Note:
1. With RPiOs based on Debian buster CPU Speed can be improved to 1800 Mhz. But I set it to 1700
2. GB4 will not work
3. no fio on NVMe Manjaro. CPU set to stock frequency
4. @ehab
@cybertech is gonna go nuts by the end of the month.
don't forget to add me to the users for all the vpses you have i can bench them for you now and then in your memory.
Acer predator Helios 300 i5 10th gen with rtx 2060 , not the fastest but gets the job done
Which drive is this? Some Silicon Power or Timetec NVMe?
WD SN550,
pacificrack
last bench after PayPal dispute
My Raspberry Pi4,
1st Run
Tue 09 Nov 2021 07:37:02 PM IST ARM-compatibility is considered *experimental* Basic System Information: --------------------------------- Processor : Cortex-A72 CPU cores : 4 @ 1700.0000 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ❌ Disabled RAM : 3.5 GiB Swap : 100.0 MiB Disk : 220.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 58.62 MB/s (14.6k) | 126.06 MB/s (1.9k) Write | 58.58 MB/s (14.6k) | 129.81 MB/s (2.0k) Total | 117.21 MB/s (29.3k) | 255.87 MB/s (3.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 139.54 MB/s (272) | 79.92 MB/s (78) Write | 151.48 MB/s (295) | 89.17 MB/s (87) Total | 291.02 MB/s (567) | 169.09 MB/s (165) ARM architecture not supported by Geekbench 4, use Geekbench 5. Geekbench 4 test failed. Test truncated at this stage*2nd Run
GB5 only
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 18.40 MB/s (4.6k) | 83.05 MB/s (1.2k) Write | 18.39 MB/s (4.5k) | 85.52 MB/s (1.3k) Total | 36.80 MB/s (9.2k) | 168.58 MB/s (2.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 138.89 MB/s (271) | 144.91 MB/s (141) Write | 150.77 MB/s (294) | 161.68 MB/s (157) Total | 289.66 MB/s (565) | 306.60 MB/s (298) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 238 Multi Core | 591 Full Test | https://browser.geekbench.com/v5/cpu/10914993Comparison of fio for 64k / 4 k and 1m is very interesting !
3rd Run
YABS with Manjaro on USB NVMe
non-result
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 0.00 KB/s (0) | 0.00 KB/s (0) Write | 0.00 KB/s (0) | 0.00 KB/s (0) Total | 0.00 KB/s (0) | 0.00 KB/s (0) Geekbench 5 test failed. Run manually to determine cause.Note:
4. @ehab
My previous Post updated
your getting creative.
are you this romantic with the ladies?
Act.. and not just talk? With the ladies I suppose you got to do both?
yes .. i can imagine
lets talk somewhere else , @cybertech will freak if we spam here
later
Wishosting - KVM HDD Limited Flash Sale - $3.99/month
Odd write speeds since this is supposed to be a hard drive!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu 11 Nov 2021 05:31:13 AM UTC Basic System Information: --------------------------------- Processor : Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS) CPU cores : 1 @ 3699.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 393.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 90.66 MB/s (22.6k) | 1.01 GB/s (15.7k) Write | 90.90 MB/s (22.7k) | 1.01 GB/s (15.8k) Total | 181.57 MB/s (45.3k) | 2.02 GB/s (31.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.83 GB/s (3.5k) | 2.08 GB/s (2.0k) Write | 1.93 GB/s (3.7k) | 2.22 GB/s (2.1k) Total | 3.76 GB/s (7.3k) | 4.30 GB/s (4.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 469 Mbits/sec | 928 Mbits/sec Online.net | Paris, FR (10G) | 471 Mbits/sec | 928 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | 139 Mbits/sec | 719 Mbits/sec Clouvider | NYC, NY, US (10G) | 385 Mbits/sec | 703 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 285 Mbits/sec | 682 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 267 Mbits/sec | 372 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 191 Mbits/sec | 375 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3418 Multi Core | 3324 Full Test | https://browser.geekbench.com/v4/cpu/16409588 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 675 Multi Core | 666 Full Test | https://browser.geekbench.com/v5/cpu/10942909# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Nov 11 12:37:52 CET 2021 Basic System Information: --------------------------------- Processor : Intel(R) Core(TM) i3 