Beware, the disk fio bench is done under the current working directory. If your system has mixed NVME/SATA SSD/HDD, make sure to do more disk benches under the corresponding directories.
edit: this YABS result was posted on almost "real time" basis- 4 or 5 lines posted at a time as the results were displayed on the terminal. Copy/pasta errors to be excused.
hazi.ro NAT LXC, 1GB RAM, 160GB HDD; offer link
IPv6 address is invalid; IPv4 has only outbound; benchmark taken via VNC and exported through transfer.sh
@yoursunny said: hazi.ro NAT LXC, 1GB RAM, 160GB HDD; offer link
If you have problem with accessing it through IPv4 NAT then check your configuration of ssh daemon on this VPS (/etc/ssh/sshd_config). Port number there have to be changed from 22 to the same as designated external port and enable "PermitRootLogin yes". It worked for me when I reinstalled from default Centos 7 to Debian 11.
In case anybody got interested in this beast, the Alwyzon Cyber Weekend sale is still ongoing and there is also some stock left for the 35 €/yr promotion of the Virtual Server XS. (The EcoServers are nearly gone thought.)
— Michael
yes i do not see any ipv6 in my panel..
made a sneak preview here:
https://talk.lowendspirit.com/discussion/comment/75938/#Comment_75938
Indeed.. I meant with the NVMe.
Are we there yet?
no
amazon sent by snail mail.
Ah The anticipation!!
dedipath performing better on debian 10
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 26 Nov 2021 12:55:50 PM CET Basic System Information: --------------------------------- Processor : AMD EPYC 7702P 64-Core Processor CPU cores : 12 @ 1996.249 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 62.8 GiB Swap : 0.0 KiB Disk : 2.0 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 160.42 MB/s (40.1k) | 1.81 GB/s (28.3k) Write | 160.85 MB/s (40.2k) | 1.82 GB/s (28.4k) Total | 321.27 MB/s (80.3k) | 3.63 GB/s (56.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 5.03 GB/s (9.8k) | 5.20 GB/s (5.0k) Write | 5.29 GB/s (10.3k) | 5.55 GB/s (5.4k) Total | 10.33 GB/s (20.1k) | 10.75 GB/s (10.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.47 Gbits/sec | 2.39 Gbits/sec Online.net | Paris, FR (10G) | 2.45 Gbits/sec | 2.39 Gbits/sec WorldStream | The Netherlands (10G) | 2.47 Gbits/sec | 2.40 Gbits/sec WebHorizon | Singapore (1G) | 567 Mbits/sec | 724 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.08 Gbits/sec | 1.65 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 1.99 Gbits/sec | 1.79 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.17 Gbits/sec | 1.17 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 860 Mbits/sec | 928 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4507 Multi Core | 34722 Full Test | https://browser.geekbench.com/v4/cpu/16422968 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 967 Multi Core | 9344 Full Test | https://browser.geekbench.com/v5/cpu/11232008Webhorizon Cloud Five Solutions
Fri Nov 26 07:11:48 EST 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 2 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : 78.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 636.20 MB/s (159.0k) | 4.42 GB/s (69.0k) Write | 637.88 MB/s (159.4k) | 4.44 GB/s (69.4k) Total | 1.27 GB/s (318.5k) | 8.86 GB/s (138.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.02 GB/s (5.9k) | 4.44 GB/s (4.3k) Write | 3.18 GB/s (6.2k) | 4.73 GB/s (4.6k) Total | 6.20 GB/s (12.1k) | 9.17 GB/s (8.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 249 Mbits/sec | 285 Mbits/sec Online.net | Paris, FR (10G) | 243 Mbits/sec | 286 Mbits/sec WorldStream | The Netherlands (10G) | 288 Mbits/sec | busy WebHorizon | Singapore (1G) | 118 Mbits/sec | 81.7 Mbits/sec Clouvider | NYC, NY, US (10G) | 258 Mbits/sec | 185 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 73.1 Mbits/sec | 247 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 112 Mbits/sec | 142 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 125 Mbits/sec | 111 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed Clouvider | London, UK (10G) | 290 Mbits/sec | 282 Mbits/sec Online.net | Paris, FR (10G) | 295 Mbits/sec | 282 Mbits/sec WorldStream | The Netherlands (10G) | 293 Mbits/sec | busy WebHorizon | Singapore (1G) | 112 Mbits/sec | 207 Mbits/sec Clouvider | NYC, NY, US (10G) | 269 Mbits/sec | 274 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 122 Mbits/sec | 254 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1480 Multi Core | 2789 Full Test | https://browser.geekbench.com/v5/cpu/11232408 Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7088 Multi Core | 11187 Full Test | https://browser.geekbench.com/v4/cpu/16422983@Abdullah @ofit
@vyas which plan is this? GB scores?
