https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
@Neoon said:
A wild KS-LE in its natural habitat in RBX5
Lol looks like someone at OVH goofed up the bandwidth limits. Limited to 100 mbps outgoing on IPv4, but still get full gig over IPv6. Switch to v6 preferred and that's a sweet rig. The 100 mbit cap is what turned me off originally.
Its all mixed up, one got 2x4TB all 100Mbit the other one 2x2TB with 1Gbit on IPv6.
If you are unlucky you stuck with 100Mbit on all links and 2x2TB.
Also notice the benchmark difference, no idea yet.
Likely cooling.
@Mason and others, can you please explain something to me? m_ _m
I am probably missing some crucial information on YABS and/or hardware, but on first sight, it feels like the math does not add up in the case of some dedicated servers... (like in the last 5 or so YABS results posted here) - namely, it feels like the given core count is either doubled, or the multi core GB5 result is halved...
Is my understanding correct in that
These 'cores' @ YABS are actually CPU threads
But this is the number of "CPUs" seen by the OS (using lscpu or in some other way)
Meanwhile, Geekbench uses CPU cores and not 'cores' (=threads)
@chimichurri said: @Mason and others, can you please explain something to me? m_ _m
Or perhaps does the reason for this lie somewhere completely else? orz
There 'cores' @ YABS are the logical cores seen by the operating system.
Geekbench uses all those logical cores in multicore benchmark.
The point is that the number of logistic cores or threads doesn't determine the multicore performance.
The number of physical cores determines that.
Some CPUs have HT/SMT enabled, where makes the number of logical cores equal to two times number of physical cores.
(The HT/SMT in fact, can be disabled by motherboard settings)
So basically, considering a host node with 12 physical cores, and with HT/SMT enabled,
you will see 24 logical cores.
If you run a multithread program with 4 threads, you will see it is about 4 times faster because 12>4, i.e. you have enough physical cores,
but if you run a multithead program with 16 thread, you will see it is about 12 times fater, because 16>12, i.e. you only have 12 physical cores.
Then considering a 4-core (shared cores) VPS on such host node, which means such VPS can only have 4 threads equivalently.
Since 12>4, you will see the performance is 4 times of single core, as the host node have enough physical cores.
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 73
Multi Core | 123
Full Test | https://browser.geekbench.com/v5/cpu/11388337
Test | Value
Single Core | 84
Multi Core | 157
Full Test | https://browser.geekbench.com/v5/cpu/11388065
This is crazy, slower than the snail owned by cuciu shitserver.
Test | Value
Single Core | 73
Multi Core | 123
Test | Value
Single Core | 84
Multi Core | 157
Test | Value
Single Core | 73
Multi Core | 123
Test | Value
Single Core | 84
Multi Core | 157
Looks like it may be intentional, considering it's 2 digit in any location I choose. They might want you to use this for FTP/NFS/etc storage, not so much for seedboxes and such.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 30 15:24:38 EST 2021 Basic System Information: --------------------------------- Processor : AMD EPYC 7763 64-Core Processor CPU cores : 2 @ 2450.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 39.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 325.01 MB/s (81.2k) | 3.76 GB/s (58.8k) Write | 325.87 MB/s (81.4k) | 3.78 GB/s (59.1k) Total | 650.88 MB/s (162.7k) | 7.55 GB/s (118.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 8.88 GB/s (17.3k) | 10.62 GB/s (10.3k) Write | 9.35 GB/s (18.2k) | 11.33 GB/s (11.0k) Total | 18.23 GB/s (35.6k) | 21.95 GB/s (21.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 942 Mbits/sec | 703 Mbits/sec Online.net | Paris, FR (10G) | 939 Mbits/sec | busy WorldStream | The Netherlands (10G) | busy | 77.3 Mbits/sec WebHorizon | Singapore (1G) | 311 Mbits/sec | 78.9 Mbits/sec Clouvider | NYC, NY, US (10G) | 763 Mbits/sec | 180 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 838 Mbits/sec | 219 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 588 Mbits/sec | 130 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 624 Mbits/sec | 59.7 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4362 Multi Core | 7272 Full Test | https://browser.geekbench.com/v4/cpu/16427134 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 903 Multi Core | 1837 Full Test | https://browser.geekbench.com/v5/cpu/11342252really wanted to and did so for 2 years, finally replacing it with Ryzen in HK haha.
wallets getting weaker..
