No. No. No.
  • so virmach is deadpool?