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 26 Nov 2021 12:11:39 PM GMT Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz CPU cores : 2 @ 3407.982 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 2.9 GiB Swap : 0.0 KiB Disk : 37.8 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 385.42 MB/s (96.3k) | 603.65 MB/s (9.4k) Write | 386.44 MB/s (96.6k) | 606.82 MB/s (9.4k) Total | 771.86 MB/s (192.9k) | 1.21 GB/s (18.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 583.51 MB/s (1.1k) | 591.19 MB/s (577) Write | 614.51 MB/s (1.2k) | 630.56 MB/s (615) Total | 1.19 GB/s (2.3k) | 1.22 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 6.51 Gbits/sec | 8.25 Gbits/sec Online.net | Paris, FR (10G) | 7.19 Gbits/sec | 8.39 Gbits/sec WorldStream | The Netherlands (10G) | busy | 6.81 Gbits/sec WebHorizon | Singapore (1G) | 314 Mbits/sec | 403 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.11 Gbits/sec | 1.74 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 3.64 Gbits/sec | 2.73 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.23 Gbits/sec | 1.08 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 901 Mbits/sec | 142 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 6.05 Gbits/sec | 7.71 Gbits/sec Online.net | Paris, FR (10G) | 7.00 Gbits/sec | 7.89 Gbits/sec WorldStream | The Netherlands (10G) | 8.30 Gbits/sec | 5.15 Gbits/sec WebHorizon | Singapore (1G) | 221 Mbits/sec | 800 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.11 Gbits/sec | 1.01 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.24 Gbits/sec | 1.15 Gbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5981 Multi Core | 9971 Full Test | https://browser.geekbench.com/v4/cpu/16422980 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1247 Multi Core | 2390 Full Test | https://browser.geekbench.com/v5/cpu/11232462# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Nov 26 12:13:32 UTC 2021 Basic System Information: --------------------------------- Processor : AMD Ryzen 5 3600 6-Core Processor CPU cores : 1 @ 3444.949 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.0 GiB Swap : 2.0 GiB Disk : 29.4 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 75.11 MB/s (18.7k) | 173.43 MB/s (2.7k) Write | 75.31 MB/s (18.8k) | 174.34 MB/s (2.7k) Total | 150.43 MB/s (37.6k) | 347.78 MB/s (5.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 269.36 MB/s (526) | 335.96 MB/s (328) Write | 283.67 MB/s (554) | 358.34 MB/s (349) Total | 553.04 MB/s (1.0k) | 694.30 MB/s (677) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.44 Gbits/sec | 2.20 Gbits/sec Online.net | Paris, FR (10G) | 2.53 Gbits/sec | 1.39 Gbits/sec WorldStream | The Netherlands (10G) | busy | 1.06 Gbits/sec WebHorizon | Singapore (1G) | 535 Mbits/sec | 719 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.02 Gbits/sec | 1.32 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 2.09 Gbits/sec | 1.08 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.16 Gbits/sec | 1.05 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 782 Mbits/sec | 562 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 2.50 Gbits/sec | 1.62 Gbits/sec Online.net | Paris, FR (10G) | 2.54 Gbits/sec | 1.49 Gbits/sec WorldStream | The Netherlands (10G) | 2.55 Gbits/sec | 1.10 Gbits/sec WebHorizon | Singapore (1G) | 202 Mbits/sec | 690 Mbits/sec Clouvider | NYC, NY, US (10G) | 2.06 Gbits/sec | 694 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 1.10 Gbits/sec | 864 Mbits/secGB is not possible to run here.
Hostcram
Fri Nov 26 16:44:51 UTC 2021 Basic System Information: --------------------------------- Processor : 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz CPU cores : 1 @ 3500.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.0 GiB Swap : 1.5 GiB Disk : 9.7 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.17 GB/s (294.9k) | 3.44 GB/s (53.7k) Write | 1.18 GB/s (295.7k) | 3.45 GB/s (54.0k) Total | 2.36 GB/s (590.7k) | 6.89 GB/s (107.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.47 GB/s (6.7k) | 1.39 GB/s (1.3k) Write | 3.65 GB/s (7.1k) | 1.48 GB/s (1.4k) Total | 7.13 GB/s (13.9k) | 2.88 GB/s (2.8k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 862 Mbits/sec | 171 Mbits/sec Online.net | Paris, FR (10G) | busy | busy Clouvider | NYC, NY, US (10G) | 914 Mbits/sec | 504 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 7549 Multi Core | 7216 Full Test | https://browser.geekbench.com/v4/cpu/16423246 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1652 Multi Core | 1724 Full Test | https://browser.geekbench.com/v5/cpu/11239627VPS reviews | | MicroLXC | English is my nth language.