I have that too, I'm not going to renew it so I can transfer it
Due: 17.12.2021
17,65 EUR / 6m
NVMe Gen 4.0 goodness
@vyas
@Mason my NVMe is 600K IOPS on paper, any insight why fio shows much less?
@cybertech Try this
56Special Sing:
5 fair-share cores Xeon Gold @ 2.6GHz+
6GB RAM
56GB NVMe RAID-10
5600GB BW @ 10Gbps port
KVM @ SolusVM
Singapore DC2
$56/year
Here is yabs:
root@GreenCloud:~# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 01 Dec 2021 05:40:19 PM GMT Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6132 CPU @ 2.60GHz CPU cores : 5 @ 2593.898 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 5.8 GiB Swap : 2.0 GiB Disk : 53.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 273.34 MB/s (68.3k) | 2.27 GB/s (35.5k) Write | 274.06 MB/s (68.5k) | 2.28 GB/s (35.7k) Total | 547.41 MB/s (136.8k) | 4.55 GB/s (71.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.24 GB/s (6.3k) | 3.63 GB/s (3.5k) Write | 3.42 GB/s (6.6k) | 3.87 GB/s (3.7k) Total | 6.66 GB/s (13.0k) | 7.51 GB/s (7.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.04 Gbits/sec | 1.01 Gbits/sec Online.net | Paris, FR (10G) | 1.44 Gbits/sec | 1.11 Gbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | 220 Mbits/sec | 552 Mbits/sec Clouvider | NYC, NY, US (10G) | 660 Mbits/sec | 672 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 539 Mbits/sec | 721 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 866 Mbits/sec | 965 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 395 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 771 Multi Core | 3160 Full Test | https://browser.geekbench.com/v5/cpu/11360131https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
ShockHosting free dedi 3 months
root@server:~# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 01 Dec 2021 10:11:44 AM PST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz CPU cores : 8 @ 1992.388 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 2.9 GiB Disk : 915.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.02 MB/s (257) | 14.01 MB/s (219) Write | 1.05 MB/s (264) | 14.67 MB/s (229) Total | 2.08 MB/s (521) | 28.68 MB/s (448) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 54.08 MB/s (105) | 71.08 MB/s (69) Write | 56.89 MB/s (111) | 75.81 MB/s (74) Total | 110.97 MB/s (216) | 146.90 MB/s (143) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 549 Mbits/sec | 218 Mbits/sec Online.net | Paris, FR (10G) | 741 Mbits/sec | 263 Mbits/sec WorldStream | The Netherlands (10G) | 606 Mbits/sec | 233 Mbits/sec WebHorizon | Singapore (1G) | 227 Mbits/sec | 311 Mbits/sec Clouvider | NYC, NY, US (10G) | 575 Mbits/sec | 162 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 393 Mbits/sec | 145 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 846 Mbits/sec | 220 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 455 Mbits/sec | 71.9 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1027 Multi Core | 3842 Full Test | https://browser.geekbench.com/v5/cpu/11360619https://capnhatuudai.com/en/ - Personal blog sharing promotion information, Domain Name Coupons, Hosting, VPS / Server, WordPress and the latest experiences and news from service providers around the world.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Dec 1 17:37:22 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz CPU cores : 8 @ 1236.012 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 16.0 GiB Disk : 1.8 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 600.00 KB/s (150) | 8.64 MB/s (135) Write | 630.00 KB/s (157) | 9.14 MB/s (142) Total | 1.23 MB/s (307) | 17.79 MB/s (277) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 38.26 MB/s (74) | 52.34 MB/s (51) Write | 40.45 MB/s (79) | 55.59 MB/s (54) Total | 78.71 MB/s (153) | 107.94 MB/s (105) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 95.4 Mbits/sec | 933 Mbits/sec Online.net | Paris, FR (10G) | 95.4 Mbits/sec | 935 Mbits/sec WorldStream | The Netherlands (10G) | 95.0 Mbits/sec | busy WebHorizon | Singapore (1G) | 12.8 Mbits/sec | 210 Mbits/sec Clouvider | NYC, NY, US (10G) | 35.5 Mbits/sec | 579 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 32.6 Mbits/sec | 394 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 22.8 Mbits/sec | 385 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 14.3 Mbits/sec | 190 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 842 Mbits/sec | 675 Mbits/sec Online.net | Paris, FR (10G) | 843 Mbits/sec | 884 Mbits/sec WorldStream | The Netherlands (10G) | busy | 655 Mbits/sec WebHorizon | Singapore (1G) | 141 Mbits/sec | 166 Mbits/sec Clouvider | NYC, NY, US (10G) | 448 Mbits/sec | 157 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 274 Mbits/sec | 89.6 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 881 Multi Core | 3834 Full Test | https://browser.geekbench.com/v5/cpu/11360136Free NAT KVM | Free NAT LXC