CPU 540 @ 3.07GHz CPU cores : 4 @ 3058.747 MHz AES-NI : ❌ Disabled VM-x/AMD-V : ✔ Enabled RAM : 7.6 GiB Swap : 1024.0 MiB Disk : 915.3 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.06 MB/s (266) | 14.27 MB/s (223) Write | 1.09 MB/s (274) | 14.84 MB/s (231) Total | 2.16 MB/s (540) | 29.11 MB/s (454) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 54.26 MB/s (105) | 61.38 MB/s (59) Write | 57.16 MB/s (111) | 65.75 MB/s (64) Total | 111.42 MB/s (216) | 127.13 MB/s (123) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 10.7 Mbits/sec | 87.7 Mbits/sec Online.net | Paris, FR (10G) | 22.4 Mbits/sec | 77.6 Mbits/sec WorldStream | The Netherlands (10G) | busy | 87.0 Mbits/sec WebHorizon | Singapore (1G) | 2.46 Mbits/sec | 39.5 Mbits/sec Clouvider | NYC, NY, US (10G) | 3.39 Mbits/sec | 64.4 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 2.88 Mbits/sec | 64.6 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.93 Mbits/sec | 49.9 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 1.56 Mbits/sec | 33.5 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 526 Multi Core | 1083 Full Test | https://browser.geekbench.com/v5/cpu/10947290Webhosting - NVMe SSD, Cloudlinux, Litespeed, SSH Access
SpeedyPage - KVM-2G 2.99 GBP/month
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 16 17:00:10 EST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Silver 4112 CPU @ 2.60GHz CPU cores : 1 @ 2599.992 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 29.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 194.23 MB/s (48.5k) | 1.38 GB/s (21.7k) Write | 194.74 MB/s (48.6k) | 1.39 GB/s (21.8k) Total | 388.97 MB/s (97.2k) | 2.78 GB/s (43.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.67 GB/s (3.2k) | 1.58 GB/s (1.5k) Write | 1.76 GB/s (3.4k) | 1.68 GB/s (1.6k) Total | 3.43 GB/s (6.7k) | 3.26 GB/s (3.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 3.02 Gbits/sec | 2.84 Gbits/sec Online.net | Paris, FR (10G) | 3.00 Gbits/sec | 2.79 Gbits/sec WorldStream | The Netherlands (10G) | 2.97 Gbits/sec | 2.82 Gbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 1.79 Gbits/sec | 2.47 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 609 Mbits/sec | 1.98 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.31 Gbits/sec | 1.25 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 162 Mbits/sec | 892 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3457 Multi Core | 3313 Full Test | https://browser.geekbench.com/v4/cpu/16414558 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 772 Multi Core | 769 Full Test | https://browser.geekbench.com/v5/cpu/11041139SpeedyPage - KVM-4G 4.99 GBP/month
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 17 15:19:39 EST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Silver 4112 CPU @ 2.60GHz CPU cores : 2 @ 2599.992 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 3.8 GiB Swap : 0.0 KiB Disk : 58.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 211.59 MB/s (52.8k) | 1.53 GB/s (24.0k) Write | 212.15 MB/s (53.0k) | 1.54 GB/s (24.1k) Total | 423.75 MB/s (105.9k) | 3.08 GB/s (48.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.63 GB/s (3.1k) | 1.69 GB/s (1.6k) Write | 1.71 GB/s (3.3k) | 1.80 GB/s (1.7k) Total | 3.35 GB/s (6.5k) | 3.50 GB/s (3.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 3.02 Gbits/sec | 2.84 Gbits/sec Online.net | Paris, FR (10G) | 2.99 Gbits/sec | 2.82 Gbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 2.12 Gbits/sec | 2.44 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 74.3 Mbits/sec | 1.97 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.06 Gbits/sec | 1.32 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 135 Mbits/sec | 892 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3395 Multi Core | 6018 Full Test | https://browser.geekbench.com/v4/cpu/16415404 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 755 Multi Core | 1455 Full Test | https://browser.geekbench.com/v5/cpu/11057410Posting for historical arcihves.
My INR 19 K (~ US Dollars 280) Crapware- Coconics Laptop, moments before it died for good. Planning to use it for parts.