OMG which provider?
which server?
BF is probably not the best day to test this, anyway here we go...
Netcup RS Black Storm
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 26 Nov 2021 06:49:47 PM CET Basic System Information: --------------------------------- Processor : AMD EPYC 7702P 64-Core Processor CPU cores : 4 @ 1996.250 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 19.6 GiB Swap : 0.0 KiB Disk : 629.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 171.61 MB/s (42.9k) | 1.88 GB/s (29.3k) Write | 172.06 MB/s (43.0k) | 1.89 GB/s (29.5k) Total | 343.68 MB/s (85.9k) | 3.77 GB/s (58.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 3.43 GB/s (6.7k) | 3.61 GB/s (3.5k) Write | 3.62 GB/s (7.0k) | 3.85 GB/s (3.7k) Total | 7.06 GB/s (13.7k) | 7.46 GB/s (7.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.69 Gbits/sec | 2.37 Gbits/sec Online.net | Paris, FR (10G) | 1.52 Gbits/sec | 2.37 Gbits/sec WorldStream | The Netherlands (10G) | busy | 2.38 Gbits/sec WebHorizon | Singapore (1G) | 185 Mbits/sec | 513 Mbits/sec Clouvider | NYC, NY, US (10G) | 751 Mbits/sec | 1.70 Gbits/sec Velocity Online | Tallahassee, FL, US (10G) | 486 Mbits/sec | 1.80 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 548 Mbits/sec | 1.03 Gbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 167 Mbits/sec | 1.06 Gbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 1.62 Gbits/sec | 2.33 Gbits/sec Online.net | Paris, FR (10G) | busy | 2.32 Gbits/sec WorldStream | The Netherlands (10G) | busy | 2.34 Gbits/sec WebHorizon | Singapore (1G) | 280 Mbits/sec | 807 Mbits/sec Clouvider | NYC, NY, US (10G) | 781 Mbits/sec | 1.43 Gbits/sec Clouvider | Los Angeles, CA, US (10G) | 464 Mbits/sec | 1.08 Gbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1036 Multi Core | 3983 Full Test | https://browser.geekbench.com/v5/cpu/11241114LiteServer BF 2G NVMe:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Nov 26 14:37:13 EST 2021 Basic System Information: --------------------------------- Processor : AMD EPYC 7452 32-Core Processor CPU cores : 2 @ 2349.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.8 GiB Swap : 255.0 MiB Disk : 39.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 255.44 MB/s (63.8k) | 3.35 GB/s (52.3k) Write | 256.11 MB/s (64.0k) | 3.36 GB/s (52.6k) Total | 511.56 MB/s (127.8k) | 6.72 GB/s (105.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 7.56 GB/s (14.7k) | 8.38 GB/s (8.1k) Write | 7.96 GB/s (15.5k) | 8.94 GB/s (8.7k) Total | 15.53 GB/s (30.3k) | 17.33 GB/s (16.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 781 Mbits/sec | 726 Mbits/sec Online.net | Paris, FR (10G) | 753 Mbits/sec | 660 Mbits/sec WorldStream | The Netherlands (10G) | 785 Mbits/sec | 825 Mbits/sec WebHorizon | Singapore (1G) | 593 Mbits/sec | 318 Mbits/sec Clouvider | NYC, NY, US (10G) | 480 Mbits/sec | 283 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 718 Mbits/sec | 244 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 615 Mbits/sec | 203 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 552 Mbits/sec | 148 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 4251 Multi Core | 7446 Full Test | https://browser.geekbench.com/v4/cpu/16423354 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 935 Multi Core | 1800 Full Test | https://browser.geekbench.com/v5/cpu/11243318@Abdullah 2GB RAM has 1vCPU or 2vCPU?