A wild KS-LE in its natural habitat in Gravelands
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Dec 1 17:52:38 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-1620 v2 @ 3.70GHz CPU cores : 8 @ 1384.399 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 32.0 GiB Disk : 961.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 788.00 KB/s (197) | 11.47 MB/s (179) Write | 824.00 KB/s (206) | 12.01 MB/s (187) Total | 1.61 MB/s (403) | 23.48 MB/s (366) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 48.41 MB/s (94) | 64.03 MB/s (62) Write | 50.88 MB/s (99) | 68.84 MB/s (67) Total | 99.29 MB/s (193) | 132.88 MB/s (129) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 96.9 Mbits/sec | 941 Mbits/sec Online.net | Paris, FR (10G) | 96.9 Mbits/sec | 941 Mbits/sec WorldStream | The Netherlands (10G) | 96.8 Mbits/sec | 940 Mbits/sec WebHorizon | Singapore (1G) | 84.3 Mbits/sec | 323 Mbits/sec Clouvider | NYC, NY, US (10G) | 94.6 Mbits/sec | 901 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 91.4 Mbits/sec | 761 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 91.6 Mbits/sec | 601 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 85.8 Mbits/sec | 481 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 95.5 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 95.5 Mbits/sec | 928 Mbits/sec WorldStream | The Netherlands (10G) | 95.4 Mbits/sec | 927 Mbits/sec WebHorizon | Singapore (1G) | 82.3 Mbits/sec | 69.1 Mbits/sec Clouvider | NYC, NY, US (10G) | 92.7 Mbits/sec | 888 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 87.7 Mbits/sec | 511 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 877 Multi Core | 3581 Full Test | https://browser.geekbench.com/v5/cpu/11360354Free NAT KVM | Free NAT LXC
Humble janitor of LES
Proud papa of YABS
Likely cooling.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 1 Dec 23:07:03 GMT 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU X5650 @ 2.67GHz CPU cores : 24 @ 1595.838 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.9 GiB Swap : 16.0 GiB Disk : 2.8 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 234.74 MB/s (58.6k) | 1.15 GB/s (18.0k) Write | 235.36 MB/s (58.8k) | 1.16 GB/s (18.1k) Total | 470.10 MB/s (117.5k) | 2.31 GB/s (36.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.55 GB/s (3.0k) | 1.53 GB/s (1.5k) Write | 1.63 GB/s (3.1k) | 1.63 GB/s (1.6k) Total | 3.18 GB/s (6.2k) | 3.17 GB/s (3.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 941 Mbits/sec | 941 Mbits/sec Online.net | Paris, FR (10G) | 938 Mbits/sec | 939 Mbits/sec WorldStream | The Netherlands (10G) | 937 Mbits/sec | 939 Mbits/sec WebHorizon | Singapore (1G) | 168 Mbits/sec | 254 Mbits/sec Clouvider | NYC, NY, US (10G) | 894 Mbits/sec | 583 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 807 Mbits/sec | 322 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 849 Mbits/sec | 316 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 785 Mbits/sec | 233 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 928 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 925 Mbits/sec | 926 Mbits/sec WorldStream | The Netherlands (10G) | 924 Mbits/sec | 926 Mbits/sec WebHorizon | Singapore (1G) | 181 Mbits/sec | 358 Mbits/sec Clouvider | NYC, NY, US (10G) | 884 Mbits/sec | 587 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 837 Mbits/sec | 288 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2608 Multi Core | 19502 Full Test | https://browser.geekbench.com/v4/cpu/16428087 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 580 Multi Core | 5260 Full Test | https://browser.geekbench.com/v5/cpu/11364595@Mason and others, can you please explain something to me? m_ _m
...and if the above reasoning is correct, then why is the math OK [i.e. core count * GB5 ingle score = (more or less) GB5 multi score] in case of VPS results? ><"
Examples:
https://talk.lowendspirit.com/discussion/comment/77160/#Comment_77160
https://talk.lowendspirit.com/discussion/comment/76781/#Comment_76781