ISP: ShockHosting
CPU: Intel(R) Xeon(R) CPU E3-1271 v3
RAM: 16GB DDR 3
DISK: 1x 480GB SSD
IP: /29 subnet
PRICE: 30€ per month
Amadex.com Domainer + IT Supporter | Brbljaona Balkan Chat Website | ICT Jobs Croatia
Small manjaro homelab vps
Most likely NVMe cache, speeds will go down once that has run out
Great for short bursts
PHP-Friends vServer Schnupperspecial 2021 NVMe
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon 22 Nov 2021 03:34:59 PM CET Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Gold 6240 CPU @ 2.60GHz CPU cores : 2 @ 2600.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.8 GiB Swap : 0.0 KiB Disk : 78.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 251.42 MB/s (62.8k) | 3.00 GB/s (47.0k) Write | 252.09 MB/s (63.0k) | 3.02 GB/s (47.2k) Total | 503.51 MB/s (125.8k) | 6.03 GB/s (94.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.39 GB/s (4.6k) | 3.45 GB/s (3.3k) Write | 2.51 GB/s (4.9k) | 3.68 GB/s (3.5k) Total | 4.91 GB/s (9.5k) | 7.13 GB/s (6.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 3.51 Gbits/sec | 3.04 Gbits/sec Online.net | Paris, FR (10G) | 8.15 Gbits/sec | 4.68 Gbits/sec WorldStream | The Netherlands (10G) | 8.89 Gbits/sec | 3.22 Gbits/sec WebHorizon | Singapore (1G) | 239 Mbits/sec | 724 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.23 Gbits/sec | 1.85 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 1.20 Gbits/sec | 1.35 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.20 Gbits/sec | 1.20 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 92.9 Mbits/sec | 837 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 7.20 Gbits/sec | 5.15 Gbits/sec Online.net | Paris, FR (10G) | busy | 5.97 Gbits/sec WorldStream | The Netherlands (10G) | 8.94 Gbits/sec | 5.52 Gbits/sec WebHorizon | Singapore (1G) | 224 Mbits/sec | 750 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.33 Gbits/sec | 2.02 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 877 Mbits/sec | 1.17 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 757 Multi Core | 1427 Full Test | https://browser.geekbench.com/v5/cpu/11138140Went on a dedi buying spree with OVH, upgrading older ones.
RISE-LE-2
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 23 03:53:45 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) E-2274G CPU @ 4.00GHz CPU cores : 8 @ 4813.232 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.5 GiB Swap : 1024.0 MiB Disk : 879.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 804.60 MB/s (201.1k) | 908.22 MB/s (14.1k) Write | 806.72 MB/s (201.6k) | 913.00 MB/s (14.2k) Total | 1.61 GB/s (402.8k) | 1.82 GB/s (28.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 971.87 MB/s (1.8k) | 976.69 MB/s (953) Write | 1.02 GB/s (1.9k) | 1.04 GB/s (1.0k) Total | 1.99 GB/s (3.8k) | 2.01 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 485 Mbits/sec | 8.32 Gbits/sec Online.net | Paris, FR (10G) | busy | 5.96 Gbits/sec WorldStream | The Netherlands (10G) | 485 Mbits/sec | busy WebHorizon | Singapore (1G) | 302 Mbits/sec | 652 Mbits/sec Clouvider | NYC, NY, US (10G) | 455 Mbits/sec | 2.23 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 434 Mbits/sec | 1.33 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 401 Mbits/sec | 1.21 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 215 Mbits/sec | 735 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1355 Multi Core | 4980 Full Test | https://browser.geekbench.com/v5/cpu/11148411Game-LE
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 23 03:53:52 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 7 3800X 8-Core Processor CPU cores : 16 @ 3900.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.6 GiB Swap : 1024.0 MiB Disk : 879.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 615.63 MB/s (153.9k) | 902.73 MB/s (14.1k) Write | 617.25 MB/s (154.3k) | 907.49 MB/s (14.1k) Total | 1.23 GB/s (308.2k) | 1.81 GB/s (28.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 954.61 MB/s (1.8k) | 985.70 MB/s (962) Write | 1.00 GB/s (1.9k) | 1.05 GB/s (1.0k) Total | 1.95 GB/s (3.8k) | 2.03 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 936 Mbits/sec | 465 Mbits/sec Online.net | Paris, FR (10G) | busy | busy WorldStream | The Netherlands (10G) | 934 Mbits/sec | 510 Mbits/sec WebHorizon | Singapore (1G) | 459 Mbits/sec | 152 Mbits/sec Clouvider | NYC, NY, US (10G) | 736 Mbits/sec | 642 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 754 Mbits/sec | 158 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 826 Mbits/sec | 239 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 686 Mbits/sec | 195 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 923 Mbits/sec | 704 Mbits/sec Online.net | Paris, FR (10G) | 907 Mbits/sec | 471 Mbits/sec WorldStream | The Netherlands (10G) | 887 Mbits/sec | 768 Mbits/sec WebHorizon | Singapore (1G) | 255 Mbits/sec | 201 Mbits/sec Clouvider | NYC, NY, US (10G) | 404 Mbits/sec | 128 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 755 Mbits/sec | 105 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1406 Multi Core | 9512 Full Test | https://browser.geekbench.com/v5/cpu/11148432hosthatch HK
active services running
GreencloudVPS SG10GbpsStorage0.5TB
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 24 18:39:36 EST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) Silver 4216 CPU @ 2.10GHz CPU cores : 1 @ 2099.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.8 GiB Swap : 2.0 GiB Disk : 490.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 10.93 MB/s (2.7k) | 97.55 MB/s (1.5k) Write | 10.95 MB/s (2.7k) | 98.07 MB/s (1.5k) Total | 21.88 MB/s (5.4k) | 195.62 MB/s (3.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 392.25 MB/s (766) | 584.04 MB/s (570) Write | 413.09 MB/s (806) | 622.94 MB/s (608) Total | 805.35 MB/s (1.5k) | 1.20 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.02 Gbits/sec | 1.00 Gbits/sec Online.net | Paris, FR (10G) | 1.43 Gbits/sec | 1.17 Gbits/sec WorldStream | The Netherlands (10G) | 1.00 Gbits/sec | 1.04 Gbits/sec WebHorizon | Singapore (1G) | 871 Mbits/sec | 883 Mbits/sec Clouvider | NYC, NY, US (10G) | 689 Mbits/sec | 678 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | busy | 726 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.01 Gbits/sec | 895 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 404 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.02 Gbits/sec | 1.03 Gbits/sec Online.net | Paris, FR (10G) | 848 Mbits/sec | busy WorldStream | The Netherlands (10G) | 990 Mbits/sec | 927 Mbits/sec WebHorizon | Singapore (1G) | 895 Mbits/sec | 910 Mbits/sec Clouvider | NYC, NY, US (10G) | 711 Mbits/sec | 710 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.03 Gbits/sec | 985 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 681 Multi Core | 697 Full Test | https://browser.geekbench.com/v5/cpu/11180008One for the road:
Greencloud BF 2020 12 GB / 4VCPU Singapore before it's curtains down this week:
new home desktop on SSD while awaiting NVMe arrival:
Upcycled ThinkCentre Tiny M900.