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Nov 27 02:51:34 UTC 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2637 v3 @ 3.50GHz CPU cores : 1 @ 3629.078 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.0 GiB Swap : 0.0 KiB Disk : fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 116.09 MB/s (29.0k) | 1.68 GB/s (26.3k) Write | 116.39 MB/s (29.0k) | 1.69 GB/s (26.4k) Total | 232.48 MB/s (58.1k) | 3.38 GB/s (52.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 991.20 MB/s (1.9k) | 981.41 MB/s (958) Write | 1.04 GB/s (2.0k) | 1.04 GB/s (1.0k) Total | 2.03 GB/s (3.9k) | 2.02 GB/s (1.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 414 Mbits/sec | 17.8 Mbits/sec Online.net | Paris, FR (10G) | 454 Mbits/sec | 4.44 Mbits/sec WorldStream | The Netherlands (10G) | 583 Mbits/sec | 512 Mbits/sec WebHorizon | Singapore (1G) | 153 Mbits/sec | 255 Mbits/sec Clouvider | NYC, NY, US (10G) | 310 Mbits/sec | 15.1 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 301 Mbits/sec | 19.0 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 283 Mbits/sec | 9.99 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 129 Mbits/sec | 489 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 784 Multi Core | 813 Full Test | https://browser.geekbench.com/v5/cpu/11250729If you have problem with accessing it through IPv4 NAT then check your configuration of ssh daemon on this VPS (/etc/ssh/sshd_config). Port number there have to be changed from 22 to the same as designated external port and enable "PermitRootLogin yes". It worked for me when I reinstalled from default Centos 7 to Debian 11.
YABS for @ShockHosting Free 3 months Dedicated Server!
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 27 Nov 2021 12:37:39 AM PST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E3-1270 v3 @ 3.50GHz CPU cores : 8 @ 1942.584 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.3 GiB Swap : 976.0 MiB Disk : 1.8 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 915.00 KB/s (228) | 12.95 MB/s (202) Write | 951.00 KB/s (237) | 13.60 MB/s (212) Total | 1.86 MB/s (465) | 26.56 MB/s (414) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 49.67 MB/s (97) | 62.20 MB/s (60) Write | 52.60 MB/s (102) | 66.63 MB/s (65) Total | 102.28 MB/s (199) | 128.84 MB/s (125) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 574 Mbits/sec | 237 Mbits/sec Online.net | Paris, FR (10G) | 713 Mbits/sec | 268 Mbits/sec WorldStream | The Netherlands (10G) | busy | busy WebHorizon | Singapore (1G) | 389 Mbits/sec | 783 Mbits/sec Clouvider | NYC, NY, US (10G) | 520 Mbits/sec | 131 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 765 Mbits/sec | 111 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 837 Mbits/sec | 145 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 467 Mbits/sec | 129 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1039 Multi Core | 3915 Full Test | https://browser.geekbench.com/v5/cpu/11257283🔥 RackNerd BF2021 VPS from $10.88/year & free ClientExec 😎 HostCram FastestVPS 🤑 Virmach BF&CM 2021 👈 Affiliate link ⚡
✔️SellSSL.com - Sectigo PositiveSSL from 15 USD per year!
I should have bought one ...
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 27 Nov 2021 02:34:16 PM CET Basic System Information: --------------------------------- Processor : AMD Ryzen 7 3700X 8-Core Processor CPU cores : 16 @ 3600.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.7 GiB Swap : 0.0 KiB Disk : 1.9 TiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.02 GB/s (257.2k) | 3.88 GB/s (60.6k) Write | 1.03 GB/s (257.9k) | 3.90 GB/s (60.9k) Total | 2.06 GB/s (515.2k) | 7.78 GB/s (121.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 4.91 GB/s (9.5k) | 5.07 GB/s (4.9k) Write | 5.17 GB/s (10.1k) | 5.41 GB/s (5.2k) Total | 10.08 GB/s (19.6k) | 10.48 GB/s (10.2k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 932 Mbits/sec | 923 Mbits/sec Online.net | Paris, FR (10G) | 929 Mbits/sec | 898 Mbits/sec WorldStream | The Netherlands (10G) | 931 Mbits/sec | 922 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 886 Mbits/sec | 348 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 843 Mbits/sec | 81.7 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 826 Mbits/sec | 424 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 758 Mbits/sec | 167 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 917 Mbits/sec | 710 Mbits/sec Online.net | Paris, FR (10G) | 918 Mbits/sec | 912 Mbits/sec WorldStream | The Netherlands (10G) | 919 Mbits/sec | 911 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 875 Mbits/sec | 445 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 824 Mbits/sec | 315 Mbits/sec Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 6255 Multi Core | 41221 Full Test | https://browser.geekbench.com/v4/cpu/16424028 Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1376 Multi Core | 9702 Full Test | https://browser.geekbench.com/v5/cpu/11264569@alwyzon Virtual Server XS
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Nov 27 21:14:19 UTC 2021 Basic System Information: --------------------------------- Processor : AMD EPYC 7542 32-Core Processor CPU cores : 2 @ 2899.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 24.6 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 314.37 MB/s (78.5k) | 3.77 GB/s (58.9k) Write | 315.20 MB/s (78.8k) | 3.79 GB/s (59.3k) Total | 629.58 MB/s (157.3k) | 7.57 GB/s (118.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 11.54 GB/s (22.5k) | 11.40 GB/s (11.1k) Write | 12.15 GB/s (23.7k) | 12.16 GB/s (11.8k) Total | 23.69 GB/s (46.2k) | 23.56 GB/s (23.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 802 Mbits/sec | 530 Mbits/sec Online.net | Paris, FR (10G) | 734 Mbits/sec | 994 Mbits/sec WorldStream | The Netherlands (10G) | 627 Mbits/sec | 859 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 526 Mbits/sec | 826 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 540 Mbits/sec | 220 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 435 Mbits/sec | 745 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 130 Mbits/sec | 773 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 977 Mbits/sec | 978 Mbits/sec Online.net | Paris, FR (10G) | 946 Mbits/sec | 980 Mbits/sec WorldStream | The Netherlands (10G) | 453 Mbits/sec | 944 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 500 Mbits/sec | 803 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 435 Mbits/sec | 763 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 1075 Multi Core | 2109 Full Test | https://browser.geekbench.com/v5/cpu/11275148Website: thomassen.sh
Discord: Decicus#0001
can't YABS, github died entirely sad.