AFAIK both of the these are modern high end CPUs whose thread count is 2x their core count, contrary to let's say https://browser.geekbench.com/processors/1824 where core count = thread count
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 02 Dec 2021 11:05:37 PM EST Basic System Information: --------------------------------- Processor : AMD EPYC 7282 16-Core Processor CPU cores : 10 @ 2794.748 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 58.9 GiB Swap : 2.0 GiB Disk : 1.5 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 5.29 MB/s (1.3k) | 64.15 MB/s (1.0k) Write | 5.31 MB/s (1.3k) | 64.57 MB/s (1.0k) Total | 10.60 MB/s (2.6k) | 128.72 MB/s (2.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 127.61 MB/s (249) | 97.49 MB/s (95) Write | 134.39 MB/s (262) | 103.98 MB/s (101) Total | 262.01 MB/s (511) | 201.47 MB/s (196) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 795 Mbits/sec | 747 Mbits/sec Online.net | Paris, FR (10G) | 826 Mbits/sec | 670 Mbits/sec WorldStream | The Netherlands (10G) | 815 Mbits/sec | 858 Mbits/sec WebHorizon | Singapore (1G) | 117 Mbits/sec | 233 Mbits/sec Clouvider | NYC, NY, US (10G) | 868 Mbits/sec | 911 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 68.9 Mbits/sec | 123 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 833 Mbits/sec | 724 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 797 Mbits/sec | 541 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 861 Multi Core | 6138 Full Test | https://browser.geekbench.com/v5/cpu/11387097Contabo BF Promotion USA East (Top Plan)
Price was around 27 euro per month. Price is great though performance is a bit mediocre.
OneProvider Lisbon 2TB HDD $12/month 1 Gbps Unmetered Bandwidth
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 03 Dec 2021 06:41:10 AM CET Basic System Information: --------------------------------- Processor : QEMU Virtual CPU version 2.5+ CPU cores : 2 @ 2394.230 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 512.0 MiB Disk : 2.0 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.09 MB/s (1.5k) | 26.35 MB/s (411) Write | 6.08 MB/s (1.5k) | 26.79 MB/s (418) Total | 12.18 MB/s (3.0k) | 53.15 MB/s (829) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 57.44 MB/s (112) | 65.04 MB/s (63) Write | 60.25 MB/s (117) | 69.37 MB/s (67) Total | 117.70 MB/s (229) | 134.41 MB/s (130) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 192 Mbits/sec | 113 Mbits/sec Online.net | Paris, FR (10G) | 173 Mbits/sec | 331 Mbits/sec WorldStream | The Netherlands (10G) | busy | 320 Mbits/sec WebHorizon | Singapore (1G) | 86.1 Mbits/sec | 220 Mbits/sec Clouvider | NYC, NY, US (10G) | 150 Mbits/sec | 249 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 33.7 Mbits/sec | 32.4 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 135 Mbits/sec | 149 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 123 Mbits/sec | 244 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 73 Multi Core | 123 Full Test | https://browser.geekbench.com/v5/cpu/11388337OneProvider Israel 2TB HDD $12/month 1 Gbps Unmetered Bandwidth
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 03 Dec 2021 06:20:59 AM CET Basic System Information: --------------------------------- Processor : QEMU Virtual CPU version 2.5+ CPU cores : 2 @ 1999.998 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.8 GiB Swap : 512.0 MiB Disk : 2.0 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 8.10 MB/s (2.0k) | 46.15 MB/s (721) Write | 8.14 MB/s (2.0k) | 46.32 MB/s (723) Total | 16.24 MB/s (4.0k) | 92.47 MB/s (1.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 90.39 MB/s (176) | 112.86 MB/s (110) Write | 95.19 MB/s (185) | 120.37 MB/s (117) Total | 185.58 MB/s (361) | 233.23 MB/s (227) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 190 Mbits/sec | 215 Mbits/sec Online.net | Paris, FR (10G) | 183 Mbits/sec | 255 Mbits/sec WorldStream | The Netherlands (10G) | 216 Mbits/sec | 247 Mbits/sec WebHorizon | Singapore (1G) | 103 Mbits/sec | 156 Mbits/sec Clouvider | NYC, NY, US (10G) | 184 Mbits/sec | 231 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 221 Mbits/sec | 183 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 163 Mbits/sec | 176 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 164 Mbits/sec | 163 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 84 Multi Core | 157 Full Test | https://browser.geekbench.com/v5/cpu/11388065Disk speeds are moderate, network speeds are meh and Geekbench5 results are terrible.