Waiting 16 GB RAM Stick, soon to be my media recording / editing station
(Added RAM, replaced stock KDD with SATA
Monday 22 November 2021 03:56:34 AM IST Basic System Information: --------------------------------- Processor : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz CPU cores : 4 @ 2500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 15.5 GiB Swap : 8.8 GiB Disk : 430.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 87.80 MB/s (21.9k) | 148.47 MB/s (2.3k) Write | 88.03 MB/s (22.0k) | 149.25 MB/s (2.3k) Total | 175.83 MB/s (43.9k) | 297.72 MB/s (4.6k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 175.95 MB/s (343) | 194.49 MB/s (189) Write | 185.30 MB/s (361) | 207.44 MB/s (202) Total | 361.26 MB/s (704) | 401.94 MB/s (391) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3728 Multi Core | 11331 Full Test | https://browser.geekbench.com/v4/cpu/16419165 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 795 Multi Core | 2802 Full Test | https://browser.geekbench.com/v5/cpu/11127408VPS reviews | | MicroLXC | English is my nth language.
Ubuntu VM on my desktop at home, often used for dev work -
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Nov 25 11:02:42 IST 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 5 1600 Six-Core Processor CPU cores : 12 @ 3200.052 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 6.2 GiB Swap : 2.0 GiB Disk : 160.0 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 18.19 MB/s (4.5k) | 90.56 MB/s (1.4k) Write | 18.20 MB/s (4.5k) | 91.04 MB/s (1.4k) Total | 36.40 MB/s (9.0k) | 181.61 MB/s (2.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 115.07 MB/s (224) | 118.33 MB/s (115) Write | 121.19 MB/s (236) | 126.21 MB/s (123) Total | 236.27 MB/s (460) | 244.55 MB/s (238) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 599 Mbits/sec | 719 Mbits/sec Online.net | Paris, FR (10G) | 614 Mbits/sec | 807 Mbits/sec WorldStream | The Netherlands (10G) | 615 Mbits/sec | 810 Mbits/sec WebHorizon | Singapore (1G) | 663 Mbits/sec | 845 Mbits/sec Clouvider | NYC, NY, US (10G) | 328 Mbits/sec | 586 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 323 Mbits/sec | 560 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 467 Mbits/sec | 602 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | busy | 373 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 929 Multi Core | 4435 Full Test | https://browser.geekbench.com/v5/cpu/11183680Same machine, but with NVMe boot Drive. Better disk speeds, shittier GB score
fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 459.79 MB/s (114.9k) | 919.40 MB/s (14.3k) Write | 461.01 MB/s (115.2k) | 924.24 MB/s (14.4k) Total | 920.81 MB/s (230.2k) | 1.84 GB/s (28.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.04 GB/s (2.0k) | 1.08 GB/s (1.0k) Write | 1.09 GB/s (2.1k) | 1.16 GB/s (1.1k) Total | 2.14 GB/s (4.1k) | 2.25 GB/s (2.1k) Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3773 Multi Core | 11676 Full Test | https://browser.geekbench.com/v4/cpu/16418717 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 730 Multi Core | 1808 Full Test | https://browser.geekbench.com/v5/cpu/11119651VPS reviews | | MicroLXC | English is my nth language.
Dedipath
openvz
phoenix
no IPv6
but comes with 2 x IPv4
BF deal $2.27 /mth
My Seattle ryzen has ipv6
Is it not available in phoenix?
@cybertech where is the Bench for your Ryzen?