Thanks for sharing
— Michael
Hetzner dedi 4x NVME RAID 0 (I like to live on the edge!) (JK, I do backups every 6 hours)
Black Friday flash sale: Hostodo $199/year dedicated server
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat 27 Nov 2021 04:00:22 PM PST Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E31230 @ 3.20GHz CPU cores : 8 @ 2762.100 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 15.6 GiB Swap : 14.9 GiB Disk : 901.1 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 128.59 MB/s (32.1k) | 214.77 MB/s (3.3k) Write | 128.93 MB/s (32.2k) | 215.90 MB/s (3.3k) Total | 257.52 MB/s (64.3k) | 430.67 MB/s (6.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 229.45 MB/s (448) | 230.92 MB/s (225) Write | 241.65 MB/s (471) | 246.30 MB/s (240) Total | 471.11 MB/s (919) | 477.22 MB/s (465) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 835 Mbits/sec | 169 Mbits/sec Online.net | Paris, FR (10G) | 827 Mbits/sec | busy WorldStream | The Netherlands (10G) | busy | 179 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 904 Mbits/sec | 459 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 891 Mbits/sec | 120 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 932 Mbits/sec | 899 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 813 Mbits/sec | 196 Mbits/sec Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 821 Multi Core | 3058 Full Test | https://browser.geekbench.com/v5/cpu/11277529Daniel15 | https://d.sb/. List of all my VPSes: https://d.sb/servers
That’s very good for hdd
WebHorizon 256MB NAT in Chile 🇨🇱:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2021-10-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Nov 28 06:05:58 EST 2021 Basic System Information: --------------------------------- Processor : Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz CPU cores : 1 @ 1888.767 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 256.0 MiB Swap : 128.0 MiB Disk : 3.9 GiB fio Disk Speed Tests (Mixed R/W 50/50): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 27.53 MB/s (6.8k) | 113.22 MB/s (1.7k) Write | 27.55 MB/s (6.8k) | 113.82 MB/s (1.7k) Total | 55.08 MB/s (13.7k) | 227.05 MB/s (3.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 235.13 MB/s (459) | 243.90 MB/s (238) Write | 247.63 MB/s (483) | 260.15 MB/s (254) Total | 482.76 MB/s (942) | 504.06 MB/s (492) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 139 Mbits/sec | 62.8 Mbits/sec Online.net | Paris, FR (10G) | 168 Mbits/sec | busy WorldStream | The Netherlands (10G) | busy | 77.9 Mbits/sec WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 180 Mbits/sec | 123 Mbits/sec Velocity Online | Tallahassee, FL, US (10G) | 214 Mbits/sec | 95.5 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 196 Mbits/sec | 117 Mbits/sec Iveloz Telecom | Sao Paulo, BR (2G) | 247 Mbits/sec | 154 Mbits/sec iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | | | Clouvider | London, UK (10G) | 96.0 Mbits/sec | 44.6 Mbits/sec Online.net | Paris, FR (10G) | 141 Mbits/sec | 36.7 Mbits/sec WorldStream | The Netherlands (10G) | 95.6 Mbits/sec | busy WebHorizon | Singapore (1G) | busy | busy Clouvider | NYC, NY, US (10G) | 121 Mbits/sec | 91.7 Mbits/sec Clouvider | Los Angeles, CA, US (10G) | 102 Mbits/sec | 43.2 Mbits/sec Geekbench 5 test failed. Run manually to determine cause.Need a free NAT LXC? -> https://microlxc.net/