Nothing as crazy as my $1/year sister from cociu that got involcurated in Romania, but still insane deals :
DataIdeas, Texas: $6/year
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 03 Dec 2021 04:57:56 PM +08 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3792.872 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 976.4 MiB Swap : 975.0 MiB Disk : 8.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 264.14 MB/s (66.0k) | 1.81 GB/s (28.3k) Write | 264.83 MB/s (66.2k) | 1.82 GB/s (28.4k) Total | 528.98 MB/s (132.2k) | 3.63 GB/s (56.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.95 GB/s (3.8k) | 2.10 GB/s (2.0k) Write | 2.06 GB/s (4.0k) | 2.24 GB/s (2.1k) Total | 4.01 GB/s (7.8k) | 4.35 GB/s (4.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 315 Mbits/sec | 19.0 Mbits/sec Online.net | Paris, FR (10G) | 262 Mbits/sec | 928 Mbits/sec WorldStream | The Netherlands (10G) | 251 Mbits/sec | 933 Mbits/sec WebHorizon | Singapore (1G) | 144 Mbits/sec | 324 Mbits/sec Clouvider | NYC, NY, US (10G) | busy | 54.4 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 561 Mbits/sec | 59.1 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 703 Mbits/sec | 39.3 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 119 Mbits/sec | 906 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 395 Mbits/sec | 15.3 Mbits/sec Online.net | Paris, FR (10G) | 189 Mbits/sec | 24.2 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | 163 Mbits/sec | 15.8 Mbits/sec Clouvider | NYC, NY, US (10G) | 662 Mbits/sec | 50.7 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 701 Mbits/sec | 65.1 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1128 Multi Core | 1120 Full Test | https://browser.geekbench.com/v5/cpu/11390683GreenCloud, Singapore: $68/2 years
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 03 Dec 2021 03:56:38 AM EST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6132 CPU @ 2.60GHz CPU cores : 2 @ 2593.898 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 5.8 GiB Swap : 3.0 GiB Disk : 36.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 255.72 MB/s (63.9k) | 2.31 GB/s (36.1k) Write | 256.40 MB/s (64.1k) | 2.32 GB/s (36.3k) Total | 512.12 MB/s (128.0k) | 4.63 GB/s (72.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.18 GB/s (6.2k) | 3.45 GB/s (3.3k) Write | 3.35 GB/s (6.5k) | 3.68 GB/s (3.6k) Total | 6.54 GB/s (12.7k) | 7.14 GB/s (6.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 929 Mbits/sec | 959 Mbits/sec Online.net | Paris, FR (10G) | busy | 1.19 Gbits/sec WorldStream | The Netherlands (10G) | busy | 1.05 Gbits/sec WebHorizon | Singapore (1G) | 173 Mbits/sec | 385 Mbits/sec Clouvider | NYC, NY, US (10G) | 694 Mbits/sec | 674 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 306 Mbits/sec | 732 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 992 Mbits/sec | 985 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 420 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 950 Mbits/sec | 972 Mbits/sec Online.net | Paris, FR (10G) | busy | 701 Mbits/sec WorldStream | The Netherlands (10G) | 1.00 Gbits/sec | 868 Mbits/sec WebHorizon | Singapore (1G) | 345 Mbits/sec | 370 Mbits/sec Clouvider | NYC, NY, US (10G) | 670 Mbits/sec | 649 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 917 Mbits/sec | 954 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 787 Multi Core | 1491 Full Test | https://browser.geekbench.com/v5/cpu/11390713Also managed to get advinserver's offer, awaiting provision
I love 2 digit gb5 scores
Looking for some outstanding disk I/O in Vienna?
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 03 Dec 2021 01:13:17 PM UTC Basic System Information: --------------------------------- Processor : AMD EPYC 7542 32-Core Processor CPU cores : 8 @ 2899.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.4 GiB Swap : 0.0 KiB Disk : 196.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 312.17 MB/s (78.0k) | 4.15 GB/s (64.9k) Write | 312.99 MB/s (78.2k) | 4.18 GB/s (65.3k) Total | 625.17 MB/s (156.2k) | 8.33 GB/s (130.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 13.80 GB/s (26.9k) | 12.92 GB/s (12.6k) Write | 14.53 GB/s (28.3k) | 13.78 GB/s (13.4k) Total | 28.33 GB/s (55.3k) | 26.71 GB/s (26.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 976 Mbits/sec | 870 Mbits/sec Online.net | Paris, FR (10G) | 899 Mbits/sec | 994 Mbits/sec WorldStream | The Netherlands (10G) | 990 Mbits/sec | 860 Mbits/sec WebHorizon | Singapore (1G) | 179 Mbits/sec | 597 Mbits/sec Clouvider | NYC, NY, US (10G) | 553 Mbits/sec | 816 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 575 Mbits/sec | 709 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 350 Mbits/sec | 284 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 149 Mbits/sec | 620 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 981 Mbits/sec | 979 Mbits/sec Online.net | Paris, FR (10G) | 890 Mbits/sec | 980 Mbits/sec WorldStream | The Netherlands (10G) | busy | 944 Mbits/sec WebHorizon | Singapore (1G) | 144 Mbits/sec | 314 Mbits/sec Clouvider | NYC, NY, US (10G) | 421 Mbits/sec | 805 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 376 Mbits/sec | 780 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1083 Multi Core | 7613 Full Test | https://browser.geekbench.com/v5/cpu/11394546Alwyzon - Virtual Servers in Austria starting at 3,99 €/month (excl. VAT)
Some updates pushed to the YABS repo. Give me a shout if anyone hits any issues.
Proud papa of YABS
Always interesting seeing the usage spikes on Black Friday. Seems like it'll continue to be an annual tradition
Proud papa of YABS
I blame @cybertech ..... :-)
p.S @Mason congratulations on the growth innuse and acceptance of YABS...
Also interesting is the spike around August /September where number of BMs exceed unique machines by a factor of 4x
Thanks, I was waiting for this
Virmach
BF-SPECIAL-2021
$12.95/yr WOW
3172MB RAM
3 vCORE
35GB SSD (RAID 10)
5TB Traffic WOW
10Gbps Bandwidth WOW
BUFFALO, NY LOCATION
1 DEDICATED IPv4
NO IPv6 but its ok
PHP Friends Schnupperspecial 2021
Low performance of CPU compared with Intel Xeon Gold 6240 that could get 1500-ish score
root@v57190:~# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-12-03 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun 05 Dec 2021 02:54:51 AM CET Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6140 CPU @ 2.30GHz CPU cores : 2 @ 2300.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 2.0 GiB Disk : 76.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 132.76 MB/s (33.1k) | 907.83 MB/s (14.1k) Write | 133.11 MB/s (33.2k) | 912.61 MB/s (14.2k) Total | 265.88 MB/s (66.4k) | 1.82 GB/s (28.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.42 GB/s (2.7k) | 1.23 GB/s (1.2k) Write | 1.49 GB/s (2.9k) | 1.31 GB/s (1.2k) Total | 2.91 GB/s (5.7k) | 2.55 GB/s (2.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 3.08 Gbits/sec | 2.96 Gbits/sec Online.net | Paris, FR (10G) | 7.37 Gbits/sec | 4.79 Gbits/sec WorldStream | The Netherlands (10G) | 7.97 Gbits/sec | 2.94 Gbits/sec WebHorizon | Singapore (1G) | 119 Mbits/sec | 445 Mbits/sec Clouvider | NYC, NY, US (10G) | 1.46 Gbits/sec | 1.87 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 22.8 Mbits/sec | 68.3 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.15 Gbits/sec | 1.06 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 197 Mbits/sec | 404 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 6.31 Gbits/sec | 2.97 Gbits/sec Online.net | Paris, FR (10G) | 7.49 Gbits/sec | 2.79 Gbits/sec WorldStream | The Netherlands (10G) | 8.20 Gbits/sec | 4.77 Gbits/sec WebHorizon | Singapore (1G) | 116 Mbits/sec | 357 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.07 Gbits/sec | 1.94 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 3.24 Mbits/sec | 711 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 602 Multi Core | 1085 Full Test | https://browser.geekbench.com/v5/cpu/11426667⭕ A simple uptime dashboard using UptimeRobot API https://upy.duo.ovh
Virmach Special
Terrahost free LXC, seems improved IO
